Spoiler Question
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
Regarding adding the clear center section, although I could as I have a Grand Sport with the Stage 2 aero option -- I would not.
First, the spoiler extensions restrict the already fair at best rear visibility in a coupe. Not as bad as a Vert with the top up but close! Adding even a "clear" plastic center would add some distortion to what can be seen.
Second, Tadge (Corvette Chief Engineer) in a post provided the drag numbers for Stage 2 versus Stage 3 options. Stage 3, which essentially adds that large clear section increases drag 25%! It goes from 0.40 to 0.50! Even if tracking where the extra downforce it provides (85% more) would be useful, it would also be logical to remove it when driving on the street!
The cars already push hard. You don’t need the bridge on the track. Especially a stingray.
The new C7, is a worthy aspiration. I Love mine. Buying it changed my enjoyment of driving. Never thought I'd buy another Corvette in 42 years since my last new one. They (GM) were making cr@p IMO.. The C7 changed all that. LOVE MY C7! ♡♡♡
That's a funny plate / rear end..😛😛😛
I personally 'cheaped out', bought some rivenuts and the Stage 2 Winglets. Slid the winglets on the respective sides, drilled hole using winglets as a template. Screwed on wing......if you go this route, you will not be able to use the Stage 3 Clear piece as the holes will not align. There is no over-hang on the sides and its looks great. YRMV.
Hi all, first post from a new comer here, looking for some help with regards to the stage 2 winglets going onto a 2019 Z51 spoiler!. I have tried twice with no luck.
1st time I ordered the GM Z06 winglets, they were never going to work, way too wide! They went back.
2nd time, Ordered some online, and was assured, as the comments on there also agreed that these stage 2 winglets would fit, but they didn’t as you can see below in photos, so they are going back too!
i just got back from a corvette shop and the curve of the winglets was way off, away, from the curve of the spoiler... where have you guys ordered you z51 stage 2 winglets from, as I see many on here with them! All looking great.
thank you!
thank you!
