2014 Z51 swap to Z06 grille confirmation
Old 02-08-2019, 07:43 PM
z06kidd
z06kidd's Avatar
Default 2014 Z51 swap to Z06 grille confirmation
ok so before I buy this grille. I just want a little confirmation. I have a 2014 Z51 and wanting to swap to the Z06 grille with no cameras. Im seeing the grille on ebay for around $100 vs on gmparts direct for $250. Is there really a difference? They really look the same but im sure the grille on ebay quality isn't as great as the gmparts direct. Just curious to see if there are any people who bought off ebay as well. Im thinking just ordering from gm parts direct just to be on the safe side.
https://www.gmpartsdirect.com/oem-pa...amera-84115258
https://www.ebay.com/itm/For-14-Up-C...Mdd:rk:12:pf:0
Old 02-08-2019, 11:59 PM
Steve Garrett
Support Corvetteforum!
Steve Garrett's Avatar
Received 7,751 Likes on 4,181 Posts
CORVETTE TODAY Host
St. Jude Donor'15
Should be the same. I bought my Z06 grill off of Ebay for $250.
Old 02-09-2019, 04:47 AM
cowboy casey
cowboy casey's Avatar
Mine was from ebay Looks perfect
Old 02-10-2019, 12:20 PM
Pete43
Pete43's Avatar
I just ordered the Ebay Z06 grill. I couldn't find any bad reviews. Only a few good reviews. Hope the paint is good on the grill.
Old 02-10-2019, 02:48 PM
James Dean
James Dean's Avatar
Going to be doing the same here with the $100 Z06 grill while my Corvette is getting work done
Old 02-14-2019, 08:07 PM
Dakynz
Dakynz's Avatar
you installing yourself or having someone perform. Once you buy, look up how to remove the front nose. Its got some funny alignment bolts behind the lights that can be frustrating on some to detach.
Pete43 (03-07-2019)
Old 03-07-2019, 08:01 PM
Pete43
Pete43's Avatar
Just finished installing my $100 Ebay Z06 grill. I found the 2 -7mm bolts on either sides of the headlights. (tough to find and reach) Took a little over 2 hrs to remove the cover and install the grill. Only took about 45mins to re-install the cover. It looks great and it lined up fine around the headlights and fenders!
Old 03-07-2019, 08:14 PM
Avanti
Avanti's Avatar
Received 5,187 Likes on 3,439 Posts
I, too, looked at this until I saw how to do it. I know it's certainly doable, but i know, as well, that plastic crap is all made to be put together ONCE and not repeatedly, I decided to live with my all black original. Okay, I'm an old wimp...
Old 03-07-2019, 11:11 PM
Matthewstorm
Matthewstorm's Avatar
You never said how the grill worked out for you. Was it good quality?
Old 03-07-2019, 11:22 PM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Would be great if the OP gave some feedback on how the grille was in terms of fit, finish and ease of install.
Old 03-17-2019, 10:23 AM
Pete43
Pete43's Avatar
Default Z06 grill
Just thought i would say that my $100 Ebay grill fit perfect. It was an ABS material I think. It was wrote on the inside. Not sure what the $250 grill is made of for comparison. The Carbon Flash paint looks fine. No chips or cracks...(so far).. It looks awesome on my torch red Z-51.
Old 03-17-2019, 10:47 AM
Matthewstorm
How much is involved in the installation? Thanks.
Old 03-17-2019, 10:57 AM
cstapp99
cstapp99's Avatar
I bought the ebay Z06 grille and installed myself. It was a bit of a PIA, but I was very happy with the end result when finished. There are videos here about how to do the nose removal and reinstall. Do a quick search.
Old 03-17-2019, 11:22 AM
Pete43
Pete43's Avatar
Default Z06 grill
Youtube has a lot of grill, how to , video's. All the bolts were easy to take out , except the 2, 7mm bolts that hold the bumper cover tabs at each of the headlights. You have to go through the fender wells to get to them. But all you do is loosen them and the bumper cover lifts upward easy.
From my other post: I found the 2 -7mm bolts on either sides of the headlights. (tough to find and reach) Took a little over 2 hrs to remove the cover and install the grill. Only took about 45mins to re-install the cover. It looks great and it lined up fine around the headlights and fenders!
Old 03-17-2019, 02:41 PM
JT Corvette
JT Corvette's Avatar
i keep going back and forth on doing this..same with the rear spoiler install since i gotta pull the bumpers
Old 03-18-2019, 02:17 PM
ExtremeOnlineStore
Supporting Vendor
ExtremeOnlineStore's Avatar
https://extremeonlinestore.com/colle...7/bumper-grill
Old 03-21-2019, 09:22 AM
Woodson
Woodson's Avatar
Received 1,356 Likes on 784 Posts
Originally Posted by ExtremeOnlineStore
Who do you use for international shipping? I'm in if it's not UPS.
To 2014 Z51 swap to Z06 grille confirmation
Old 03-21-2019, 01:55 PM
ExtremeOnlineStore
Supporting Vendor
Originally Posted by woodson
who do you use for international shipping? I'm in if it's not ups.
usps
Old 03-21-2019, 02:14 PM
Woodson
Woodson's Avatar
Thanks, placing order now.
Old 03-21-2019, 04:47 PM
Woodson
Woodson's Avatar
Wow $70.00 shipping to Canada. Placed order anyway. Thanks.
Quick Reply: 2014 Z51 swap to Z06 grille confirmation
