Wheel Cleaner-To Use or Not to Use
Received 1,620 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Please let's NOT turn this into another brake pad argument thread, there are enough of those already!!!!
I use simple green on the rims just before washing the car. Just spray them and let soak while I get the foam cannon ready and then wash the car and rims with soap. I use a long sponge thing on a stick to get the barrel of the rims clean during washing.
Labmannn (01-25-2019)
hemistar1 (01-25-2019)
Best thing I have ever tried is Sonax wheel cleaner. Been using it for a couple years with no negative effects on the OEM black wheels. Amazon has it. Melts the dust right away with minimal effort.
They also have a plus version that I've tried with success as well.
A word to the wise on wheel cleaners.Read the back label well.Even the smallest almost hidden warning.I learned the hard way.
Alot of these cleaners show how easy the crap comes off.Some are a very caustic solution.Do you know what caustic does to plating.It simply, Bang removes it.
Caustic cleans that good.It will make Metal Rust.
Your 2 piece rotors with those nuts studs will be accelerated into rusting.
If your label sez..Don't use on motorcycle wheels? That is your key to stay away.
True Story:My 2nd Harley had spokes.Thinking what a PIA To remove the brake dust from spokes.Purchased a wheel cleaner.Read the instruction.Except for that one (most important)sentence:Not for Motorcycles.
Sprayed rims and while rinsing saw my spokes turn Black.Plating,Gone.
Called Eagle One,Teck line.Told him what happened.Sorry he said you removed the plating.It is on the back label,No Cycles
My mistake.Re-spoked both rims with about 1500 miles on the bike.
I believe some of your caliper hardware is plated also.I used Tough Stuff once.
My Nuts weren't Happy
Anything you use to clean your exterior, can be used on your Z51 wheels. I too have a set of black wheels and mine looked hazy and dull, even after a good cleaning. So I used Meguiars M205 Polish and the Mother's Cone sponge (for a drill) and it worked perfectly... Check out my before and after pictures:
BEFORE:
AFTER:
BEFORE:
AFTER:
I use the same car shampoo (Adams) that I use to wash the car body. I wash the wheels each time I wash the car. My GS with black wheels is my daily driver and for the most part I don't notice the brake dust.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Chrome should not have the same problem of painted wheels. My Black OEM wheels on my Z51 were pitting my wheels if I didn't the excess brake dust from the OEM brake pads off after ~2 trips to town, ~100 miles total. Real PIA!
I have been using Sonax for years.
DALE#3 (01-28-2019)
#35
There are lots of cleaners including the Sonax brand mentioned that will safely clean all types of rims After you have cleaned them apply a ceramic coating and you are golden Yes this coating CAN be applied to all types of rims. This brand is my favorite but there are others as well.
http://gyeonquartz.com/product/rim/
#36
However just to be safe I'll switch to something that approved for use on aluminum like the Meguiars mentioned above.
DALE#3 (01-28-2019)
#38
Back to Simple Green then? Normal driving brake dust isn't a big deal its the after track day, caked on, thick black layer that needs something stronger that foams up to help remove it.
#39
I don't bother with wheel cleaner anymore because it generally doesn't do a better job than generic auto soap and water.
BUT
There are a couple of companies making a spray to put on the wheels after they are clean to prevent brake dust build-up and they really are amazing.
I have used Armor-all wheel protectant and AUTOGLYM wheel protector with excellent results. Barley any brake dust sticks to the wheels after a quick spray on a clean wheel. Buddy of mine gave me a can of the armorall stuff and I was very skeptical so I didn't even try it for about a year and wished I had done so earlier.
Also, for all you guys complaining about the brake dust that's life with stock pads on a high performance car; my SRT is the same way.
BUT
