Another case of dealership incompetence
#61
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
I expect the correct oil filter to be installed each and every time a dealership services a car they sell. I don't expect the service manager should have to read a bulletin that (at it's heart) says "use the correct filter, don't use the incorrect filter" in order to know that using the incorrect filter is incorrect.
No dealer should have to receive a bulletin telling them not to use incorrect parts. The fact they get bulletins stating that fact (because the issue is so widespread) should be disconcerting to us all.
#62
I'd argue it's more prudent financially to have a simple data base like the one I suggest in place than it is to have the system GM has in place now, so in that case, it's more due to stupidity than finances.
thompstl1 (01-23-2019)
#63
#64
For my C6 worked with the Service Writer to find specific Bulletins I knew existed from forum comments re my roof rattle and the free replacement of my dif fluid. She had to use the exact words that identified when they got paid for from GM. It literally said, “If customer complains of XYZ replace dif fluid.” She used those exact words NOT the typical input from owners, “My rear end makes noise!”
You have no idea of the number of bullitins they get including for Silverado’s etc. As I recall they sell over 500,000 Silverado’s per year versus ~30,000 Vettes. Considering the Servive Manager has to worry about mechanics not showing up for work, hiring new ones etc etc sure he is going to read every bulletin that comes in from GM and remember the details!
#65
"JerryU:
Do you expect Service Managers to read every service bulletin?"
When it comes to my car? Yes.
#66
I chalk up the bulletins as being education pieces for service/repair improvement. How are they going to stay competent at their profession if they let these critical communication pieces just get shrugged off. I get that it is overwhelming but that's not our fault. The majority of us are car people and understand that we might need to perform some due diligence on things, but not everyone understands things to that level and they really shouldn't have to since they are relying on the "experts" to perform the work to standard.
Found this and listed two: 1st The 2014 Corvette and 2nd The 2 wheel drive Silverado with a 6.2 Lier engine.
There are similar lists for the each available engine and 4 wheel drive models! I could list a similar list for all car and truck models by engine!
Automotive Recall and Technical Service Bulletin Titles for 2014 Chevrolet Corvette V8-6.2L VIN 7.
TSB Number: Issue Date:........….TSB Title
13417 JAN 14 Campaign - Software Updates for OSTER Activation
13384 NOV 13 Campaign - Low Rear Differential Fluid Level
13360 OCT 13 Campaign - Low Rear Differential Fluid Level
00-00-89-027H JUL 14 Interior - Eliminating Unwanted Odors
PI1276 JUL 14 M/T - Hard to Shift Into gear/Mushy Shifts, No Grinding
14-06-04-004B JUL 14 Engine, Fuel System - Various Noises During Engine Operation
10-08-46-001B JUL 14 OnStar(R) - Inadequate Radio Mute During Nav. Announcements
PIT5231A JUL 14 Audio System - Blank Display/DTC U150F Stored
PIP4112P JUN 14 Drivetrain Controls - Sag/Hesitation on Acceleration
05-03-08-002F JUN 14 Suspension - Shock Absorber/Strut Replacement Guidelines
PI1266 JUN 14 Audio System - Radio Reprogramming Using Techline(R)/SPS
PIP5188 JUN 14 Fuel System - Raw Fuel in The EVAP Canister
PI0373B JUN 14 Body - Power Foldaway Mirror Glass Shakes/Flutters
PI1258 JUN 14 Brakes - Squeal/Squeak on Initial Apply
