Noise reduction / stereo upgrade project
So far everything I read up on especially this seems to give you a problem with the audio system. The C7 seems like it will be a challenge to upgrade the whole system. I had my C5 Z06 done which I sold to get my C7 Z06. My C5 had sound deadening done. Which I plan on having the crazy cowboy insulation kit done to my C7. I have a friend who I been dealing with for years doing all my installs on my cars. I will be chatting with him to see what options I can do with a system in my C7. I do have the 1LZ so it is the 9 speaker system I believe. But I only got the car. It is stored for the winter. Only has 50 miles on it. I want to drive it first and get some miles on it. I may chose just to have my installer do the sound deadening kit. Or just wait if i’m going to upgrade the sound system.
1. I went with the 10 inch Pioneers after considering others. I even orders some JL 10s and found they were too small. The Pioneer 10s, like the 8, lined up perfectly. The shallow JL 10s were significantly more expensive, which honestly wasn't a problem, but again, the speakers were too small and the mount holes did not line up. I didn't try all the ones you listed. If you do, make sure to let everyone know the outcome.
2. The larger size of the Pioneer is why it fits, others did not line up and would require fab. I considered several different 10s and even ordered a set of JLs, but I found that only the Pioneer 10s har mounting holes that fit the car and did not require an adapter. The JL shallow 10s were considerably more expensive, which I didn't really care about, but again, they did not line up with the stock mounting holes.
2. The larger size of the Pioneer 10s is why it fit in the car. Others were too small and would require fab work I didn't want to deal with on principle. I wanted this to look as stock as possible, just sound better.
3. I actually just ordered the JL coaxial 3.5 inchers first, and when they fit, just went with them.
I'm also sold on the JL 3.5s. Solid reviews.
Last question before I start ordering some shiznit...how did you arrive at the Kilmat's vs Dynamat or Noico? Dynamat seems to have a rep for being overpriced. I read a couple reviews saying beware Kilmat smell in hot weather (butyl), but Dynamat is made of the same stuff. Did you come across Noico in your research?
JMKarian (11-13-2019)
OK, I'm sold on the Pioneers. I'm not willing to play the guessing game on sizing on the others. The reviews are solid and the price is right. If they don't work out, or they get blown out, they won't be expensive to replace.
I'll post more details about how I wired in the speakers and more small details when I get a chance.
2016C7.paul (01-13-2019)
So Im planning the Upgrade on my C7 As well... ( I own a shop in South Fl) what Ive found thusfar is that the Midrange in the door is a 4 Ohm Load driver and the 10" door sub is a 1 Ohm Load but that the sub is passively crossed over with the tweeter ( If the graphic wiring breakdown is accurate This now makes me wonder what the impedience is on the tweeter.. If its 4 ohm then the Impedience will be about 2.5 in parallel. so those mid-subs are definitely Out! At this point I have gotten the NAV TV gm 650 Integration ( Im a Nav TV Dealer) Im going to swap the 1" tweeter in the dash and the Midranges with ARC Audio RS1 and RS3's Im still working on the door subs now. Currently the amp Plans are the Arc Audio X2 1100.5 (2 of them ) and the PS8 Digital processor 31 band EQ with phase and time alignment. Once I have a plan of attack in the doors Its game on. for Install Im keeping it simple all amps on the floor then build a panel that fill flush the amps up to the Hump. sub placement will be rather simple. Single 8" arc sub in a box firing 45 degrees utilizing the little storage unit as part of the box eliminating the need to make a bulky box sitting in the corner...
Input and thoughts are appreciated...
The following 2 users liked this post by jamiejam1:
2016C7.paul (01-13-2019),
JMII (01-14-2019)
So Im planning the Upgrade on my C7 As well... ( I own a shop in South Fl) what Ive found thusfar is that the Midrange in the door is a 4 Ohm Load driver and the 10" door sub is a 1 Ohm Load but that the sub is passively crossed over with the tweeter ( If the graphic wiring breakdown is accurate This now makes me wonder what the impedience is on the tweeter.. If its 4 ohm then the Impedience will be about 2.5 in parallel. so those mid-subs are definitely Out! =.
I plan on using the stock speakers except for the worthless 8" sub unless the door woofer is really 1 ohm. I believe with a decent amp and DSP processing (going JBL MS-8) the stock speakers could made to play much better. While the stock speakers are junk the poor (or no) crossovers, under powered amp and terrible Bose processing is holding them back. I think a lot can be gained just adding a decent DSP tune. With 10" door woofers, 3.5" door mids and a 3.5" center the sound stage should be excellent in this car. The tweeter placement is less then ideal and my frequency sweeps show it rolls off a bit too soon but it sure looks like you could fit just about any aftermarket tweeter in there given the large grille but I haven't seen what's behind it.
Passive cap cross-over on the tweeter (yellow part mounted to back of tweeter), no passive crossover inductor for the door woofer.
4 ohm tweeter with the 1 ohm mid sub can only mean they set this up in parallel which would put it at between 2.5 to 3 ohm load, which would then be consistent with the 3'ish ohm midrange... It also means that it (The sub) as some call it, is actually a very low Frequency playing "MID"Bass basically running at full range 60Hz to Maybe 300-400 hz. ( I may disconnect my midrange and run only the 10 and tweeter throw it on the Audio Control RTA with Pink Noise and see what frequencies are actually playin)g..... but limited to its own playable frequency response. This in itself could actually Play in as a benefit to anyone who wants to add a simple amp with high level inputs. Grabbing them at the Bose amp out, into the new sony 6 channel amp with the built in DSP @ High Level Input, you could swap out all the speakers Put in a simple 3 way setup like the new Sony 3 way system reduce the 10 in the door to a 6 1/2 with a plate, add a simple sub at the rear and call it a day.. ( Keeping in mind this is a Lower budget type of setup that eliminates things like the clean sweep, bit one, PS8 type of processors that run 600-1000 each... The worst part of it is having to run a 9 wire to each side of the car into the front stage... Audiophiles and SQ guys NEVER run rear fill speakers, cause your sound stage is always at the front....for the more budget minded this may be an option... as an SQ competitor, Im naturally going full mote on this so it should be interesting.. Love this thread cause we are getting down to the nitty gritty of this.....
Well I do carry Pioneer as a brand, and JL corporate, is in my back yard. That being said I think the choice of JL is a good one, the Pioneer leaves me with only one concern. The flat sub is exactly that, A subwoofer. I think that if this 10" is not capable of playing the higher mid bass frequencies there me be a hole in the frequency responses between 80 or 100 Hz up to 400 hz which is your standard snare taps going up to the low depth of the vocal frequencies.. Since the OP has already installed these I would defer that question to him for an accurate answer... As it was stated in a previous reply, apparently the 10 and tweeter are running in parallel with each other, so that mean the channel was designated as a full range mid bass with ultra low capabilities... OP? Insight?
#34
Yep all front sound stage for me
And you do NOT want to grab the high level off the Bose amp, its got all kinds of volume based EQ non-sense going on. You could, but only IF you used the DSP's volume control to get around this.
#35
#37
Loving this thread too...
I may start by just swapping the 8" sub...then I'd like to add an amp and separate volume control to that. This may be enough for me...but, we know how THAT goes with our rides.
#38
Snampro, how long and involved was it with removing just the 8" sub?
Saaaaay...for someone who really hasn't done that kind of tear down before. And I'll definitely order those tools you mentioned.
#40
When I take it out I'll take more pictures and post them here.
