Optima Battery
Optima Battery
I was at an event in Austin Texas at Circuit of the Americas. Optima Batteries had a car show, and if you registered, you'd get a Yellow Top battery.
I have the battery, for my C7 Grand Sport, it called for a H6 battery, what I received was a DH6 Yellow Top. Any issues with using a deep cycle battery?
Thanks in advance...
There is another thread on this titled: "Battery: which is best, AC Delco or Optima ?"
Jay Leno uses Optima batteries in all his cars. He says you don't have to worry about fluids leaking out.
Interesting! I am staying with OEM for now. Best wishes.
30 years as a Corvette daily driver - more than 900,000 miles - see zero reason to change away from OEM batteries...
The following 3 users liked this post by 4thC4at60:
Received 5,202 Likes
When Ultima first came out I used them for many years. At that time I had to get them mail-order since no one locally sold them yet. I always had excellent and long service, both of which justified the above premium price... at least for me. Then Johnson Control bought the company and as they say, "that was that." I continued with them for a while... that is until I got two bad ones in a row. Only then I did the research to see what had happened. Hence, I discovered the sale and more. No more Optimas for me.
NortonCO (11-16-2020)
Roadster Madness. 😠
Received 1,510 Likes
St. Jude Donor '13, '20-'21
I cannot answer your question because I have only used AC Delco. I can tell you that for the last 17 years I have owned my C4, I have only changed the battery three times, and that was with extended garage parking time between car shows.
I need a new battery in the C7 and I am going with the AC Delco.
Here is the link on a battery search for Optimal. They are all very old:
https://www.corvetteforum.com/forums...rchid=82110681
Always used Delco batteries in my Corvettes and sold thousands through my auto parts stores over the years and never had issues doing either.
You can get an OEM Delco battery for your C7 for about $125>$140 that will typically give you 5>6 years service, that's good enough for me.
Used Optima in my hot rod truck is the past. When I went to the local battery shop asking about an Optima a few years back, found out that they are no longer made here in the USA, but in Mexico. That makes me question about the quality control of the battery.
Received 19,275 Likes
'20-'21-'22-'23-'24
When I had my last two C5, I ran Optima Red Tops in them. In the '00, the Red Top lasted nearly 7 years and was going strong when I sold the car. When I bought my '03 (used), it had a Red Top in it and right after the three year mark, the battery gave up the ghost. So, mixed reviews from me.
I have been pleased with the AC Delco batteries too - they have given me many years of reliable service.
There's no issue running a deep-cycle battery. I have no first-hand experience with them but, as others have said, Optima reviews I've seen/heard point to a decline in quality and reliability following buyout and offshoring of production.
Optima, of course, on ultima as in my dumb post above... it's a b***h to get old, let me tell ya!
Optimas are deep cycle AGM batteries. They are designed to produce moderate amounts of current over long periods of time. Examples would be if you are shining spot lights of the battery with the engine off, or are playing super high power stereo with engine off.
When the car is running, the alternator MUST be able to keep up with all loads. When running the battery just sits there getting charged most all of the time.
Plus, AGM batteries require step charging. The GM charging systems do not do step charging needed to support the AGM chemistry/design.
So there’s no need for OPtima unless you have heavy battery drains when the car is off. They are not going to hurt anything if you got it for free, but life of the battery will be reduced if they are not charged properly (I’m sure you could find a special voltage regulator with the proper charging program for AGM batteries)
NortonCO (11-17-2020)
There are many C7 owners using AGM batteries. If I lived in the frozen tundra of North Dakota I would continue to use a flooded lead filled battery. If you're a southern boy AGM is fine. Also, numerous battery maintainer/chargers can work with AGM batteries. The CTEK 3300 indicates in their manual they can charge the AGM. However in cold climates of northern Idaho I would use a CTEK 7002 which has what they call "snowflake mode" and will charge a battery at a lower Voltage setting when temps drop below 41 deg F. You don't want to fast charge an AGM battery.
Just because they are being used doesn’t mean it’s technically a good idea. The bulk charge needed by AGM batteries is at a relatively high charging amps. They need this for longevity. Those little maintainers are only meant to top off and maintain a battery and not to charge it from deep discharge. And our voltage regulators do not support the charge profile needed by AGM batteries. Sure they will be charged by conventional charging but it’s not optimum and will affect battery life. The marketing campaign for these batteries is very strong and convincing. They are good for long moderate draws while not being charged (deep cycle). An aftermarket voltage regulator would be needed to feed AGM batteries their proper charging diet.
Ron_Attleboro_MA (10-08-2021)
Why not contact Optima directly instead of relying on opinions? I personally would not risk damaging my electrical system just because I did not make a simple phone call.
Toll Free: 888-8-OPTIMA (888-867-8462)
CUSTOMER SERVICE:
E-mail: info@optimabatteries.comToll Free: 888-8-OPTIMA (888-867-8462)
Yes, but those cars - unlike the Corvette - have charging systems designed for AGM use.
BMW is one such example. The final step in replacing the battery in my BMW was to register the battery to the car (AGM or not, amp hours, etc.) so that the car knows it has a new battery and the battery's specifications. The car then treats the battery according to its type and specs.
DON'T DO IT; Stay OEM
I have first hand experience on my Jeep with the yellow top Optimas and they are GARBAGE. Mine loses juice rather quick, sometimes it dies just after a week of not driving my Jeep.
They used to be excellent with a long live but not any more. Also they used to have like 10 years warranty and they changed it to 3 years, just like everybody else.
I don't want one of those nowhere near my Z.
