How to remove hard water spots
Hello fello corvette enthusiast I am a new corvette owner and like to keep my stuff sharp.After washing my car I hand dry it but I still get water spots.What is the secret to getting them out,They show up prettye bad.I wax often but even then they are still present and really tuff to get out,Any Ideas?is there something I can buy that will help with out ruining my paint?I spent big dollars for a water softner system installed for my house it helps but I still have spots.
C7 of Year Finalist (performance mods) 2019
Couple of tips to prevent them:
Try washing in the shade or cooler temps
Use a pH neutral soap. I like Adams.
Use a drying aid like a detail spray or Beadmaker.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
SOMETIMES, all it takes is to clay bar the car.
Other times, you need to be more aggressive and polish the car (machine polishing is the easiest)
Art17 (03-19-2019)
owc6 (03-18-2019)
They're emulsified with a dose of detail spray or wax and polishing with a detailer towel.
Had the same issue a few years back... Got the same general answers that are in this thread so far...I don't know about you, but I didn't have a clay bar nor did I want to put in the elbow grease or risk scratches using a machine...Here's what you can do for a few bucks and surprisingly, it actually works:
1) Wet the glass
2) Wet a sponge and put Bon Ami (found in any supermarket for $1.29 or less) on the sponge
3) Wet the sponge some more so the Bon Ami dissolves into it
4) Make small circular swirls with the Bon Ami covered sponge all over your glass
5) Wash glass and rinse thoroughly.
Ta-daa...water spots are gone.
1) Wet the glass
Received 5,204 Likes
I use an inline filter on my hose when I wash the black C7. It's the only one of my vehicles it's a visible issue for. It doesn't take an expensive filter. I got mine from amazon though I don't recall the name and I'm not at my shop to check. That and a clay bar of your choice to get it clean to begin with--then, filtered water. Also, Maquiars makes a kit for glass that includes a cleaner and sealer. It can take multiple applications of the cleaner and a lot of rubbing but the result is worth it, imho.
All the best.
All the best.
I think he he was talking about the paint....
1) Wet the glass
1) Wet the glass
There are lots of products that will remove water spots but the bigger issue is you need to change your washing technique to prevent them from happening at all. I have no idea what your process is so it's very hard to help you. With a little more information perhaps we can get you better suggestions and help you out. What soap do you use, are you in the shade, do you use a drying agent, what type of towels, etc etc etc
I am in the shade and have tried several brands of car wash soap.I had a top of the line hard water filter system installed to my water supply in my new home.Did a lot of research on the systems offered .The system I installed was $3500.00 it works real well my outside faucets are plumed through it as well.The biggest problem is in this part of the world Kennewick Washington it is well known for hard water.I am on a well and I hand dry my cars as soon as I am done that helps a lot with minimizing but I still have spotting,I googled how to remove water spots from your car and one of the tricks was to use white viniger and water mix,But that also removes wax and they recommend to apply a new coat of wax that's a lot of work if your washing a1 time a week.Thanks again I am going to try the H20 ordered some from amazon let you know how it works out.I dry my car with clean shami as well.
Thanks for the ideas fellas!
I like to wash the roof, hood, trunk lid, and the side doors to the level of the door handles then dry. Then wash the drivers side from where I left off to the bottom of the panels then dry. Then wash the passenger side from where I left off to the bottom of the panels then dry. Then I was the front end and dry. Then I was the rear of the car and then dry. Lastly I was the rims and tires and then dry. ( Some wash the rims first) I use this method because noting ever has the chance to dry before I get it to it.
If you are washing the entire vehicle and then trying to come back and dry it without a drying aid before it dries on its own, you are likely causing your own water spotting. Especially with a Chamois. Your challenge now is to remove the existing water spots which may only be accomplished via compound and polishing then reapplying a sealant and /or wax. Good luck.
Received 1,400 Likes
I used to have them until i started doing the wheels first, then the car, then drying immediately.
Your set-up looks like mine, the CR spotless next to the lift and the METRO Blaster/ Vacuum on the wall. I have three black vehicles, so I'm always ordering more resin LOL. One thing I did do is plumb a bypass, so I can leave the CR hooked up to the hose reel in the garage.