PIC5088E JUN 14 Audio System - XM(R) Band Not Receiving All Channels
PIC5588B JUN 14 OnStar(R) - Replacement Module Activation/Programming
PIC6009 JUN 14 Suspension - Rear Sway Not Present on Independent Susp. Vehicle
I1126C JUN 14 Instruments - Various Malfunctions, Issues
PIP4112P JUN 14 Engine Controls - Normal Sag/Hesitation on Acceleration
PIP4653E JUN 14 A/T Controls - MIL ON/Multiple DTC's Stored in The TCM
PIP5165B MAY 14 Engine - Oil Dripping From the Air Filter Box
00-03-10-006J MAY 14 Tires - Radial Force Variation (RFV) Information
03-03-10-007I MAY 14 Wheels/Tires - OE Tire and Wheel Characteristics
PI1238A MAY 14 Audio System - No XM(R) On Start Up
PI1245 MAY 14 Memory Systems - Auto Memory Recall Option
12-08-132-001B MAY 14 Electrical - Power Outlet/Trailer Lighting Fuse Replacement
06-00-89-029J MAY 14 Interior - Cleaning Plastic Surfaces
14-08-117-001 MAY 14 Body Controls - Unable to Clear BCM DTC's After Repairs
PI1235 MAY 14 Electrical - Proper Ground Terminal Repair Information
05-06-04-035D MAY 14 Fuel System - E85 Fuel Usage Information
PIT5285 MAY 14 Cell Phone - Call Screen Displayed After Call is Ended
PIT5283 MAY 14 Audio System - Radio Touchscreen Inaccurate/Hard to Use
11-08-49-001K MAY 14 Instruments - 'Transport Mode ON' Mssg, Battery Lamp Flashes
PIP5130D APR 14 Engine - Intermittent No Start, DTC's P0011 or P00C6
PIP5185A APR 14 Engine - Rattle/Flutter When Switching From V4 - V8 Mode
PIC5994 APR 14 Interior - Heated Seat Turns Itself OFF
PIC5991 APR 14 Cell Phone - Brief Static During Outbound Bluetooth(R) Calls
01-08-42-001J APR 14 Lighting - Exterior Lamp Condensation/Replacement Guidelines
02-08-42-001G APR 14 Lighting - Head/Tail/License/Fog/Driving Lamp Damage Info.
PIC5491F APR 14 OnStar(R) - System Will Not Power Up
PI1220 APR 14 Body - Front Edge of Door Contacts Front Fender
PIP5170A APR 14 Drivetrain - Torque Tube/A/T Noise Diagnostic Information
PIP5168C APR 14 Engine - Crank But No Start
PI1159C APR 14 Infotainment System - Various Issues/Concerns
PIC5970A APR 14 Wheels - Installing Z51 Wheels On a Non-Z51 Car
PIC5985 APR 14 Exhaust System - NPP Performance Exhaust Information
PIP5189 APR 14 Fuel System - Black Smoke On Cold Start
PIC5982 APR 14 Instruments - Defaults to 'Tour Mode' At Start Up
PIC5978 MAR 14 Audio System - Favorites List Covers Menu Options
PIC5854B MAR 14 Audio System - HD Radio Signal Cuts In and Out
PIT5268 MAR 14 Audio System - Normal Operating Characteristics
PI1204 MAR 14 Instruments - Driver/Passenger Temp. Displays Flicker
PIC5975 MAR 14 Steering - Vehicle Pulls To The Right At Highway Speeds
PIC5976 MAR 14 A/C - Excessive Temperature Changes With Minor Setting Change
PIC5948B MAR 14 Instruments - IPC Not Showing Various Functions/Erratic Message
PIC5934B MAR 14 Audio System - Rolling/Flickering Radio Display
PIT5964 MAR 14 OnStar(R) - Canadian Customers Unable to Make Calls in USA
PIC5374C MAR 14 OnStar(R) - Off Route Message During Turn-By-Turn Operation
PIC4801F MAR 14 OnStar(R) - Turn-By-Turn Feature Inoperative
PIC3011H FEB 14 OnStar(R) - Voice Recognition Operation Issues
PI1179 FEB 14 Instruments - Analog Temp Gauge Doesn't Match Digital Gauge
09-03-10-016B FEB 14 Wheels - Preventing Chrome Clad Wheel Damage
12-03-10-002A FEB 14 Wheels/Tires - Vibration Felt Between 58-72 MPH
PIC5968 FEB 14 Navigation - Normal Map View Changes During Operation
05-03-10-020E FEB 14 Tires - Nitrogen Gas Usage Information
08-03-10-006E FEB 14 Wheels/Tires - Tire Slowly Goes Flat on Aluminum RimP
IT4943C FEB 14 Emissions - EVAP DTC P0442 Diagnosis
02-08-98-002E FEB 14 Body - Hem Flange Rust Repair Information/Procedure
