Brakes squealing
Brakes squealing
2018 stingray, 7, 678 mi. I can’t get rid of the squeal in the front brakes. Only seems to do it when cold backing out of garage. Goes away after it’s washed, but comes right back. Just started a month ago, don’t hear it after it’s warm or going forwards. Any help would be great!
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Have you tried bedding the pads?
I haven’t tried bedding yet, my thoughts were after 8,000 mi. They should be bedded? It just st started, doesn’t do it going forwards, or after being driven.
My brakes also squeal when I initially back out of the garage and that is the only time they do that. I am not concerned about it.
Do you know the procedure?
Find a nice back road, accelerate to 40 MPH. Hit the brakes hard until you slow to 10 MPH. Do not completely stop. Repeat 3 times.
Accelerate to 30 MPH and hit the brakes moderately hard until you slow to 5 MPH but do not stop. Repeat twice then drive for 3 - 5 minutes while avoiding brake use(to cool things down).
Taevon lee (01-17-2019)
As a next step after doing the above and it doesn't go away, remove the pads and apply some brake pad lube between the pad and the caliper.
Received 2,223 Likes
Seems pretty common that the brakes squeal when backing up after sitting for a while. Mine started doing that at around 10,000 miles on a base car. No big deal.
Brake paste (not lube or grease) might help if my theory is correct. NOTE: this stuff goes between the pad and the piston ONLY, it is sticky and works like a shim to stop the pad from vibrating. You don't want to use it any place where the pad, clips, springs need to slide.
JHII, I guess that's possible but I don't know if the leading edge of the pad wears more than the trailing edge. Why has this never happened on any other car of mine? I wonder if the "reverse" squeal only happens on base cars and not on Z51 cars??? Since the pad/rotors are quite different between the two.
I wonder if its just a pad compound issue as it seems to vary so much from car-to-car. If its the first stop of the day (IE backing out of your driveway) I would almost put it down to moisture or temperature differences. Pretty much all my vehicles squeak after I wash them or after it rains. Could also be related to how hot the brakes where when the car was parked.
Another good question is how many brake squeaking issues are due to the condition of the retaining clips. The clips should stop the pads from vibrating (which leads to noise) while also letting them slide in and out of position easily.
Squeal gone
so i did the brake bedding procedure yesterday, the problem was not there this morning backing out of my driveway. How long will it last?
