Daily driver
Old 02-09-2019, 02:13 PM
  #101
05Z51C6
CF Senior Member
05Z51C6's Avatar
My 14 z51 is my daily driver. When weather is bad (snow/ice) I'll work from home.
05Z51C6 is online now
Old 02-11-2019, 09:55 PM
  #102
boss2k
CF Senior Member
Why are these 2 paddle shifters in the manual C7, I know they turn on activate rev match feature but why 2 of them?
boss2k is offline
Old 02-11-2019, 11:01 PM
  #103
Matthewstorm
CF Senior Member
Matthewstorm's Avatar
One for righties, one for lefties.
Matthewstorm is offline
The Following User Says Thank You to Matthewstorm For This Useful Post:
boss2k (02-12-2019)
Old 02-11-2019, 11:09 PM
  #104
owc6
CF Senior Member
owc6's Avatar
owc6 is online now
Old 02-11-2019, 11:28 PM
  #105
boss2k
CF Senior Member
Really, they both do the same function, I thought one is to turn on and other is to turn off
boss2k is offline
Old 02-11-2019, 11:30 PM
  #106
owc6
CF Senior Member
owc6's Avatar
Dang, am I about to become the bad guy?
owc6 is online now
Old 02-12-2019, 12:48 PM
  #107
krwunlv
CF Senior Member
I dont DD my car, only bc of snow and ice, I have a 2001 4Runner for that. However, for those grocery runs, short weekend trips and such this helps.
Rola trunk organizer, but air this puppy out for a while before putting it in the car.
Amazon Amazon
Ken
krwunlv is offline
Old 02-13-2019, 12:45 AM
  #108
1776DAVE
CF Senior Member
Started with 4 miles on my 2016 Z51 now have 37000 showing I drive everyday and take on road trips. love driving it it holds up great good gas mileage yes driving everyday and parking you are liable to get more door marks
Yes if some one parks close it was hard to get in and out of it ... SO I instaled a vertical door kit from dream car customs and now have all the opening and clearence to get my feet in and out of the car plus I get lots of admirers when the door goes up... but yes door dings do happen.. I've had to have mine repaired once already but it's worth it why put the things in a garage and treat like art work ? driving like they're meant to be driven yes! 37000 smiles on my Z51 right now...
loving every minute of it!!!
1776DAVE is offline
The Following User Says Thank You to 1776DAVE For This Useful Post:
boss2k (02-13-2019)
Old 02-13-2019, 12:46 AM
  #109
Matthewstorm
CF Senior Member
Nope, wax on, wax off, both paddles.
boss2k (02-13-2019)
Old 02-13-2019, 10:18 AM
  #110
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
I bought mine to DD then started making it into another trackday car and find myself shopping C5 verts as an actual DD. Going to be very keen to see what the C8 brings.
Tool Hoarder is offline
The Following User Says Thank You to Tool Hoarder For This Useful Post:
boss2k (02-13-2019)
Old 02-16-2019, 08:57 PM
  #111
boss2k
CF Senior Member
One quick question, is getting in and out a big pain, I am told to put *** in first and then legs, now I never owned a sports car before so wondering if this will be an issue as I always owned sedans, will I get used to it fast?
boss2k is offline
Old 02-16-2019, 09:31 PM
  #112
Evan70
CF Senior Member
Evan70's Avatar
It’s a low slung sports car with bolstered seats, it’s certainly harder to get in and out of than family sedan, but it’s not horrible. You want hard to get in/out of, that’s my 91 C4 ZR-1. I actually think the C6 was easier than the C7, but I’ve got sport seats in my 2015, which have bigger bolsters.
Evan70 is offline
The Following User Says Thank You to Evan70 For This Useful Post:
boss2k (02-19-2019)
Old 02-16-2019, 09:47 PM
  #113
Jmhornz71
CF Senior Member
Jmhornz71's Avatar
My first Vette was an 88 C4 Im sure there were plenty of laughs watching me learning to get in and out of it. When I got the 96 I was much better and it was easy. The C6 was a breeze and I find he C7 just as easy most of the time I sit in the seat then swing my legs in
Jmhornz71 is offline
The Following User Says Thank You to Jmhornz71 For This Useful Post:
boss2k (02-19-2019)
Old 02-18-2019, 04:32 PM
  #114
acroy
CF Senior Member
acroy's Avatar
I stick in a leg, plant my butt, swing in the other leg. I'm 6'3". I don't want to rotate/grind on the seat surface, tear up the bolster, etc. Good to experiment. My C5 is also a bit lower than a stock height C7.
acroy is offline
The Following User Says Thank You to acroy For This Useful Post:
boss2k (02-19-2019)
Old 02-18-2019, 07:26 PM
  #115
pnsnkr
CF Senior Member
pnsnkr's Avatar
I've enabled the 'easy exit' feature. With this, the seat is as far back as possible and the steering column is all the way tucked in. Even with this, I try to plant my butt all the way to the front as possible so the lumbar support isn't in the way of my hips when I pivot and swing my legs into the car.
pnsnkr is offline
The Following User Says Thank You to pnsnkr For This Useful Post:
boss2k (02-19-2019)
Old 02-19-2019, 05:54 AM
  #116
cowboy casey
CF Senior Member
cowboy casey's Avatar
AT 6'2" I do the same exact thing to get in
cowboy casey is offline
The Following User Says Thank You to cowboy casey For This Useful Post:
boss2k (02-19-2019)
Old 02-19-2019, 09:57 AM
  #117
Tool Hoarder
CF Senior Member
6'3" here as well... do the same. Step in with right foot, sit down/in, then pick up left leg/foot. Try not to rotate/grind on the seat as that's what wears them out fast. The C7 is tighter only because the left side of the dash wraps around more and has that point because they left the HVAC vent in the dash, vs. the C5 which had it in the door panel.
boss2k (02-19-2019)
Old 02-19-2019, 10:06 PM
  #118
boss2k
CF Senior Member
any special steps to get out
boss2k is offline
Old 02-20-2019, 05:02 AM
  #119
Kevin A Jones
CF Senior Member
Support Corvetteforum!
Kevin A Jones's Avatar
I'm 5'-9" and fairly athletic/flexible and still find the C7 a real pain in the *** to enter/exit especially if you want to do so to avoid scuffing up your side bolster. I've often wondered how very tall, overweight and/or owners with leg/joint/back issues put up with getting in/out of a C7 every day.
On the flip side, once you get in they are very comfortable and extremely pleasing to drive, but glad I have other daily drivers so I can reserve my C7 for only when I really want to drive an amazing and exhilarating sportscar.
Kevin A Jones is offline
The Following User Says Thank You to Kevin A Jones For This Useful Post:
boss2k (02-21-2019)
Old 02-20-2019, 06:53 AM
  #120
Billy346
CF Senior Member
Billy346's Avatar
I am an electrician and an estimator for my company. (I'm one of the owners and estimating is one of my many responsibilities.) My work vehicle has to be more "tool friendly" and also something that doesn't make my customers think that I "charge too much".
The Vette is nice for weekends or weekdays when I'm not in front of customers. Since my primary work vehicle (a Prius) is like my office, it's nice to have something else to drive on the weekend that I enjoy.
Billy346 is offline
The Following User Says Thank You to Billy346 For This Useful Post:
boss2k (02-21-2019)
Quick Reply: Daily driver
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
