Why are Vette's still push rod and plastic?
Old 01-18-2019, 09:09 PM
V Vette
V Vette's Avatar
Originally Posted by FLEXjs
Their
THEIR
There??? LOL, LOL
The following 2 users liked this post by V Vette:
Jmhornz71 (01-19-2019), mtaxman (01-22-2019)
Old 01-18-2019, 09:10 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,400 Likes on 1,365 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
There's no requirement to start a new thread every day.
Apparently there is!
(answer to OP - composite is generally lighter than steel)
Old 01-18-2019, 09:12 PM
V Vette
V Vette's Avatar
True so why don't more companies use the same plastic, SMC or whatever] it is? Also, comments are not required if you don't like post. Thanks!
Old 01-18-2019, 09:13 PM
Zymurgy
Moderator
Support Corvetteforum!
Zymurgy's Avatar
Received 15,066 Likes on 6,168 Posts
As for the "plastic", see Automotive Composites: Mass Reduction for Mass Production which even features the C7.
V Vette (01-18-2019)
Old 01-18-2019, 09:14 PM
LarryFL
LarryFL's Avatar
OHC's wouldn't fit under a low slug hood like the Vette's. What I love about the LT4 that they can still cram an SC under there. Couldn't do that with OHC's.
The following 4 users liked this post by LarryFL:
C6_Racer_X (01-19-2019), nmerhaut (01-19-2019), NSC5 (01-19-2019), V Vette (01-18-2019)
Kingtal0n
Kingtal0n's Avatar
I once read a long time ago that there was a motor called a 'hemi cammer' which was some kinda OHV V8 with two timing chains or something...
and it was too good. It beat everybody so they banned it.
Old 01-18-2019, 09:36 PM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,544 Likes on 5,536 Posts
An old adage "If it ain't broke, don't fix it, comes to mind.
Old 01-18-2019, 10:05 PM
Zymurgy
Moderator
Zymurgy's Avatar
Originally Posted by V Vette
True so why don't more companies use the same plastic, SMC or whatever] it is? ...
Many manufacturers ARE using SMC (or similar) for a variety of body panels. For example, the Lincoln MKS deck lid is SMC, The Acura NSX has SMC trunk, front and rear quarter panels. The Jeep Wrangler has a SMC roof. Most bumper covers are some sort of SMC material. The Corvette has been ahead of the curve on the use of such materials, and is continuing to lead as more parts are made of carbon fiber. This trend will continue to increase not only on the Corvette, but across the automotive industry.
The following 3 users liked this post by Zymurgy:
JimNeedsC7 (01-19-2019), NSC5 (01-19-2019), V Vette (01-19-2019)
Old 01-18-2019, 10:48 PM
lakemg
lakemg's Avatar
The main reason for the "plastic" body panels is for weight savings. If the vette was made with standard sheet metal panels, it wouldn't be the light weight beast that it is.
Chevy isn't the only one still using pushrods...all those hemis running around are still OHV configurations. Pushrod setups work well.
Old 01-19-2019, 09:12 AM
wgood
wgood's Avatar
Well if Corvettes were electric and all carbon fiber what do you think the price would be 200 thousand or more ????? Wayne
Old 01-19-2019, 09:32 AM
KEZ06
KEZ06's Avatar
Ford had a cammer as well. Motors are very large. Hell a regular 426 hemi is referred to as an elephant.
Old 01-19-2019, 10:16 AM
mammoth713
mammoth713's Avatar
Ok you Vette head experts, why in 2019 do Vette's still have a push rod engine and bodies still plastic (or some variance of plastic)? Thanks
Pushrod V8 is world-class in power density in small packagaging..
Lookup a photo of the ford coyote motor on an engine stand next to ls1 or ls7 or ls3
Old 01-19-2019, 10:36 AM
  #33
FLEXjs
FLEXjs's Avatar
wow.....
https://www.lsxmag.com/tech-stories/...-building-ls3/
Old 01-19-2019, 10:37 AM
  #34
V Vette
V Vette's Avatar
Thanks all... Love my Vettes!
Old 01-19-2019, 11:32 AM
  #35
Zymurgy
Moderator
Zymurgy's Avatar
And the clear winner is the LS3:
blkvet6 (01-21-2019)
Old 01-19-2019, 12:27 PM
  #36
C6_Racer_X
C6_Racer_X's Avatar
Like this photo?
Old 01-19-2019, 12:39 PM
  #37
mammoth713
mammoth713's Avatar
Originally Posted by C6_Racer_X
Like this photo?
Yup that's the one
To Why are Vette's still push rod and plastic?
Old 01-19-2019, 01:27 PM
  #38
CCA Corvette Parts
Premium Supporting Vendor
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
Because it's a Corvette
Regards
Chip
__________________
..................Click for
Old 01-19-2019, 01:32 PM
  #39
Oneslackr
Oneslackr's Avatar
I always laugh when people say - Why doesn't the Vette (or pick your car) have a modern DOHC engine? Well, the first DOHC car was the 1912 Peugeot which won the French Grand Prix at Dieppe,
http://theoldmotor.com/?p=62241.
The discovery of this photo prompted us to search out other Peugeot photos and construction details, which will show you this brilliant dohc, four-valve four-cylinder engine designed by Boillot-Goux-Zuccarelli or “Les Charlatans” as they were called. Boillot and Goux were both racing drivers and Paolo Zuccarelli was a very talented practical engineer-mechanic. This engine that they created in 1912, established the dohc four-valve layout that is still in use to this day.
Sure, the first production OHV engine is slightly older but not by much, 1904. They're both old designs.
In 1898, Detroit bicycle manufacturer Walter Lorenzo Marr built a motor-trike with a one-cylinder OHV engine with push rods for both exhaust and intake. In 1900, David Buick hired Marr as chief engineer at the Buick Auto-Vim and Power Company in Detroit, where he worked until 1902. Marr's engine employed pushrod-actuated rocker arms, which in turn pushed valves parallel to the pistons. Marr left Buick briefly to start his own automobile company in 1902, the Marr Auto-Car, and made a handful of cars with overhead valve engines, before coming back to Buick in 1904. The OHV engine was patented in 1902 (awarded 1904) by Buick's second chief engineer Eugene Richard, at the Buick Manufacturing Company, precursor to the Buick Motor Company. The world's first production overhead valve internal combustion engine was put into the first production Buick automobile, the 1904 Model B, which used a 2-cylinder Flat twin engine, with 2 valves in each head. The engine was designed by Marr and David Buick.
Old 01-19-2019, 02:04 PM
  #40
JFJr
JFJr's Avatar
Beautiful Vettes, you have good taste!
Quick Reply: Why are Vette's still push rod and plastic?
