What are the negatives to lowering on the stock bolts?
Old 12-20-2018, 08:47 AM
DGA3
DGA3's Avatar
Default What are the negatives to lowering on the stock bolts?
I mean, besides the obvious - that you will have less front end clearance when negotiating inclines and declines.
Besides that, what are the drawbacks? Does it affect handling? Tire wear? Void the warranty?
I think the C7 looks better when it is lower (especially the back end - there's a lot of clearance there!), but I don't want to mess anything up.
Thanks in advance for your wisdom.
Maxie2U (12-20-2018)
Old 12-20-2018, 08:58 AM
LilNutSac
LilNutSac's Avatar
You'll just need to get an alignment. Yeah, obviously it'll scrape more here and there. But it looks a thousand times better to me!
**WARNING** The "LEAVE IT ALONE!!!" crowd will be here shortly. I say make it yours! Enjoy it!
Old 12-20-2018, 09:41 AM
Sconn
Sconn's Avatar
Definitely NOT in the "DO NOT do it" crowd. It was one of the first things I did (and an alignment after).
I haven't scraped anything yet. But I'm the person you hate to be behind entering and exiting places. It did make an improvement, although there's still a decent gap. I won't go any lower though. I think the car rides a little stiffer as well.
Old 12-20-2018, 09:50 AM
HooosierDaddy
HooosierDaddy's Avatar
Haven't experienced negative side affects, only positive improvement in appearance!
Old 12-20-2018, 09:53 AM
JJLAI724
JJLAI724's Avatar
You'll need to go over speed bumps really slow. I've gone over a few speed bumps and have scrapped coming down after the front wheels go over it. But it does look better.
Old 12-20-2018, 10:46 AM
Z06 1of38
Z06 1of38's Avatar
Drop it!
Old 12-20-2018, 03:27 PM
DGA3
DGA3's Avatar
Originally Posted by Z06 1of38
Drop it!
That looks niiiiiice!
K.Shupe (12-20-2018)
Old 12-20-2018, 04:18 PM
JakeC7GS
JakeC7GS's Avatar
St. Jude Donor '17
I wouldn't do it, but I DD mine and work on a military base with stupid huge speed tables at the gates. Not to mention some of the casino lots. Never want to be one of those stance-boys trying to zigzag over a hump.
They do look great lowered though.
Old 12-20-2018, 04:38 PM
LarryFL
LarryFL's Avatar
I wouldn't do it, but would die protecting your right to do so
Old 12-20-2018, 04:40 PM
2cnd Chance
2cnd Chance's Avatar
Default Has this ever been an Ask Tadge subject?
It would be good to hear from him regarding this. Personally I can’t see an issue, or why would they have designed it this way.
Old 12-20-2018, 05:16 PM
orca1946
orca1946's Avatar
Hitting everything, poor tire wear ,can't get out ,smashing animals !
Old 12-20-2018, 05:28 PM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
You won't get any worse tire wear with it lowered on stock bolts than you would if it were at the stock ride height. The only way lowering it will make the tire wear worse is if you're alignment is off, but that can happen just the same at the stock height.
I had mine lowered with under 400 miles on it and now have 9179 miles and have no problems with it at all. The ride is still comfortable, and I really don't have any issues with speed bumps or getting in and out of various driveways.
The following 2 users liked this post by Patman:
Blackbird13 (12-20-2018), Steve_R (12-20-2018)
Old 12-20-2018, 05:52 PM
Mobil 1
Support Corvetteforum!
Mobil 1's Avatar
No downside, No alignment needed. No extra tire wear.
Chicks dig it.
Old 12-20-2018, 05:57 PM
Steve_R
Steve_R's Avatar
Received 3,290 Likes on 1,400 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
Lowered mine all the way on the stock bolts when I got it nearly 5 years ago. Other than being careful at times I've had no problems at all - and it looks much better without the raised 4x4 look.
Old 12-20-2018, 06:17 PM
pedalpusher
pedalpusher's Avatar
Someone on this forum showed how to lower these cars on stock bolts. Where can I find that information?
Thanks in advance.
Old 12-20-2018, 07:55 PM
HorsePower Junkie
HorsePower Junkie's Avatar
St. Jude Donor '20-'21-'22-'23
Mobil 1,
Why does it not need an alignment after lowering it?
Doesn't the alignment specs change after being lowered?
Old 12-20-2018, 08:25 PM
HooosierDaddy
Thanks in advance.
Tons of videos on youtube showing the process.
To What are the negatives to lowering on the stock bolts?
Old 12-20-2018, 08:35 PM
DSOMDream
DSOMDream's Avatar
No fat chicks allowed, car will scrape! Paul
Old 12-20-2018, 08:42 PM
blackmagicZ
blackmagicZ's Avatar
No issues at all. Have gone over speed bumps without scraping and didn’t need an alignment.
Old 12-20-2018, 10:58 PM
Mobil 1
Mobil 1's Avatar
Nope
Quick Reply: What are the negatives to lowering on the stock bolts?