14-03-10-001 FEB 14 Steering/Tires - Tire Hop/Chatter on Low Speed Tight Turns
PIC5944A FEB 14 Memory Systems - Seat Memory Module DTC B285A
PI0488D FEB 14 A/T - No Forward Engagement/Slipping
PIT5252A FEB 14 Body Controls - Horn/Wipers/Hazard Flashers Stuck ON
PI1167 FEB 14 Electrical - Missing Nut on 100 AMP Fuse Stud
PIP5179 FEB 14 Fuel System - Extended Cold Start Crank Times
PIP5176 JAN 14 Cooling System - Engine Runs Hot or Overheats
13-03-10-001A JAN 14 Tires - Cold Weather Tire Cracking Information
99-08-51-007F JAN 14 Wheels - Information Regarding Refinishing Aluminum Wheels
14-08-42-001 JAN 14 Lighting - Headlamp Inoperative Diagnostic Tips
PIC5161D JAN 14 Audio System - Normal Key OFF Operation
PI1108A JAN 14 ABS/TCS - Performance Traction Management (PTM) Inoperative
PIP4670D JAN 14 Computers/Controls - Module Swapping Warning
PIC5953 JAN 14 Cell Phone - Voice Recognition Issues Involving Emojis/Symbols
PIP5173 JAN 14 Engine - Buzz on Initial Start Up
PI1101B JAN 14 Instruments - Lighting Brightness Too Low
PI1103A JAN 14 Memory Systems - Power Seat/Mirror Inoperative
PI0281D JAN 14 Body - Under Body Corrosion
PIP3140F JAN 14 Vehicle - Abnormal Noise/Vibration Due to Aftermarket Items
01-07-30-042H JAN 14 A/T - 2-3 or 3-2 Shift Clunk Noise Information
PI1148 JAN 14 Body - Revised Front Lower Air Dam
PI1144 JAN 14 Interior - Driver Seat Outer Side Trim Cover Comes Loose
04-03-10-013H DEC 13 Drivetrain - Rear Wheel Drive Characteristics/Winter Tires
05-00-89-072C DEC 13 Fuel System, Engine - Fuel and Oil Additive Information
13-04-17-001 NOV 13 Drivetrain - Torque Tube to Front Hub Bearing Alignment
00-06-01-026E NOV 13 Engine - Inspection After Severe Internal Engine Damage
PI0018B NOV 13 Body - Front/Rear Side Door Windows Bind/Noisy/Move Slowly
05-06-04-022J NOV 13 Fuel System - TOP TIER Gasoline Information (Canada)
04-06-04-047L NOV 13 Fuel System - TOP TIER Gasoline Information (US)
10-08-110-001A NOV 13 Interior - Proper Use of Floor Mats
06-08-51-005C OCT 13 Body - Hem Flange Sealer for Corrosion Protection
01-06-01-011H OCT 13 Engine - Oil Consumption Guidelines
00-03-10-002H OCT 13 Wheels - Chemical Staining on Chromed Aluminum Wheels
09-04-20-001D OCT 13 Drivetrain - Tire Chatter, Rear Differential Chatter
06-08-44-012G SEP 13 Navigation System - DVD Navigation Update Program
07-02-32-002N SEP 13 Steering - Power Steering Fluid Leaks
01-08-51-003D SEP 13 Body/Frame - Anti-Corrosion Material Application
06-06-01-010B AUG 13 Exhaust - Close-Coupled Converter and Engine Replacement Info
99-09-40-005G AUG 13 Restraints - Seat Belt Extender Availability
10-00-89-010C JUL 13 Locks - Key Code Security Rules, Applications (Canada)
13-00-89-008 JUL 13 Electrical - Wiring Repair Information
13-00-90-001 JUN 13 Engine - 2014 Model Year Engine Oil Information
05-09-40-002G JUN 13 Restraints - Normal Seat Belt Operating Characteristics
07-08-49-020H JUN 13 Instruments - Odometer Programming Quick Reference
08-07-30-026B MAY 13 A/T - Slight Movement in PARK on Cold Start Up
11-00-90-001B MAY 13 Engine - dexos 1(R) and dexos 2(R) Oil Specs/Information
03-08-48-006I MAY 13 A/C - Window Defroster Contact/Tab Repair Information
09-06-04-026G MAR 13 Engine Controls - Non-GM Engine/Transmission Calibration ID
99-08-51-001C FEB 13 Body - Paint-less Dent Repair Process
10-08-45-001D FEB 13 Electrical - Ground Repair Information
06-08-43-003D FEB 13 Wipers/Washers - Windshield Wiper Performance Information
Automotive Recall and Technical Service Bulletin Titles for 2014 Chevy Truck Silverado 1500 2WD V8-6.2L.
