Can this grill be repaired?
Popular Reply
06-25-2019, 12:01 AM
Single sections are available, great time to move up to a z06 grill
The following 7 users liked this post by yaknow:
Corvette-Dan (06-25-2019),
DeStreGa5 (06-25-2019),
I got your ZO6 (06-25-2019),
KRamz (06-25-2019),
Maxie2U (06-25-2019),
and 2 others liked this post.
Received 1,620 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
That section pops out for a tow hook to screw in to the receiver behind it. Yours likely came loose and fell out. I had an extra one, but gave it to someone on the forum that had the same issue.
The following 2 users liked this post by Marcho Polo:
twowinns (06-25-2019)
Follow-up question; can only that section be removed/replaced or can the other sections be individually removed/replaced? Reason I ask is, I have a lower right section with a small plastic piece missing due to a big rock going through it.
Former Moderator
that piece is the only one that is removed on purpose. Damage anywhere else will require a replacement grille.
Mike
my thoughts exactly!
It looks/works great; I'm on the cheap side of modding as I am a recently retired teacher and this was one of the few
I've done and well worth it from the "meaner" look to the brake ducting, You do have to remove the nose clip but
if sits right in their with a minimum of fuss.
