Oil life
Topic has been discussed two or three dozen times maybe more. Suggest you search the topic which will give you hundreds of opinions.
Received 3,812 Likes
St. Jude Donor '03-'04
I dont believe you... Ive personal done hundreds of test at the Warren Test faculty developing the oil life monitoring system and the new revamped oil feed system. We could never get past 15 months without an exponentially acidic condition and that's after 15 months. WE do something called F.M.E.A. in research and development. Failure Modes Effect Analysis. 1 years was the establish safety Zone, thus the recommendation. You are telling me you drove a car for 24 months and had no negative PH? Like I said.. I dont believe you. People think they can buy 15,000 mile oil and use the same oil for 15 years putting 1000 miles a year on it.. WE hear stories like that all the time at GM Engineering support. people read Max pressure on the sidewall of a run flat tire Max pressure 63 psi, and they think that putting 63 psi in their corvette must be better because more is better right? They wonder why the handling is so unsafe. WE have a saying at GM that we can not make it idiot proof enough for some of the idiots who buy these cars.
Corvette Enthusiast
Mine lasted a poor 7500 miles this summer (I actually put on 11,000 miles so I can say I mostly removed the time component).
I feel that even without the time component the C7 oil life monitor is much more aggressive than the C6 one.
Is that SuperTech DEXOS2? just wondering?
I had a boat that I recently sold with a Gen V blown 454 making about 650 HP running Mobile 1 15w/50 racing. I owned it for 18 years! I only put on maybe 20 hours a year. I didn't change the oil for about 10 years due to infrequent/lack of use. I changed the filter every 2 years and added a quart once or twice in 10 years and the oil always looked perfect and never had any issues with the engine that I built. I never did an analysis and it likely had impurities but the engine didn't know any better. Do we think our LT1 engines would know they had compounds that weren't helpful?
Gnarley Z51 (11-08-2019)
Evil-Twin, so tell us what is affected and what damage occurs when "OLD" oil is run for 2 years or longer and you don't even reach 7,500 miles? I have no doubt there are compounds that aren't necessarily good but are they harmful enough to cause catastrophic engine failure or any kind of failure? I understand that if you had an engine failure an oil analysis would indicate elevated levels of a specific compound and would void a warranty. I'd have to think most of us take really good care of our vehicles and most don't abuse them. I have to also imagine that the LT1 engine is not that different from many other "modern" engines today which do not require oil changes every year and they do not have catastrophic failures, so perhaps isn't this a bit overblown though required to maintain warranty?
Corvette Enthusiast
What about this... and maybe it was already covered and I missed it?
If your car only has a couple of thousand miles on the oil and it times out is the oil bad? Do we really think a dealer would change the oil on a brand new car they've had in stock for a year? Methinks not and they'd likely just reset the timer. So if a dealer does that and the oil is like new why can't anyone just reset the counter for their oil? After all, isn't changing oil that's only been used a few thousand miles really very wasteful? What about some owners who barely drive their cars at all? Why should you change the oil just because it times out, what harm is there in resetting the counter and getting the useful life out of your oil?
Thanks!
Thanks!
Thanks!
Thanks!
While under warranty, follow the manufacturer's instructions. If you don't, and have an engine warranty claim, be prepared to prove you actually did the oil changes (not just reset the OLM). Once you are out of warranty, do whatever the heck you want.
Thanks!
Thanks!
Some believe that the engine will blow up if oil is not changed yearly.
#33
Limited Powertrain Warranty
Nobody believes that. But what is a fact is that if you don't change your oil at least once every 12 months while under warranty, GM has every reason to deny any engine warranty claim you might make. So is it really worth saving a few bucks over? Once the warranty is up you can do what you wish.
Anyway, I'm always skeptical regarding limitations. Can someone with a solid understanding comment?
#35
Great, so the Warranty is 5-year/60,000-mile (whichever comes first) transferable Limited Powertrain Warranty. Does anyone know specifically what is limited and how? The part that typically gives a manufacturer a way out is "LIMITED"! Can you imagine that the oil pump failed and when looking at stored data in the ECM they found you manually shifting and that wasn't allowed under warranty? I always expect some kind of limitations and exclusions will apply to benefit a manufacturer and leaving a customer responsible.
#36
You can always expect far less when out of the 3/36 bumper to bumper factory warranty. That's pretty much gospel, regardless. The power train warranty is a whole nother thing. Like the 3/36, it is all inclusive of only what it covers. Don't worry about your OLM timing out if you haven't changed your oil. It's definitely not going to void any warranty. Not in the 3/36.
I'd like clarification on the 5-year/60,000-mile (whichever comes first) transferable Limited Powertrain Warranty which is not clear as to what is covered in the Powertrain in years 4 and 5.
#37