DECIDED TO LEAVE THIS AS THE STRING IT POSTED
TSB Number & Issue Date TSB Title=-webkit-left14315A JUN 14 Recall - Audible Warning Non-Compliance=-webkit-left14121B MAY 14 Recall - A/T Oil Cooler Line Connection=-webkit-left14204 MAY 14 Recall - Inner Tie Rod Torque=-webkit-left13323 OCT 13 Recall - Seat Back Recliner Lever Non-Compliance=-webkit-left13230B JUL 13 Recall - Passenger Air Bag Inflator Weld May Fracture=-webkit-left14126A JUL 14 Campaign - Odometer Display is Incorrect=-webkit-left14002A FEB 14 Campaign - Poor Underbody Appearance=-webkit-left13430 DEC 13 Campaign - Rear Differential Pinion Nut Improperly Fastened=-webkit-left13356 NOV 13 Campaign - Forward Collision Alert Audible Warning Inop.=-webkit-left13318 NOV 13 Campaign - Power Sliding Back Window Inoperable=-webkit-left13310A OCT 13 Campaign - Seat Back Movement=-webkit-left13304 SEP 13 Campaign - Incorrect Alternator Installed in Vehicle=-webkit-left13257 AUG 13 Campaign - Body Control Module Software Update=-webkit-left13240 JUL 13 Campaign - Power Steering Loss in Extreme Heat/Cold=-webkit-left13186 JUN 13 Campaign - Incorrect Battery Current Sensor Installed=-webkit-left13167A JUN 13 Campaign - Rubber Floor Mats Missing From Vehicle=-webkit-left00-00-89-027H JUL 14 Interior - Eliminating Unwanted Odors=-webkit-left14-06-04-004B JUL 14 Engine, Fuel System - Various Noises During Engine Operation=-webkit-left10-08-46-001B JUL 14 OnStar(R) - Inadequate Radio Mute During Nav. Announcements=-webkit-leftPIT5231A JUL 14 Audio System - Blank Display/DTC U150F Stored=-webkit-leftPI1212A JUN 14 Instruments - Improper/Incomplete Cluster Programming=-webkit-leftPI1273 JUN 14 Steering - Svc. Power Steering Message/DTC C056D-39=-webkit-leftPIT4250G JUN 14 Body - Water/Dust Through Bed Stake Pocket Openings=-webkit-leftPIP4112P JUN 14 Drivetrain Controls - Sag/Hesitation on Acceleration=-webkit-left05-03-08-002F JUN 14 Suspension - Shock Absorber/Strut Replacement Guidelines=-webkit-leftPI1266 JUN 14 Audio System - Radio Reprogramming Using Techline(R)/SPS=-webkit-leftPI1268 JUN 14 Lighting - RSE/Rear Dome Lamps Flicker With Turn Signals On=-webkit-leftPIT5298 JUN 14 Electrical - Installation od Upfitter Auxiliary Switches=-webkit-leftPI1265 JUN 14 Steering - Popping Noise From Front End of Vehicle=-webkit-leftPI0373B JUN 14 Body - Power Foldaway Mirror Glass Shakes/Flutters=-webkit-leftPI1262 JUN 14 Interior - Noise From The Center Console=-webkit-leftPIC5088E JUN 14 Audio System - XM(R) Band Not Receiving All Channels=-webkit-leftPIC5588B JUN 14 OnStar(R) - Replacement Module Activation/Programming=-webkit-leftPI1126C JUN 14 Instruments - Various Malfunctions, Issues=-webkit-leftPIT5277A JUN 14 Audio System - Various Radio Concerns=-webkit-leftPIP4112P JUN 14 Engine Controls - Normal Sag/Hesitation on Acceleration=-webkit-leftPIT5293 JUN 14 A/C - Unwanted Compressor Operation After Turning Off=-webkit-leftPIT4250G JUN 14 Body - Water/Dust Through Openings Under Bed Rails=-webkit-left14212 JUN 14 Campaign - Towing Capacity Owners Manual Supplement=-webkit-leftPIP4653E JUN 14 A/T Controls - MIL ON/Multiple DTC's Stored in The TCM=-webkit-left00-03-10-006J MAY 14 Tires - Radial Force Variation (RFV) Information=-webkit-left03-03-10-007I MAY 14 Wheels/Tires - OE Tire and Wheel Characteristics=-webkit-leftPI1238A MAY 14 Audio System - No XM(R) On Start Up=-webkit-left12-08-132-001B MAY 14 Electrical - Power Outlet/Trailer Lighting Fuse Replacement=-webkit-leftPIP5199 MAY 14 Engine - Crankshaft Balancer Appears To Be Wobbling=-webkit-left06-00-89-029J MAY 14 Interior - Cleaning Plastic Surfaces=-webkit-leftPIP3119M MAY 14 Exhaust System - Catalytic Converter Break In Information=-webkit-left14-08-117-001 MAY 14 Body Controls - Unable to Clear BCM DTC's After Repairs=-webkit-leftPI1235 MAY 14 Electrical - Proper Ground Terminal Repair Information=-webkit-left05-06-04-035D MAY 14 Fuel System - E85 Fuel Usage Information=-webkit-leftPI1215A MAY 14 Fuel System - MIL ON, DTC P0232 Set Diagnostic Tip=-webkit-leftPIT5285 MAY 14 Cell Phone - Call Screen Displayed After Call is Ended=-webkit-leftPIT5232A MAY 14 Instruments - Outside Temperature Won't Update=-webkit-leftPIP5175B MAY 14 A/T - Launch Shudder, Delayed Engagement, 1-2 Shift Bump/Clunk=-webkit-leftPIT5283 MAY 14 Audio System - Radio Touchscreen Inaccurate/Hard to Use=-webkit-leftPIP5130D APR 14 Engine - Intermittent No Start, DTC's P0011 or P00C6=-webkit-left07-08-42-006I APR 14 Lighting - BCM Updates for Bulb Outage Detection=-webkit-leftPIT5282 APR 14 Electrical/Brakes - Aftermarket Trailer Brake Controller=-webkit-leftPIC5991 APR 14 Cell Phone - Brief Static During Outbound Bluetooth(R) Calls=-webkit-left01-08-42-001J APR 14 Lighting - Exterior Lamp Condensation/Replacement Guidelines=-webkit-left02-08-42-001G APR 14 Lighting - Head/Tail/License/Fog/Driving Lamp Damage Info.=-webkit-leftPIC5491F APR 14 OnStar(R) - System Will Not Power Up=-webkit-leftPI1221 APR 14 Body - Excessive Wind Noise From Front Door Glass Area=-webkit-leftPIP5168C APR 14 Engine - Crank But No Start=-webkit-leftPI1159C APR 14 Infotainment System - Various Issues/Concerns=-webkit-leftPI1187A APR 14 Mirrors - Interior Rearview Mirror is Loose=-webkit-leftPIT5272 APR 14 Body - Whistle Noise Heard Inside Vehicle While Driving=-webkit-leftPIT5274 APR 14 Lighting - Roof Beacon Lighting Harness Location=-webkit-leftPIP3343E APR 14 Engine - Oil Leaks in Extremely Cold Temperatures=-webkit-leftPIP5189 APR 14 Fuel System - Black Smoke On Cold Start=-webkit-leftPI1210 APR 14 Interior - Rattle From Front Floor Center Console=-webkit-leftPIC5978 MAR 14 Audio System - Favorites List Covers Menu Options=-webkit-leftPIT5241B MAR 14 Electrical - Adding Integrated Trailer brake Controller=-webkit-leftPI1201A MAR 14 Exhaust System - Buzz/Pop/Rattle or Whistle Noises=-webkit-leftPIT5161B MAR 14 Fuel System - Bump or Clunk After Stopping (Normal Condition)=-webkit-leftPIC5854B MAR 14 Audio System - HD Radio Signal Cuts In and Out=-webkit-leftPI1180A MAR 14 Antitheft - Intermittent No Start/Security Lamp ON/DTC's Set=-webkit-leftPIT5268 MAR 14 Audio System - Normal Operating Characteristics=-webkit-leftPIT5253A MAR 14 Ignition System - Intermittent No Start With DTC P1682=-webkit-leftPI1105A MAR 14 Electrical - Trailer Brake Controller Harness Information=-webkit-leftPI1174A MAR 14 Instruments - **** Ring Illumination Information=-webkit-leftPI0970A MAR 14 Body - Difficult to Engage Tonneau Cover Clamps=-webkit-leftPIT5964 MAR 14 OnStar(R) - Canadian Customers Unable to Make Calls in USA=-webkit-leftPIC5374C MAR 14 OnStar(R) - Off Route Message During Turn-By-Turn Operation=-webkit-leftPIC4801F MAR 14 OnStar(R) - Turn-By-Turn Feature Inoperative=-webkit-leftPI1183 FEB 14 Interior - Front Seat Lateral Movement or Clicking Noises=-webkit-leftPIC3011H FEB 14 OnStar(R) - Voice Recognition Operation Issues=-webkit-leftPI0737A FEB 14 Body - Rear Doors Intermittently Won't Open From Inside=-webkit-left09-03-10-016B FEB 14 Wheels - Preventing Chrome Clad Wheel Damage=-webkit-left12-03-10-002A FEB 14 Wheels/Tires - Vibration Felt Between 58-72 MPH=-webkit-leftPIC5968 FEB 14 Navigation - Normal Map View Changes During Operation=-webkit-left07-03-10-008D FEB 14 Tires - Mild Feathering Information=-webkit-left05-03-10-020E FEB 14 Tires - Nitrogen Gas Usage Information=-webkit-left08-03-10-006E FEB 14 Wheels/Tires - Tire Slowly Goes Flat on Aluminum Rim=-webkit-leftPIT5245A FEB 14 A/C - Blower Motor Noisy or Vibrates in Freezing Temps=-webkit-leftPIT4943C FEB 14 Emissions - EVAP DTC P0442 Diagnosis=-webkit-leftPIT5240B FEB 14 A/C/Interior - A/C, Seat Heater Operation During Remote Start=-webkit-leftPIT5233A FEB 14 Starting System - Difficult to Turn Key in Ignition=-webkit-left02-08-98-002E FEB 14 Body - Hem Flange Rust Repair Information/Procedure=-webkit-leftPI0360C FEB 14 Keyless Start - Inoperative Using OnStar(R) Remote Link=-webkit-leftPI0488D FEB 14 A/T - No Forward Engagement/Slipping=-webkit-leftPIT5238A FEB 14 Body - Accessory Tow Hook Installation Information=-webkit-leftPIT5252A FEB 14 Body Controls - Horn/Wipers/Hazard Flashers Stuck ON=-webkit-leftPIP5104A FEB 14 Engine - Cold Start Ticking Noise For Up To 50 Seconds=-webkit-leftPIP5179 FEB 14 Fuel System - Extended Cold Start Crank Times=-webkit-leftPIT5255 JAN 14 Body Controls - False DTC B263A SYM04=-webkit-leftPIP5176 JAN 14 Cooling System - Engine Runs Hot or Overheats=-webkit-left99-08-51-007F JAN 14 Wheels - Information Regarding Refinishing Aluminum Wheels=-webkit-leftPIT5244A JAN 14 Body - Tailgate Pop/Click/Snap When Opening=-webkit-leftPIT3227J JAN 14 Body - Tailgate Cable Slack=-webkit-leftPIC5161D JAN 14 Audio System - Normal Key OFF Operation=-webkit-leftPIT5248 JAN 14 Body Controls - Unable To Clear Chassis Control Module DTCs=-webkit-leftPIT5249 JAN 14 Brakes - New DOT 3 Brake Fluid=-webkit-leftPIP4670D JAN 14 Computers/Controls - Module Swapping Warning=-webkit-leftPIC5953 JAN 14 Cell Phone - Voice Recognition Issues Involving Emojis/Symbols=-webkit-leftPIP5092A JAN 14 Drivetrain - Driveline Noise/Vibration Diagnostic Aids=-webkit-leftPIT5247 JAN 14 Fuel System - E85 Fuel Capability=-webkit-leftPIT5195A JAN 14 Instruments - Speedometer Needle Accuracy=-webkit-leftPIT5245 JAN 14 A/C - Blower Motor Noisy or