Is C7 designed to shake a little while idling?
Old 12-15-2018, 01:33 PM
  #41
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
Originally Posted by rrepp
I'm sure some will question this, but since it's true with my Stingray I'll say it anyway. My car idles a little rough too. But if I floor it and rev it up near the red line a couple of times it seems to idle a little bit smoother. I believe these motors benefit from being 'cleaned out' every once in a while. I had a Mercedes 420 years ago that had the 5.0 liter V8 in it and I could not tell the motor was running while idling, when sitting in the drivers seat. Zero vibration. Zero noise.
You get the same thing if you had a Cadillac V8. The cars were designed for different market segments than the Corvette. Mild cam and a V8 will run smoothly with barely a tremor. You get the lope when you change the cam duration to increase power at higher rpms. My Tahoe 5.3 runs smoothly.
Bill
Old 12-15-2018, 02:55 PM
  #42
Skid Row Joe
Skid Row Joe's Avatar
Received 3,962 Likes on 2,872 Posts
^^^^ I had a similar experience 26 yrs ago riding in a colleague's '90 560SEL. Got in the passenger seat and could not tell that the engine was running. Incredible experience, no sound or vibration from the engine! Esp. since I was raised in a household where my parents drove clickety-clack
​​​​​​​MB 4-cyl. 220D & 240Ds.
Old 12-15-2018, 04:34 PM
  #43
orca1946
orca1946's Avatar
It shakes almost like my 1978 Trans am hood shaker!
Old 12-15-2018, 04:38 PM
  #44
nytrorcr
nytrorcr's Avatar
I would think it's all that POWER in my Z06,
Old 12-15-2018, 07:14 PM
  #45
Walt White Coupe
Walt White Coupe's Avatar
Received 2,221 Likes on 1,139 Posts
I'm sure it wasn't "designed to shake", but that's as "smooth" as they could get it.
Old 12-17-2018, 07:57 AM
  #46
~Stingray
~Stingray's Avatar
St. Jude Donor '17, '19
Originally Posted by tobaccokid
This post must be a joke. A sports car “shakes a little”. Geez. Buy a Cadillac or Mercedes.
I think this comment is ridiculous and unhelpful. There are plenty of sports cars out there that don't shake at idle. Even cars that far exceed the hp of the corvette. So if you are not familiar with the Corvette, as several have pointed out, then you would think the car is running hard instead of running normal. And since it has been shown a softer idle is possible, even in older cars, then it appears it was done somewhat on purpose because we like "feeling the power".
Old 12-17-2018, 08:11 AM
  #47
UsernameProtected
UsernameProtected's Avatar
I think it's a feature intentionally not engineered out. My c7 does shake a little at idle all the time, but only about half what my c6z did. It reminds me of racehorses that move around nervously in the starting gate, just before exploding.
Old 12-17-2018, 08:27 AM
  #48
eseibel67
eseibel67's Avatar
The more I think about this, the idle shake is done on purpose. Stock LS engines (on which the LT1 is based) idle very smooth. Addition of variable cam timing on LT1 engine would make it possible for engine of 6.2 liters to idle SUPER smooth with 200/207, .551/.524,116.5 cam profile if so desired. The idle shake is intentional.
Old 12-17-2018, 11:37 AM
  #49
intensifi
intensifi's Avatar
Think of it as foreplay.
Old 12-18-2018, 12:55 PM
  #50
wgood
wgood's Avatar
How many full tanks of gas have you run through and were they bought the same time of the month or same gas station we need some more information ???? Wayne
Old 12-18-2018, 03:51 PM
  #51
Walt White Coupe
The C6 shook at idle and so does the C7. To think that GM had a perfectly smooth engine and then screwed around with to make it shake at idle is absurd. Some people will believe anything.
Old 12-18-2018, 06:44 PM
  #52
Kevin A Jones
Kevin A Jones's Avatar
Received 11,544 Likes on 5,536 Posts
Which sports cars far exceed the HP of the Corvette and don't shake?
Old 12-18-2018, 07:26 PM
  #53
449er
449er's Avatar
Received 4,683 Likes on 2,983 Posts
Originally Posted by Drive-C7
Like a lot of high performance engines the C7 cam shaft has higher lobes than normal street engines. I built an engine years ago for a 1961 Corvette that had a cam so high it would not idle less that 800 rpm. The car idle is normal for the car.
if you ever get a chance to stand next to a C1 with 270 HP motor will it is running you will see a Corvette "shake".
Stand next to a C2 427/435 hp motor while it is running & you will see a Corvette "shake" Lol
Old 12-18-2018, 07:30 PM
  #54
Walt White Coupe
While this isn't a sports car, it has a pretty sophisticated engine at 4.4 Liters and 445 HP with twin turbos and 4 valves per cylinder and is so smooth you can't tell it's running.
Old 12-18-2018, 07:46 PM
  #55
DSOMDream
DSOMDream's Avatar
Shake rattle and roll ! Paul
Quick Reply: Is C7 designed to shake a little while idling?
