Shudder after new flush
Anyone experience this yet?
RWCARR (02-06-2019)
I had my GS flushed due to shudder issues in November. It was fine for the first 200-300- miles but now I'm experience the shudder issue again.
There are several threads about A8 problems and the solutions , to include the flush. If I'm remembering correctly one of those threads mentioned that there is a new tranny fluid and flush procedure (yes, another one) that was supposed to be available starting in January. You might want to check on it.
RWCARR (02-06-2019)
Couple from the Z06 Forum:
https://www.corvetteforum.com/forums...x-shudder.html
https://www.corvetteforum.com/forums...er-update.html
I had mine flushed last week with the new procedure and fluid and NO shudder yet but I have only put about 50 miles on it. When I had it flushed a few months ago the shudder came back right away and was just as bad as before. My dealer did say that if the shudder returns after the new procedure and fluid flush they would flush it again to solve the problem.
I have attached the NEW TSB for those that want to see what is involved. Make sure and see the directions that apply to the Corvette as the TSB has directions for many cars. I had to break the TSB into two parts as the file was too big to post as one, the Corvette directions are toward the end of part 2.
John
John
I too had my 17 Stingray done with the new bulletin procedure last week. I only put 46 miles on it and it seems good. The dealer did mention that it can take up to 200 miles of driving before the shudder goes completely away, mine seems to shift a little smoother and no shudder as of yet but still have to rack up some miles. I hope this takes care of the problem. I heard a rumor out there that there maybe another revised bulletin to the latest one 18-NA-355 coming in the first or second quarter of 2019. Wow from the constant threads out there about this issue and the class action suit is very concerning. Good luck to everyone out there!
VNAMVET (02-07-2019)
Had the new flush done on mine and for now its quit. My expectations are really low with this new bandaid tho.
The new flush worked for a while; but shudder came back. GM can flush the toilet with this new flush!
speed4tu (02-08-2019)
John
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Are you driving in V4? This seems to exacerbate the shudder. My flush was done about 2K miles ago. Use a Range all the time. No shudder so far.
Yes / Range always. Iam sure the dealer will do it again.
Yes. 60 - 80 mph, Range on; in auto or manual mode.
Those symptoms seem unusual for a TCC problem. I would suggest looking at other causes of a shudder effect just in case......
(Good road force tire balance; check for bent rims; check for wheel runout on the car to look for rotor spindle wobble, etc)
especially in manual with a Range...
