Who has suffered a flat tire?
I apologize if this is a redundent question but could find no thread. Who has had a flat tire on their corvette in the last 5 years?
Popular Reply
05-05-2019, 08:09 AM
Right
I will put up with a little more road noise .... to have the security of knowing that 99.9 percent if the time I will be able to get to my destination or at the least someplace safe
Those that say I will carry a plug kit , and a air pump ... how the heck are you going to .....
Get a jack under a vette that has a flat
Or try to lay on the ground in some unsecured place trying to find a nail or what ever is in the tire so you can pull it out
Then push a plug through said hole in tire
and then pump up with some 12 volt pump
Or
"I have Towing"
I have two cars that require Flat Bed towing , a AMG and my VETTE . For those that say this, have you ever waited for a Flat Bed tow truck that has the ability to pull your car up ...? Not all drivers know how to lift a low expensive car . I have and in both cars I have had 2 drivers see the car and say that they could not pull my cars up without damage . And then what are you going to do when they get it up on the bed , have them drop it off in the parking lot of a closed repair business ...and then have to come back when they are open
No thanks ... I will keep my runflats on both cars ....
Dave
Or
"I have Towing"
Dave
Moderator
dlsmith82 (05-04-2019)
I recently did with my OEM "runflats". Very disappointing they couldn't hold up better after a pothole.
Replaced with non-runflats.
If you don't mind sharing, what did you replace with?
FIREHAWK INDY 500- 255/35/19 front and 295/30/20’s rear.
Very happy with them!
https://www.corvetteforum.com/forums...0&goto=newpost
I got one a year and a half ago driver side rear. Got a quarter mile from my house when I got the low pressure warning. I went back home and removed the tire to find three punctures. One of the holes was too near the side wall to repair but I had about 33,500 miles on the tires and it was getting close to replacement time anyway.
Did you replace with OEM?
Do you travel with items to help with a flat?
Pretty incredible!
I picked up a screw, right rear tire, this past winter. Tire had five thousand miles. I replaced it with an identical tire, total cost was around $400.00.
Dave
I have run flats and I never have to worry about getting stuck somewhere with a flat. Priceless!
Dcasole (05-05-2019)
