Range Finder and smog check
16 Vettes and counting…..
Word of warning: Took my '17 GS in for the annual smog check today. I pulled the Range Finder off the OBDII port about a mile from the test station. Big mistake. The test was rejected because, according to the guy, the computer must have been recently reset and it needed more miles to get a reading for fuel and oxygen. He said to drive it about 30 miles or so. I guess I'll try again next week. Don't make the same stupid mistake I did.
You do need to unplug the Range device a day or two prior to emissions checks. Last week ONSTAR tried to email the status of the Vette and it said that it could not send a status because an aftermarket device was plugged in the OBD II port. Tough Sh*t.
It hasn't interfered with my Onstar reports. Neither has the DSC controller.
I don't have Range, but I do have SmartTop, which as a device plugged into the OBD full time. I haven't had any problems with OnStar communications.
I'm in NY as well. I have a Range plugged in on my Silverado. Last year I forgot to unplug it and within a week it killed my battery (I've since added a switch to turn it off when I shut the truck off). When I went for my inspection the truck failed. The tech said it was because of the battery going flat and just needed more mileage cycles to reset the monitors, which I thought was weird as I'd driven it home from Florida after jump starting it! I didn't tell them about the Range, but I bought a code reader, cleared the codes and a week later the truck passed. So, while it's still a bit of a mystery to me it doesn't appear that the Range itself created issues, but the dead battery did.
the problem is you have a Range Finder plugged into the OBDII port instead of the Range AFM device.... problem solved.
Ha!! Don’t I feel stupid.
