Mice in the car
Mice in the car
I purchased a beautiful 2016 Z06 this past November drove it once and put it up for the winter in my garage (I live in NH). I put Irish Spring soap chunks zip tied inside dryer sheets on top of each tire and inside the car on the floor mats as mouse repellent. Yesterday I noticed one of the dryer sheets was lying on the garage floor under the car but there was no soap. So I pulled the cover off and checked inside the car. Sure enough those little bastards had gotten inside the car and ate the soap on the floor mats too and left some droppings. So then I popped the hood and sitting right on top of the engine cover was a big chunk of Irish Spring covered in chew marks along with some acorn shells. Upon closer inspection with a flash light I also found a nest right up against the firewall. The nest was mostly made up of some blue cotton like material. Those little bastards actually chewed through the dryer sheets to get to the Irish Spring and then brought a chunk of it "home" with them right next to their nest under the hood. Luckily I didn't spot any visible damage to the car besides some corrosion on the engine cover from their ****. Although I wont know for sure until I take her for a drive in the spring. Now I'm debating whether or not I should actively try and trap them. I don't like the idea of providing any kind of food source near the car even if its a bit of peanut butter on a trap.
By all means trap them. They can do more damage than you think. I had one car that when I turned on the blower in the spring the inside of the car became covered with bird seed that they had brought into the garage and stored in the car.
Been dealing with car winter storage for a number of years. I've tried a lot of different methods at first, trying to stay away from poison. When I finally started using Dcon, it was effective but discouraging to find that it takes awhile before being effective. I've found it scattered about in my engine compartment and in my car. I finally started using sticky traps. I put them at every wheel and at the lowest points (mice can jump). I also put them near any access points to/from the garage. This has been the best solution so far. Good luck, I feel your pain..
Trapping is almost a must do, in combination with any type of repellent you might want to try. Been there done that. Ended up using our regular exterminator company's bait stations outside, traps and repellent inside.
Take a look at "mouse magic". Several members reported good results during the C6 years. Good luck.
Fresh Cab works. Can get it at a local farm supply store, online, or possibly Walmart. I put a pack on front drivers and passenger floor, one in the hatch, and 2 on the engine. Haven't had a mouse problem using it. Last winter couldn't get it so used dryer sheets. End up costing $$$$$ to take the dash apart and clean up the mess.
Jibber82 (02-12-2019)
We had this same problem with a travel trailer we had. We used the Irish Spring, laser lights, strip lights, virtually everything we could think of. Then finally I found an electronic mouse trap in Ace hardware, and that was the end of the problem. It's a little pricey at about $44.00, but it works. it's blue in color, about a foot long, and about 4 inches high. Put dry bait way in the back, and when 'the little bastard' goes to get it, he steps across 2 metal plates and it electrocutes him. Just dump him in the trash, reset the button, and it's good to go for his little sister. Takes 4 aa batteries. Good luck. PS it lays on the ground OUTSIDE the car!!
Received 2,639 Likes
Jibber, I have one suggestion until you rid yourself of the vermin. Raise your hood when you park the car. I had those aggravating creatures chew up the hood liner to build their nest in my car. The little bastards built their nest on the cabin air filter. Good luck.
Better than, “...rats in the kitchen, what I’m goin do...”
I agree, try to trap them.
Your lucky if they are mice. Compared to the roof rats in my area mice are stupid and easy to catch.
I have been trying to get this guy for a couple weeks. He set off 2 traps before this one got him. 4 traps are set by each wheel baited with cat food.
We had a c-5 a few years ago. Wife came home saying the car smelled like burnt garbage, when it got hot. I could smell it coming from the exhaust, I took it out ran it up to a 100 a couple of times, watched the rear view, little hard pieces of dog food was flying out the back. They had packed the mufflers full of dog food. That cleaned it out, I put traps on the floor boards, engine compartment, and trunk. It was a roadster. And put empty soup cans over the tail pipes when it was parked. They will eat the insulation off of the enjectors, make nest out of the interior, **** and **** everywhere. We also got a mouse hunter a big *** cat. Problem solved. If you find one there will be more real quick they reproduce faster than a rabbit! And are able to reproduce at only a couple of months old.
If you have rodents in your cars, they will be all over your property. My suggestion is hire a pest control to deal with them if you don’t get them all they will be back, no if ands or butts. It’s not just a one time kill, they have to be terminated. Even after you see no more signs of them, keep treating for at least a month, or you will not kill the off spring.
Anyone make use of a CarCapsule (http://carcapsule.com/indoor-carcapsule/) with feedback regarding mice?
The following 2 users liked this post by MiamiCowboy:
DeutschZ06 (02-15-2019),
Majorhavok (02-12-2019)
Received 2,368 Likes
Rat Safari
Pack rats have been around for a million years or more. And we have been trying to kill them off for that long. Truth, they are the ultimate survivors. If bait is not your deal, then traps are not going to work. In our garage, I have Gopher Mix in make shift containers in each corner. Gopher Mix is pelletized grain laced with either arsenic or cyanide. Upside kills them pronto fast. Downside kills cats dogs and kids too. We don't have any of those so I'm good to go. You'll need to find a farm store or similar to buy gopher mix. Used by ranchers, farmers etc pour it into field holes to keep rodent excavation to a minimum. They will eat up to the surface and be DOA.
I recycle 32 oz cottage cheese plastic containers. Any kind of plastic container will work. Rinse out the tub. First cut away half the lid inside the snap on rim. You'll have a half moon opening. Install the lid then duct tape the lid to the container to secure it. Wily to the max, they like the security of sticking there nose in without getting in. Put a small rock or similar in the container to keep if from rolling around. If you want to get fancy, before taping on the lid nail or glue the tub to a foot long piece of 2x4. This provides the stability Then put the lid on. Add a cup or so of gopher mix. Doesn't take much. One pellet will kill them. I put them in inaccessible nooks in all the corners and under the car in the back. Opening down. But places I can get to with a modicum of effort. Every couple of months, I check them and refill as needed. Rats will die before getting back to their nest. You'll find them on the floor, often around the garage door, under the car. Merciless but the rats are winning so I play for keeps.
Got dogs, cats, little kids, there is a real risk to using cyanide. I'd bite the bullet on food baits and get a Rat Zapper Brand electronic trap at amazon. Uses a couple of kibbles of dry dog food and D cell batteries for frying juice. They die in situ so no hunting smelly corpses. A blinking light tells you when you got a dead body. Expensive, but easy to place and easy to monitor.
Good hunting.
Good hunting.
I have been using them since 2014. No problem with mice or anything else getting in. Just make sure to keep the filter on the intake fan or you will pull a bit of dust inside. Also put windows down a few inches to stop humidity.
I don't like the idea of providing any kind of food source near the car even if its a bit of peanut butter on a trap.[/QUOTE]
Sounds like you are feeding them Irish Spring!
