What battery replacement size for 2017 Corvette Stingray M7
Let's not discount the OEM AC Delco. It might not be an AGM, but that bad boy has 770CCA and 120 in reserve. I'm not sure who makes them (US or China), but I believe they have a relationship with either Johnson Controls or Delphi... Exide maybe? I dunno, but the specs on the OEM far exceed many other brands.
Dennis
i would stay with AC Delco oem battery.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Perhaps they will send old ones back to Saudi! Maybe they are getting in the battery business to replace their current oil revenue as cars will be powered by battery!
goldend (06-13-2019)
In the 60s I interviewed for a job at a Delco battery plant. They built two models, the OE one that went straight into cars coming down the assembly line and the consumer model for replacement sales.
What was the difference? The consumer model ran past a little paint roller that highlighted the raised lettering on the side so it would look more impressive on the shelf.
That was it.
That was it.
That was it.
That was it.
JerryU (06-13-2019)
sure as hell not buying anything made in saudi arabia. i hate buying anything made in china as it stands, the middle east meanwhile is just going too far.
They left manufacturer dry (at least ones for retail sale) for acid to activate charge to be filled later. What a mess that was filling those batteries with acid. Smelled like rotten eggs and you were lucky if you had a shirt that wasn't eat up by the end of the day.
Also, the early 60's models were "tar-top" batteries, yes that's right the top was sticky tar. A must have today if correctly restoring and early 60's GM muscle car.
Yep, remember the required acid fill!
Funny, that a lot of power to charge batteries is now required in battery manufacturing. When our local group toured the Johnson Controls plant and saw a lot of space used to put ~100 batteries in each of ~3 large water bath pools. The power was connected to the posts, the water raised to almost the top and a huge amount of DC current used to charge them.
On another monthly plant tour we had an electrical engineer from the power company describe the massive sub station built primarily for the Johnson Controls plant and to supply other new facilities in that new industrial park. I found one thing of interest was the large relays that shut down power if a short is detected in the power grid system supplied by that sub station. If you notice, sometimes your lights will blink and power goes out for a second or so. Then it comes back on and may do that twice then may shut down or stay on. We were told if a squirrel or tree branch gets across the high voltage wires and causes an excess current surge it shuts off but is quickly turned back on to see if the short cleared (squirrel was disintegrated!) That is done automatically perhaps twice and if the short didn't clear then it is shut down until maintenance folks find the cause and correct it!
Hi,
1. What battery size and make/model of a battery do you all recommend?
2. Has anyone put a lightweight lithium battery such as by Braille in? If so, what model did you buy? Does it work reliably and won't damage the car?
I was told that that these Braille battery sizes fit:
https://shop.antigravitybatteries.co...tive/ag-h6-rs/
Please feel free to check out the video below
