DSCsport Skeen and the mighty ZR1 set Street car lap 1:34 at Barber
Former Vendor
DSCsport Skeen and the mighty ZR1 set Street car lap 1:34 at BarberDSCsport was at Barber testing five GT3 cars for the upcoming IMSA race also in the group was a new ZR1. We just finished properly aligning the car and complimenting the alignment with a DSC controller to tune chassis. ride height is stock and all components on the chassis and driveline is completely stock. even the alignment is close to stock. -1.8 camber front -1.4 camber rear toe front toe in .5mm per corner caster front 7.5 rear toe 1.7mm per corner caster .75 positive. alot of detail was paid to ensuring the setup surface is perfectly level drivers wt in the car tires at 30psi
The Results car puts down power like mad no drama New Track record for a stock car at Barber set By ZR1 DSCsport Mike Skeen tires were on the cord we revised the DSC mapping lightly and adding new tires next
https://www.youtube.com/watch?v=EwRW...ature=youtu.be
Foosh (03-27-2019)
Congrats, Mike!
Can you please confirm the front and rear toe specs.
The front is set to; toe in .5mm per corner
The Rear is set to; toe in 1.7mm per corner
