Afterblow
Old 07-12-2019, 09:28 AM
mountainears
CF Senior Member
Support Corvetteforum!
mountainears's Avatar
2017 C7 of Year Finalist
Not unless you have a programmer.
mountainears is offline
Old 07-12-2019, 10:35 AM
Gary2016
CF Senior Member
I have access to a programmer does anyone have the actions needed to be taken to activate it?
Gary2016 is offline
Old 07-12-2019, 10:42 AM
mountainears
CF Senior Member
from this site, not sure how accurate...
Use the following procedure in order to enable the afterblow mode:
  1. Connect the Scan Tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Build the vehicle with the scan tool.
  4. Select Module Diagnosis.
  5. Select Remote Heater and Air Conditioning Control Module.
  6. Select Configuration/Reset Functions.
  7. Select HVAC Afterblow Configuration.
When afterblow has been enabled by the scan tool the blower motor will operate at 68% blower speed for 2 min 30 s to 4 min after the engine has been in Key OFF for 30 min.
The following conditions must be met for the HVAC module to operate the afterblow:
• The outside air temperature must be at least 21C (70F).
• The A/C compressor must have operated during the latest key cycle.
• The engine must be turned off for at least 30 min.
• The system voltage must be at least 12 V.
Quick Reply: Afterblow
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
