Oil change with Dry Sump
#41
https://video.search.yahoo.com/yhs/s...9&action=click
#42
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
All I know is that I've probably changed oil and filters 100 times on various vehicles over the years without using a torque wrench and have never had as much as a drop of leakage from a drain plug or a filter or have never had any problem removing them so I'm not about to start torquing them now..
The drain plugs also have a rubber seal and IMO “feel “ is a good way to tighten it! I use a two step tightening process with a torque wrench for my wheels. I tightened the head bolts, on the 502 cid engine I assembled for my Street Rod etc. But for some bolts “feel” is fine if you have some experiance.
Kevin A Jones (04-18-2019)
#43
Here is a video that will help you understand how to overcome the offset issue when using a crowfoot with a torque wrench.
#44
I've been looking for an excuse to buy a set of crow's feet wrenches and this looks like my cue, as my free oil changes are up and I'll be DIY starting with my next change about next January. Don't need them often but when you do it may be the only option that'll work. If would appear a flare-nut variety would be preferable for this application and all others involving a typical hex bolt or nut, and don't see any situation where the square type would work better. Any advice on this?
#46
#47
A
You ask for advice. Kevin Jones in post #24 shows a wrench to buy or consider the simple 6 sided box wrench I suggested.
However, I have often bought a wrench set for one specific need because I can justify it in my mind! Any rational to buy a wrench- like my wife and shoes! However I tried my flare nut 15 mm wrench and it was rounding the OEM drain plug hex as was my 12 point 15 mm box wrench. In fairness, most of my wrenches are Craftsman, but that metric flare nut set were cheap. If you’re going to buy the set, get quality.
#48
I don't want or need to understand it, as we've said use your torque if you like just stop trying to convince everyone it's needed for oil plugs and oil filters. I've use a torque wrench plenty of times for torquing heads and bearings, but for oil drain plugs and oil filters.
#49
I can see how a flare-nut wrench might not be as robust as a the conventional open-end type, but I can't see using them for anything requiring high enough TQ values to break them.
ShadowGray19 (04-18-2019)
#50
Moderator
#51
Just adding to this as I just went through this yesterday.
Regarding the size drain plug:
-Tried a 15mm flare wrench (harbor freight, lulz), didn't work, started rounding off
-Tried a 15mm box wrench (Husky), 12point, didn't work, wanted to round
Said screw it and put my 6point socket on with a short extender, all 3/8" drive. Threw a cheater bar (handle from jack) on it and socked it off. I put the socket on first, then the extension. The extender was small enough versus the socket to snake under the oil cooler (it may have put an ever so slight bend on it, but nothing to worry about). A wobbly joint extender probably would have come in clutch, but I didn't feel like looking for it lol.
If it matters to anyone, I'm using 5w-30 Mobil 1 Extended Performance. I have the oil cap for 0w-40 to swap on, but won't until the oil becomes reasonably priced. Cheapest I found was $50 for 6qts. Pretty pricey versus $23 for 5+qts jugs at wallyworld… And I'm sure the dealers aren't stocking/filling with 0w-40. They'd have to be pretty high on Vette servicing volume to stock it and even then there's no way of knowing what's coming out the tank. Just my thoughts.
Also wrecker3, good call on the funnel. Looks nice, wish I saw it a day earlier as it was delivered the day after I did the change.
#53
#54
St. Jude Donor '17, '19
Be careful with any socket or wrench set from HF. They have a lot of great stuff like jacks, punches, sanders, etc. But every socket I have bought from them has not fit right and started rounding nuts and bolts. This would be one thing in life that is just worth spending twice as much and get verified, well proved tools. Screw driver, get at walmart. Dremel tool, get at HF....Socket set, get a craftsman (or the like)
V Vette (04-22-2019)
#55
You guys that are ordering that funnel for $20.. quit it.
It should be around $14.49....
https://graph.keepa.com/pricehistory...sin=B0771KVLF3
#56
#57
Same here, no problems. Being an engineer, I figure that Chevy must specify a torque setting for a reason. We never specified torque settings unless there is a good reason because it is a PIA for us. It only takes seconds more to torque the fastener.
ShadowGray19 (04-22-2019)
#59
If you position the crows foot at an angle the offset is less than an inch so there is no significant difference. I just reduce the torque by 1 inch-lb even though it isn't necessary. Specified torque values always have a tolerance zone anyway..
#60
