C7 battery tender
Art17 (12-31-2018)
Moderator
Nope. But if you want to leave it cracked open it's not an problem. Interior light turns off after a short time. No need to worry about it. Some of us just gently close the hatch on the cord. You can pre bend it with a stair step shape to fit the molding better. I routed mine in the corner most area. The cord will not be damaged.
The following 4 users liked this post by Zjoe6:
What’s the issue going through trunk? I always thought it was a great idea.
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
I dont like the way the cable pushes the trunk weatherstrip. I connect the tender to these clips and then to the underhood 12v connection on the fusebox and ground. Much easier to route cabling out from under the hood than the trunk.
I just toss a towel over the rear fender and let the cord hang. My cover fits fine.
The following 6 users liked this post by saleen556:
Apocolips (12-30-2018),
JDSC8VETTE (01-01-2019),
jmmoh (01-01-2019),
MTsVette (02-22-2020),
probono (12-29-2018),
and 1 others liked this post.
SoCal Events Coordinator
St. Jude Donor '12
I do the exact same thing, use a microfiber towel in the corner of the trunk and let the cord hang down the side of the car. No damage to the weather striping, no damage to the paint and the car cover goes over the car/chord just fine.
Maybe not clever, but, I have mine connected under the hood. Drape a polishing cloth over the bumper for the cord......dont close the hood, just set it down. For me its a much easier set up.
In my garage, the nearest outlet is too far away, neither end of the tender is long enough to do this. If I set the tender on the floor so the wires hang down the side of the car, the cord will not reach the outlet. I COULD use an extension cord, but it is not recommended. If I mount the tender on the wall (like it is now), the wires are not long enough to allow use of the car cover. The best solution for me would be longer wires from the tender body to the plug in the trunk.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Since the max current out of the transformer is low, if I wanted to mount the unit on a wall, I'd just extend the wires coming from it by soldering in whatever length is needed- but that's me.
