How Soft our Tires Really Are!
Old 12-17-2018, 09:22 PM
gmarcucio
gmarcucio's Avatar
Default How Soft our Tires Really Are!
I have my 2019 Stingray tucked away in my shop for the winter. My EOS Side Skirts and front splitter arrived the other day so I figured I would put the car on the lift and check things out to see what kind of a job it's going to be. While the car was on the lift I noticed a stone in the tire (not in the tread groove) and I started to pick at it and when it fell out I couldn't believe how far it was embedded into the tire and the cavity it left in the tire! I'm wondering will this cavity fill in and come back together again after being driven on warm roads?
Mello Yello Maizey (12-17-2018)
Old 12-17-2018, 09:45 PM
Steve_R
Support Corvetteforum!
Steve_R's Avatar
Received 3,288 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
That’s not something to worry about. And it can happen to any tire, not just “soft” performance tires.
Old 12-17-2018, 09:47 PM
mschuyler
mschuyler's Avatar
Received 3,818 Likes on 1,614 Posts
Just adds a little traction!
Old 12-17-2018, 09:49 PM
gmarcucio
gmarcucio's Avatar
If I get enough of them in there I'll have studded snow tires for the winter!
owc6 (12-18-2018)
Old 12-17-2018, 09:50 PM
sTz
sTz's Avatar
Received 2,396 Likes on 1,586 Posts
Yes, they’re soft, and no, the cavities will not fill... unless it’s with another stone.
Old 12-18-2018, 12:21 AM
Received 19,186 Likes on 13,910 Posts
'20-'21-'22-'23-'24
That's one way of looking at it.
Old 12-18-2018, 08:15 AM
gliot1
gliot1's Avatar
Received 1,443 Likes on 753 Posts
Did you ever see or feel how soft a Indy car or NASCAR or top fuel dragster tire are? Almost sponge rubber like. At a drag race there are pit crew members that brush the tires off so no pebbles are stuck on them as the roll up to the tree. NASCAR tires last about 50 laps roughly 75 mi. At least our Vette tires last around 15k mi.
Old 12-18-2018, 10:21 AM
V Vette
V Vette's Avatar
Whats winter????
Old 12-18-2018, 10:34 AM
onebadcad
onebadcad's Avatar
You want soft / performance tires on your C7, if you can cut the tire, superficially, with a fingernail, you are good to go.
There are tires options less sticky, but that is akin to putting 87, or less, in the tank.
Another take, the pebbles are nail or screw blockers.
Old 12-18-2018, 01:06 PM
Dif
Dif's Avatar
Yup, but this doesn't happen to my Michelin A/S tires I put on in the Fall.
Worse case with the A/S tires is an occasional stone stuck in between the tread grooves
To How Soft our Tires Really Are!
Quick Reply: How Soft our Tires Really Are!
