What do you use to heat your garage?
I was thinking of looking into this heater. A relative told me he bought this heater and said he s really liked how it proformed and didn’t cost much to run. He has a two car garage and likes to work in garage during winter to keep himself busy and thought I might be interested in getting one for my garage.
I wish my garage was heated today! It's only 33 degrees in there right now! I'd love to put another coat of polish on my C7 during this snowy cold day (it's only 9F outside right now, BRRR!) but I won't do it unless it's at least 50 in there. The little electric space heater I've got will only raise the temperature by about 10-15F, but it takes many hours to even bump it up that much.
Hey Gang,
Im looking to do some work on my C7 and C6 this winter, but holy crap is my garage cold... I dont want to "install" anything like a wall unit or pull gas lines to my garage... Im looking at simple floor standing units that do not require power.
For example I was looking at something as simple as this:
I dont need anything elaborate, just enough heat to be "comfortable" enough to work out in the garage for a few hours, and then shut the unit off.
Thanks for any advice you can share!
have to turn it down. Price is right from Amaxon
Mayor111 (01-19-2019)
I have one of these in my basement. It is powered by 220 volt electric. My basement measures about 60’ x 35’ = 2,100 sq feet and I run the heater even in the summer to keep the basement comfortable moisture free. I am on my second heater unit, first one lasted 15 years.
Cadet Twin 4000W Wall Heater is what I use in mine. My garage is 800 sq ft insulated with a 14' ceiling and it heats it well. I have a pedestal fan that circulates the air, and wired in a Honeywell thermostat (same as I have in house) so I can monitor and control the temp from anywhere - I usually run a schedule so it's 70 when I'm using it and lets it drop down to 65 or so when I'm away. I have a vent plumbed in from the house HVAC that cools well in the summer, but due to how the house is designed my heater hardly ever runs in the winter. With the garage on the NE side of the house, I had to add in something to help it out.
I had a mini-split heat pump installed in my 650 sq. ft. garage. In SoCal, it is primarily for A/C during the hot summers but I am a couple of thousand feet up so it can hit the high 20's in the winter which is why I opted for the heat pump. Next to my lift, the best investment I've made on my garage.
Mr heater Big buddy 18000 BTU propane heater use remote tank or the ones mounted that use tanks for outdoor cooking stoves.
z51vett
Doug
z51vett
Doug
#33
Received 2,051 Likes
St. Jude Donor '13
Can someone explain the issues with carbon monoxide ?
I had been told that any combustion heater makes CO, though some are worse than others. To be safe, one should either vent the exhaust gasses outside or go electric.
But lots of posters here seem to be using some kind of combustion and are still alive to write about it.
Details, please?
Thanks.
EDIT:
Corrected carbon dioxide to carbon monoxide.
Details, please?
Thanks.
EDIT:
#34
Can someone explain the issues with CO2 ?
I had been told that any combustion heater makes CO2, though some are worse than others. To be safe, one should either vent the exhaust gasses outside or go electric.
Details, please?
Thanks.
Details, please?
Thanks.
If I'm burning the heater, I crack the garage door open a couple of inches. When it gets warm, I shut off the heater and close the garage door.
1stTimeforEverything (01-20-2019)
#35
Received 19,293 Likes
'20-'21-'22-'23-'24
The garage the C7 sits in has a vent from the HVAC system to help with the heat and I supplement it with a portable electric heater. It keeps the garage in the mid 60's temp range during the winter which is OK for me.
#36
I know the post is for what do you use to heat your garage. This is for anyone building a new garage and looking to heat it. When my wife and I added on to our house I wanted my garage to be heated the best way. I had radiant heat put in the concrete. I keep my garage set at 64 and it is awesome. Able to wash them in the winter plus detail them. Pull in from the snow and the next day all water is dried up.
#37
I just got one of these.
https://www.homedepot.com/p/RIDGID-1...242B/305624072
Kerosene heaters smell, make CO and take too long.
Not sure if this link works correctly, but scroll down to the Q&A section. If not, read the first Question & Answers to the link you provided which covers it.
https://www.homedepot.com/p/RIDGID-1...kgQO90Yez3m200
#38
Details, please?
Thanks.
Details, please?
Thanks.
Everyone should have one of these. This one activates at very low levels and I highly recommend it.
https://www.kidde.com/home-safety/en...arms/kn-cou-b/
#39
Propane heaters also emit carbon monoxide & not recommended for houses or garages, unless you have good ventilation. Be careful if using it w/o proper ventilation.
#40
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Two 20000 btu electric heaters. One at each end of three car garage. Requires 240 volt circuits...was easy. Works great, takes about an hour to warm up to 60 degrees on below freezing days.
