Least expensive way to break into my car?
#181
Did you know there was a recall for the "Mechanical Trunk Release May Not Operate" Issue? See attached link.
https://www.corvetteactioncenter.com...ile.php?id=137
#182
??? How do they fix a mechanical problem with the release by reprogramming the liftgate control module? Doesn't seem to make any sense.
#183
FWIW I have a Deltron battery tender, and use the connections under the hood. In viewing the pics of the OP's car location in his garage, I would think the under hood connections would be advisable.
#184
I think the closing/latching mechanism may pull the trunk lid closed too tight (or too loose) and that keeps the key from working. I think the software change adjusts the tension on the closing/latching mechanism.
