Mobil 1 0W-40 ESP Dexos 2 Ordering Option
Summit Racing 10.67 a quart. Buy 2 cases (12 quarts) for 127.98 and get free shipping.
https://www.summitracing.com/parts/mob-123875
Good luck getting this oil for 6 dollars a quart. I wish i could name prices i wanted to pay for everything in life too, but i cant... So many threads wanting this oil for walmart 5w30 prices.
Here is our link to 10 Quarts and we are as competitively priced as we can be. Honestly margins are horrible but we wanted to make this oil easily accessible to all and expand our customer base. We ship this out almost every day to new buyers and now already some repeat buyers all over the country.
https://horsepower-addicts.com/colle...-esp-0w-40-oil
HorsePowerAddicts (12-14-2018)
The following 2 users liked this post by Kevin A Jones:
devnull (12-14-2018),
E-Ray, 3LZ, ZER, LIFT
Received 9,615 Likes
I notice "Triscuit" now has 10 flavors! If you can get the public to demand and the product moves, a competitor looses a spot on the shelf!
This store lists the correct part number for a 6 quart case but the photo is not of the correct oil. Might be worth checking into as 12 quarts for $100 with free shipping is best I've seen.
https://www.speedwaymotors.com/Mobil...ts,371931.html
It's NOT. The title states European 0W-40. This has been around for years. Walmart has for about the same price as 5-30 etc of ~$25.00 for a 5 quart jug. (Note jugs are significantly cheaper than quarts, even at Walmart. And Mobil has a $12 rebate for Jugs with 2 allowed per person. The Rebate runs twice a year and lasts several months.)
One bit of possible confusion in the 2 in front of the word dexos. That refers to version 2. There was a version 1 but no longer! The 1 or 2 after the dexos refers to the specification. The dexos 2 was for diesels and it is a tougher spec. The new Mobil 0W-40 ESP in dexos 2. Could it be used for diesels? Yep IF the weight is specified for that diesel. I believe the factory fill for a Duramax diesel is 15W-40.
I know many are enamored with the 0W-40 but the "Forum oil expert" has said viscosity improvers (which is how a 0 weight oil holds it's viscosity to 40 at a specific higher temperature to be rated 40,) in the past he indicated it did not last! He does say he reserves judgment and will await the SDS to see if he can identify a change.)
A 15W-40 has less of the "viscosity Improver" so you're likely to have that weight until it's changed.
I expect Mobil and GM have done all the required testing. But frankly since I don't track, don't get close to 300 F oil temp, I seldom start my car when it's below 40 F- the 5W-30 that came with my 2017 Grand Sport is fine with me and won't change until the price of the ESP is equal to most other Mobil oils at Walmart.
Sr.Random input generator
I called Speeeway for clarification. I have a feeling that it's indeed the right product, but their title is a copy paste disaster. Their technical staff will be back on Monday. I'll either call them during the week, or put an order, asking them to check part number before shipping. Hmm, yeah I'll just do that actually.
Alright, placed the order for 4 cases, and put a note asking them to check. We'll see!
Dexos2 was originally a diesel spec but it's beginning to be specified in gasoline engines now. A lot of people do confuse the dexos1 gen 2 symbol to mean dexos2 though. The key is that the dexos1 logo is in green and the dexos2 logo is in blue, so you can immediately identify the oils that have either of those certifications. When you see the green dexos1 logo and you see the number 2 in it as well, that refers to generation 2 which is the latest version of dexos1 and is a better oil as it lessen the chances of LSPI (low speed pre ignition) I believe dexos2 has already addressed that issue a long time ago.
#33
I think JerryU's pic on the right side is for the European version of M1. Two things that are different on the label compared with the US version of the Corvette oil is the label for the Euro version indicates 1 L (liter) and also the wording "Fully Synthetic". The US version shows 1 QT with the wording "Advance Synthetic". I don't believe the European version is recommended for the Vette.
#34
Received 2,047 Likes
St. Jude Donor '13
"ESP 0W-40 Dexos2"
If it says that on the bottle, then I think it's ok. Whether the two oils are actually a little different, or just two different people wrote the label, is unclear to me.
#35
#36
Here's info from Mobil1, which clears up which oil is correct for C7:
bosco1 (12-25-2018)
#37
#38
Received 8,924 Likes
I recently had the dealer change the oil in my car and provide an extra quart for later on. Here are the pictures of the container I have in the garage.
Note the Bar Code is 071924471115
The key item defining this oil from the European Formula is the ESP Formula (Emissions System Protection) Logo. If you check the Answers in the ask Tadge section you will see where he says the Mobil 1 15W50 oil recommended for track usage wasn't recommended for street usage because it reduced catalytic converter life (causing increased warranty claims under the 80K/8 Year Emissions Warranty) and decreased fuel mileage. The ESP Formula resolves those two problems.
Bill
Bill
The following 2 users liked this post by Bill Dearborn:
bosco1 (12-25-2018),
malexand123 (12-25-2018)
#39
Your post #32 show a 1 Liter bottle of oil (which I was referring) and this is what has been online for sale as the European variant. Note the 1 Liter label. I have also found a European Material Data Safety Sheet indicating it's Dexos2 certified this oil as well. I believe the oil you show here is not the Dexos2 Euro oil but some other oil. It doesn't mention GM on the label.
#40
Perhpas as mentioned above, shelf space is a very important, limited resorce at Walmart and every retailer. For Walmart (and others) it’s much more important than a few $s extra margin!
Side Bar:
Remnded years ago of going with our National Accounts Manager to Sam’s when we had a chance to get their oxyacetylene outfit business. There were located in a large metal building next to Walmart headquarters in an old high school building in Bentonville AK. To emphasize their “low cost” philosophy, no ties were allowed and you bought coffee in the wating area for $0.10 as I recall.
We met with that commodity buyer on a wooden picknick table with ~6 foot partitions between the numerous buyers tables. I remember the buyer said, "We just put a small mark-up on your price because we’re just in business to get ‘good deals’ for their Club Members." I recall he said something like 12%. So I priced the product just under the competitive incumbent offering. He said fine, you pick any ~5 Culub stores you want to have a trial. We did.
Our National Accounts Manager was telling him about the superior features of our product. He said very clearly, "I don’t care if it’s an oxyacetylene outfit or duct tape! I only am allotted a fixed amount of shelf space in the CLUB! Whatever product gets the most revenue is all I care about!"
