Flat bottom steering wheel on 2015 Stingray
Hi guys,
I just wanted to ask if you can fit a flat bottom steering wheel (as on the 2016+ models) to a 2015 Corvette Stingray 3LT which currently has the round style steering wheel - I've heard rumours there may be issues with whether the standard airbag is compatible?
Many thanks for your help!
Received 1,620 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Airbags are the same. Easy swap, lots on here have done it.
C7 of Year Finalist (performance mods) 2019
Very easy install, just make sure you have a good impact driver to break the steering wheel nut loose as it is on very tight. I used a kobolt 700lb impact driver as my 300lb desalt would not break it loose. Basically all you need to do is disconnect battery, pop out air bag using 2 screw drivers, unhook air bag wiring and all control wiring connectors, undo steering wheel nut and lift off. Under an hour to do it.
The following 2 users liked this post by chefcg1:
Tigerwooly (01-10-2019),
VUDUC7 (04-11-2024)
Hi guys,
The following 2 users liked this post by Patches:
jbretthorton (01-10-2019),
Not to hijack the post, but I also am looking to do this since I recently bought a 2015 stingray z51. I have already looked on trunk monkey but have found two different part numbers. Could anyone possibly post the correct number? The options I found have a price difference of $410 so something seems off. Both are listed as fitting a z51 with auto trans and both are wheels with the correct color stitching. The two I found are: $323 wheel option and $732 wheel option so it's kinda confusing that both say they will fit. Any help would be greatly appreciated!
Jeffthunbird (01-11-2019)
