C7 battery died, but....
Sometimes, at weekend car meets, I'll put my C7 into "service" mode. This turns on everything except headlights, A.C. and fans, running off the battery. I've left it that way for several hours without impact to the car's OEM battery. I drive home and hook it up to the Genius 3500 charger, rinse, repeat.
Last Friday was a bit different. My cell phone was dying, so I thought "lemme charge it while in service mode". So, for 2hrs, I left it. Go to start and I get the dreaded clicking. The battery was dead. Some random folks came by with a USB jump starter. They said hook it up and start...I did and it did. Impressive. Yesterday, I ordered a (and received today, less than 12hrs later). I won't leave home without it.
The following 2 users liked this post by ImpliedConsent:
frankb (05-19-2019),
joemessman (05-19-2019)
I learned about a similar device when my 67 big block died at our library. My son in law brought one of those over to jump me and I laughed at him. It fired right up.. I'm with you, I never drive anywhere without it. Will probably order a 2nd one to keep in my yukon daily driver.
ImpliedConsent (05-19-2019)
No, you misunderstand. I use service mode to light up the DRLs/lighting beyond the 10minute limit. It just so happened my cell phone was dying that night and I decided to charge it while in service mode. I'd never done that before and I'm just guessing it killed the battery prematurely.
The following 3 users liked this post by owc6:
Exactly true, unless you're in "service" mode, then all those danged ports, jacks, windows... they're all on. I'll NOT be testing my theory that it was my charging of my phone that killed the OEM battery. I'll just hook it up to this USB charger (QC too!).
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Any particular reason you picked this brand and model? Or was this the one that was used on your car? Thanks for the info, btw.
You're right. It was the brand/model the couple used. It was tried and true and got me out of a bind. I just finished charging it and it sits in the cubby. I'm curious as to its shelf life.
Got this^^ from Chevy dealership, about $80 out the door, 1000 amp with USB ports, charge your phone from it, etc, good for abt 25 jump starts. Lithium & rechargeable lots times (years) Starts all types of 12volt battery systems, don't leave home without it.
I have had this one for over a year:
https://www.amazon.com/iClever-18000mAh-Portable-Starter-Flashlight/dp/B0752T1HKG/ref=asc_df_B0752T1HKG/?tag=bingshoppinga-20&linkCode=df0&hvadid={creative}&hvpos={adposition}&hvnetw=o&hvrand={random}&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl={devicemodel}&hvlocint=&hvlocphy=&hvtargid=pla-4584207576976103&psc=1
Received 2,051 Likes
St. Jude Donor '13
OP referred to a "USB jump starter". Can you actually put enough current into the car's USB to start it without frying other items, or did you mean you can keep the jump pack charged up by leaving it connected to a USB in your car when everything is normal?
St. Jude Donor '15
"In honor of jpee"
Thank you. While not exactly inexpensive, it's what I'd call "cheap insurance" to have with you. I think I'll get one! Thanks again for the counsel.
Gearhead Jim (05-19-2019)
St. Jude Donor '13
A friend has one of those jump packs in case his own Corvette battery dies, he claims he only has to charge it up a couple of times per year to be always ready.
Unfortunately, I don't know which brand or model he owns.
Last Friday was a bit different. My cell phone was dying, so I thought "lemme charge it while in service mode". So, for 2hrs, I left it. Go to start and I get the dreaded clicking. The battery was dead. Some random folks came by with a USB jump starter. They said hook it up and start...I did and it did. Impressive. Yesterday, I ordered a 1500A USB Power Pack from Amazon (and received today, less than 12hrs later). I won't leave home without it.
I've wondered if you could use these battery packs in place of the regular battery. They're very light, pack an enormous amount of power, and are relatively cheap. Not for the corvette, but for something smaller where light weight is important.