Vibrates=-webkit-leftPI1103A JAN 14 Memory Systems - Power Seat/Mirror Inoperative=-webkit-leftPI0281D JAN 14 Body - Under Body Corrosion=-webkit-leftPIP3140F JAN 14 Vehicle - Abnormal Noise/Vibration Due to Aftermarket Items=-webkit-leftPIT5229A JAN 14 A/C - Excessive Dust Intrusion Into Interior=-webkit-left01-07-30-042H JAN 14 A/T - 2-3 or 3-2 Shift Clunk Noise Information=-webkit-leftPI1150 JAN 14 Starting System - Clicking Noise From Rear of Engine=-webkit-left05-00-89-072C DEC 13 Fuel System, Engine - Fuel and Oil Additive Information=-webkit-left00-06-01-026E NOV 13 Engine - Inspection After Severe Internal Engine Damage=-webkit-leftPI0018B NOV 13 Body - Front/Rear Side Door Windows Bind/Noisy/Move Slowly=-webkit-left05-06-04-022J NOV 13 Fuel System - TOP TIER Gasoline Information (Canada)=-webkit-left04-06-04-047L NOV 13 Fuel System - TOP TIER Gasoline Information (US)=-webkit-left10-08-110-001A NOV 13 Interior - Proper Use of Floor Mats=-webkit-left06-08-51-005C OCT 13 Body - Hem Flange Sealer for Corrosion Protection=-webkit-left01-06-01-011H OCT 13 Engine - Oil Consumption Guidelines=-webkit-left00-03-10-002H OCT 13 Wheels - Chemical Staining on Chromed Aluminum Wheels=-webkit-left13-08-43-001 SEP 13 Wipers/Washers - Wiper Blade Identification=-webkit-left06-08-44-012G SEP 13 Navigation System - DVD Navigation Update Program=-webkit-left13-08-66-001 SEP 13 Body - Tailgate Hinge Lubrication Procedure=-webkit-left07-02-32-002N SEP 13 Steering - Power Steering Fluid Leaks=-webkit-left01-08-51-003D SEP 13 Body/Frame - Anti-Corrosion Material Application=-webkit-left10-08-44-006B SEP 13 Navigation System - Reporting Missing/Inaccurate Map Data=-webkit-left13-03-10-002 SEP 13 Wheels/Tires - Vibration Diagnostic Tips=-webkit-left06-06-01-010B AUG 13 Exhaust - Close-Coupled Converter and Engine Replacement Info=-webkit-left99-09-40-005G AUG 13 Restraints - Seat Belt Extender Availability=-webkit-left10-00-89-010C JUL 13 Locks - Key Code Security Rules, Applications (Canada)=-webkit-left13-00-89-008 JUL 13 Electrical - Wiring Repair Information=-webkit-left13-00-90-001 JUN 13 Engine - 2014 Model Year Engine Oil Information=-webkit-left09-00-89-029K JUN 13 Locks - Replacement Key, Key Cutting Procedure=-webkit-left05-09-40-002G JUN 13 Restraints - Normal Seat Belt Operating Characteristics=-webkit-left07-08-49-020H JUN 13 Instruments - Odometer Programming Quick Reference=-webkit-leftPI0011C MAY 13 Body - Door Latch Diagnostic Procedures=-webkit-left08-07-30-026B MAY 13 A/T - Slight Movement in PARK on Cold Start Up=-webkit-left11-00-90-001B MAY 13 Engine - dexos 1(R) and dexos 2(R) Oil Specs/Information=-webkit-left03-08-48-006I MAY 13 A/C - Window Defroster Contact/Tab Repair Information=-webkit-left09-06-04-026G MAR 13 Engine Controls - Non-GM Engine/Transmission Calibration ID=-webkit-left99-08-51-001C FEB 13 Body - Paint-less Dent Repair Process=-webkit-left10-08-45-001D FEB 13 Electrical - Ground Repair Information=-webkit-left06-08-43-003D FEB 13 Wipers/Washers - Windshield Wiper Performance
#68
Don't think you'all understand the scope of the issue.
