C7 Z51 brake question
Old 06-13-2019, 01:06 AM
Silverfox1
CF Senior Member
Default C7 Z51 brake question
Just got my 2015 : Z51 3LT M7 8k mi. Found in the trunk two metal disc rings, GM part # 23184111 "Z51 Front Brake Rotor Cooling Rings." Asked dealer bout it & he says OEM aftermarket addition for those who track car. Can anyone add to this? How they work? For those of us who don't track, is this even worth putting on car? Thinking when car needs new fronts, just throw them on. Doesn't look like any big deal to do it. Oh yeah, saw rather spirited discussions from few years ago about whether to put wheel locks on. Consensus was if they want 'em, they'll get 'em. Locks may scare off the "casual" thief & may just slow down the pro. Those that are stymied may be pissed off enough to do other damage. is that assessment still accurate today? At home car is always garaged. But planning trips, amongst them the 2019 Caravan.
Thx
Silverfox1 is offline
Old 06-13-2019, 08:11 AM
rrsperry
CF Senior Member
rrsperry's Avatar
Yep those are the factory cooling rings. OE not OEM.. (as in an original part that came with the car.
No, don't put them on. You are supposed to put them on when you track the car and THEN REMOVE them... It's ok, because I think Chevy did away with them anyway.
So no, don't just put them on. Use them as paper weights or wall art.
rrsperry is offline
Old 06-13-2019, 11:30 AM
Silverfox1
CF Senior Member
Ahhhh, thx for the head's up. Good to know.
Old 06-13-2019, 01:45 PM
JMII
CF Senior Member
JMII's Avatar
I track my 14 Z51 without the cooling rings. My car was used and didn't include them. However (expensive) aftermarket two piece racing rotors don't come with them so I am not buying GMs logic on why they are needed. Plus as mentioned they changed the design of these rotors in later years and got rid of the rings anyway. Seems to be a failed experiment then.
As for wheel locks - never been a fan of them. If you lose the key or they become damaged you are in a world of hurt. If someone wants your wheels they are taking them regardless of the locks.
Congrats on the car
JMII is offline
Silverfox1 (06-13-2019)
Old 06-13-2019, 01:48 PM
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 1,975 Likes on 1,102 Posts
Don't bother... I tracked my C7Z51 w/o them w/o any issue. The OEM 2-part cast rotors lasted nearly two seasons (using good pads) before I swapped to DBA rotors. They were an odd oversight.... something came up in development to where engineers decided the car needed a larger heat sink on the front. GM wanted you to install and un-install every track weekend... which is sily as it requires taking the caliper off every time which is great for the caliper bolt threads which get torqued to 159 ft/lbs with fresh loctite.
Tool Hoarder is offline
Old 06-13-2019, 02:56 PM
TPAJETSKI
CF Senior Member
My cooling rings are still in the plastic bag. I swapped the front rotors for the updated version a few months back.
TPAJETSKI is offline
Old 06-13-2019, 04:29 PM
Silverfox1
CF Senior Member
Ahhh, mine are also still in the plastic bag. What's the deal with the upgraded rotors? Thx
Old 06-13-2019, 04:36 PM
Tool Hoarder
CF Senior Member
Can you be more specific? GM cheaped out in later years going back to a 1-piece rotor even for the Z51s. The early 2-part cast rotor is superior.
Old 06-13-2019, 04:48 PM
JMII
CF Senior Member
JMII's Avatar
I thought the early 2 part suffered from vibrations. Source: http://www.corvetteactioncenter.com/...html#d2342e156
Mine are starting to vibrant slightly but given that I track the car I knew they wouldn't last long. Also in my case I could have pad deposits issues as I switch between aggressive track pads and the crappy OEM pads.
I see that many here just move onto DBA rotors especially for track use.
JMII is offline
Old 06-13-2019, 04:52 PM
Tool Hoarder
CF Senior Member
Put 55K miles on a set and never had any vibrations. Bought car in 2017 with 42K miles, has 56K now and just put the DBA 2-piece fronts and single part rears on. Had zero issues with the stock 2-part ones. I did see the TSB on vibration, but could have been hub face rust/deposits.
Quick Reply: C7 Z51 brake question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
