Mystery chime
Mystery chime
I shut off my 2019 Stingray, open the door, and hear a single chime. Huh? How to turn that off?
Is there a message in the DIC when it chimes?
I turned the chime volume setting down all the way, but still get mystery chimes, including after turning off the engine and opening the door. What does that mean and how can I stop it?
Another thread's running w/ similar 'mystery chime'.
Turned out owner had accidentally set his headlights 'on' vs 'auto'.
When shut-down w/ HLs 'on', caused chime, a reminder to shut 'em off.
Mystery solved, and interestingly another member posted claiming same issue.
Upon checking, HLs were (inadvertently?) put in on/manual.
Check position of your HL switch, may solve the mystery immediately.
Received 19,284 Likes
'20-'21-'22-'23-'24
Let us know what you find out is the source of your chime.
My going theory is that it’s letting me know there is a msg on the DIC, but I’m not sure.
My 2014 Stingray never had this issue. This is my 2-week old 2019 Stingray. Hope somebody can solve this.
I’ll let y’all know. Thanks.
This happens pretty consistently:
I shut off the car.
DIC says “Start engine to view application”.
DIC goes blank.
I open the door.
2 seconds later I get a polite single chime.
I shut off the car.
DIC goes blank.
I open the door.
Are you sure you do not have an extra FOB in the corvette or left a singe FOB. There is a setting not to chime if either is the case. I like to keep an extra FOB in the corvette in case I lose the one on me. I can always use my phone to unlock.
Yes, one time I was away and lost my keys. I was at cedar point. Lucky for me I went back to the last ride and the attendant had them...they fell on the floor - I was an indoor 3D ride.
One thing to check...
If the DIC is set to display certain functions such as tire pressure, oil life, g-force bubble gauge; the DIC will warn you the car has to be running for those "applications" to work. Maybe that is the chime you are hearing. If the DIC is set to show AUDIO (Currently playing) or INFO (speedometer), it won't warn you because they work even if the car is not running. I found this out one time when I had the car showing tire pressure when I shut it down.
What was the last thing you had the DIC set to show?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Nice to see so many chimed in
Nope. Only one fob; in my pants pocket. I also went thru the settings and turned off all the chime warnings I could find, as well as the volume down to minimum. Thanks.
Mshindman (07-21-2019)
When I turn the car off, the DIC warns: “Start engine to view application”, then goes blank.
I open the the door to exit, and the chime chimes in (sorry) 1-2 seconds after that, when I’m halfway out the door.
While driving, I usually keep the DIC set to Performance > digital speedometer, with the 4 digital gauges on the right.