#69
#70
At least my Corvette is a 2017.
#71
I am fortunate in that the sponsor/dealership for our local Corvette club does great work. They keep at least one Corvette specialist all time. They sell a ton of Vettes (for a medium size city), give great support for our club and go out of their way to make things right. I like to do my own 'wrench turning', however my age and health has prevented me form doing so, anymore. I use a non dealership to work on my C-5, because I have a friend that is extremely competent on earlier Vettes. My point is, not all dealerships are bad.
That said, the tech does not do the oil change. In 14 the first two oil changes on my car were done wrong. Over filled both times. Both times I gave the service writer the bulletin explaining the correct fill and procedure. After the second time wrong I got in touch with the General Manager and Service manager, they made it right. Gave me to complementary changes after that for my have to come twice to have it done right, I live over 50 miles away. Never had another issue with an Oil change on the 14, four more were done. No issue with the first change on the 2018.
The Corvette tech has always been good, and knows what he is doing. Never an issue with him.
#72
I didn't have a source for 2017's but doubt the number is a lot less. That source had the summary for all makes. They are similar! Most are no big deal! My September 2013 built C7 Z51 was an early build. Was back at the dealer twice in the 3 1/2 years I had it before it was sold! Once when GM said bring it in an have the "dif" oil level changed. I wanted as the newly trained C7 Tech let me come under the car while it was on the alignment, drive-on rack. It was fine and I found the place to install the skip shift elimination device! The second was when I had the software update for the seat belt recall issue. Great car, hope my 2017 Grand Sport is as good! (I do my own oil changes)
#73
True they do a good Corvette Tech. He has been very helpful.
First tell the Service Writer you want 9 quarts installed and be given the 10th. That will help two things, first that they will be using the Mobil 1 oil you request. In the discussion, ask and be confident they know what oil you expect and agree to provide it. That will also assure it's not overfilled.
Second, drive the car home and then follow the Owner's Manual of checking the oil level. It must be hot, >170 degrees, which it will be from the trip home. Then after 5 minutes of shutting the engine off (to allow oil to drain down from the tanks internal baffles) check the oil level. It's the level that is critical not some volume estimate. From my 5 year experience it will be about 1/4 quart above MIN and 3/4 quart below the MAX oil level.
BE SURE NOT TO WAIT MORE THAN 10 MINUTES AFTER SHUTTING THE ENGINE OFF TO CHECK THE LEVEL. Although it states that in the Owner's Manual it des not say why. That would allow excess oil to drain back to the oil pan and you'll get a low oil reading! In fact I would guess many certified C7 Techs will not take the time to get the oil hot and perform that level check.
Then with a funnel, pour from the quart they gave you and check the level until it is where you would like it. Some of us do not fill to the MAX level. You will have to start the engine for a few minutes and wait the 5 minutes again. The oil will still be hot.
You should understand how to check the oil level anyway as it's something you should do periodically. However even I don't do it at every gas fill as suggested in the Owner's Manual- it's not needed. But especially during break-in, it should be checked.
