Least expensive way to break into my car?
#42
Subscribed
#44
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
You need jacking pucks, hope your guy knows that
#50
Here is the lifting points for the C7
https://extremeonlinestore.com/blogs...ur-c7-corvette
The number 3 Red is where you need a block or puck to lift without damaging the skirts
#51
Holy crap I hate all the electronics in modern cars. This shouldn't be happening.
For the record though, 12v applied to the starter batt post is a winner.
#52
Used those many times, hopefully he'll never need them. They do have all types of floor jacks, struts, air bags for lifting cars, trains and buses. Like I said earlier... I would've been in there, either through the window if the power locks worked, or jumping it.
beaversstonehaven (02-18-2019)
#54
So if you can get the rear hatch open on a dead C7, you climb into the trunk then you crawl thru the car to get to the hood release? If that's the case, I'd sell the POS. Please tell me that's not true.
#56
Moderator
Why do you want to get to the hood release? The battery is in the rear compartment on the C7. When you open the rear hatch, there is a small pull cable on the driver's side wheel well cover to open the door manually. Then you can pull the hood release.
Jmhornz71 (02-16-2019)
#57
Have you read the owners manual or own a C7 the battery is at the right rear corner of the under the hatch plus there is a a cable to pull that would open the door to get access to the hood release for whatever reason
#59
#60
Although, over the years, both C6 and C7 forums have had plenty of people who have done this and then posted about it. lol
