Tire ?? Cold, NY What would the experts do?
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
OK,
Here is my question. I am going to head out for Sebring tomorrow with my 2018 Grand Sport (Pilot super sport tires). I live in upstate NY where the temp tomorrow will be like 10 - 15 degrees, no snow so thats good. The car will be in a heated garage overnight. Obviously, once on the road for several hours the outside temp will be increasing going south. I have heard that the tires should not be used in the really cold weather. What do you guys think I should do. The tires will be warm from the garage right off. I don't know, give me some feedback if you would. Thanks
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I wouldn't
The following 2 users liked this post by KenHorse:
Avanti (03-05-2019),
vdavenp802 (03-05-2019)
Had a C6 Z06 and now a C7 with those type tires. IF you just have to go out, drive like you got a state trooper behind you that hates your guts and wants to give you about a 100 tickets.
I live in the Southern Adirondacks and had the cars out in cold weather BE EXCEEDINGLY CAREFUL, car can get slippery real fast. Also put in in the bad weather mode with the console switch.
good luck-
good luck-
I'd second not doing this - and I wouldn't with PSS tires. The weather might be good now, but what about the return trip home?
You should make it, but taking another car would be a much wiser choice.
The temperatures you are suggesting are well below the glass point of the tires and they will behave as if oiled.
OK,
tires might be warm, at least for a while, but the ground wont. the tires on your car just arent for those conditions, you need some kind of badass all season tire. just square yourself with the fact that based on where you live, you might not get all the juice out of it that you could and would if you were in SoCal or texas or something.
OP - unless you track your car, consider getting A/S for it.
Received 5,213 Likes
Many posts here that reference and/or reproduce the correct page in your Manual.
I've done it for many years, with no issues. I'm sure you won't be the only performance car on the road. Enjoy the ride.
Formula 1
Guess I m more belt and suspenders guy. I wouldn’t do it. Tires are to operate in temps at least 40 degrees.
If if rains, gets windy, or worse, you’ll be over the road, no less increased stopping distances. If was only for a very short distance - maybe.
If was me, would change to at least all season tires.
OK,
OK,
I was on the way back from Austin to So. MD. I was chasing between storms. I started out from Augusta on my last leg ~600 mi, in the wee hours of the morning before more severe cold came in. 23 degrees F when I left the hotel. It was a bit squirrelly heading out from the hotel (where the car was outside, so the tires were 23 deg). I put it in W, and was very ginger with it, especially getting onto the freeway. It took about 20 minutes before the tires really felt right, but after that, it was fine. I drove through Columbia, SC where the snow was on the ground, and a bit on the road. The tires felt fine. The temps dropped as the front came in and by the time I got to the 95 corridor, it was 9 deg F. Needless to say, I only stopped long enough to pee or gas up, not both at the same time.
As I worked my way back north, the temps rose, but there was blowing snow in VA. Got to Md in sunny conditions, in the low 30s, just in time for a late lunch. Good thing because I was starving and I had to pee again.
My tires did not peel off, nor did they crack.
Received 8,928 Likes
Starting out in a warm garage and getting on the road asap there won't be any issue with those tires as they will maintain their temperature. You need to get up to speed (70 mph) asap and keep speed up until the ambient temps get to about 20 degrees. Higher speeds generate more tire heat and help them keep them warm. Other than that you shouldn't have an issue. The Cup2 tire is the one that shouldn't be driven or stored in temps below 21 degrees. Use the throttle gently and you won't have any problem. No different than driving any other car in low grip situations NO SUDDEN CHANGES in throttle, brakes or steering. The Word Is SMOOOOOOTH.
Here is a link to the Michelin Owner's Manual that doesn't mention anything about damage caused by driving in low temps.
https://www.michelinman.com/img/stor...6_REV_0716.pdf
Bill
Bill
good luck-
good luck-
Put it in Winter mode and don't hit the gas hard or brake hard.
Everyone on the roads around you only have worn out bald tires and they make it everyday, so you will be OK.
I love my AS3+. Best tires for the Vette in any weather.
OK,
When I was a kid I thought I lived in upstate NY (Rockland County NY ) it was only after my first snowmobiling trip to Old forge NY did I realize I lived in southern NY and was considered an uppity city folk to the real upstate people
Aint this a kick in the nuts, New car and cant drive it in the cold. I have a 2018 and its up on my lift in a garage since October till April . Looking forward to wearing out the stock tires and getting a new set that I can use if I chose to in the cooler weather.
