Disappointed to say the least
Backed the car out for a little drive and this...Have owned the car 2 weeks and it has 969 miles on it! Waiting to hear back from the dealer
Moderator
Stingray? Wet sump,
Received 5,216 Likes
What is the fluid, at least? Assumed to be oil, above. Is it? If so, it could be significant to nearly zilch, as noted. The car is probably two or three years old... s**t's going to happen. The good thing is you saw it when you backed out. Hopefully it wasn't doing so when you drove it in. Was there a puddle? Big? Small?
You at least LOOKED where it was parked, right? You'll get it fixed and then... ENJOY!
Received 1,620 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Yes a little more info is needed. Is it Z51? It'll have dry sump and should have had the 500 mile oil change recently and perhaps has a small leak. Did you wipe your finger in the liquid and try to determine what it is? It could be a/c condensation but I doubt it if you just pulled it out cold. It does appear to be oil. You've had it two weeks and low miles, it's under warranty. Get it to the dealer and let us know what happened.
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
Looks like a non Z51 from the aero under the car (so wet sump). That puddle is right under where the filter is. My $20 bet is that the filter is the issue (not on all the way, or double gasketed). Any takers?
The following 4 users liked this post by devnull:
beaversstonehaven (01-12-2019),
joemessman (01-12-2019),
kenownr (01-18-2019),
rogergcam (01-15-2019)
I know things will happen but just disappointed guys. It's a Stingray 1LT so again, I don't know what or dry. I'm not very mechanical but I believe its oil. That is the puddle in my garage in the photo.
Moderator
You have a Stingray base car so it's a wet sump LT1 engine. All Z51, Grand Sport, and Z06 are dry sump. And it could literally just be a loose oil filter. Myself I'd be jacking it up to tighten it, check/add oil, clean it up and back in action. But I have the pucks.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
996toomey (01-13-2019)
Former Moderator
Landru (01-13-2019)
I thought stingrays didn't have the center air dam? Probably a dry sump.
Anyway, good news is 99% of the time, on new cars, oil leaks aren't a big deal. A hose or a gasket.
Base one does (have center dam). Z51 not so much
