Engine l stumble
Old Nov 18, 2021 | 06:51 AM
jazvet's Avatar
jazvet
Veteran: Marine Corps
Default Engine l stumble
Have 19 vert that has this problem around 1500 rpms anyone experience this ?
Old Nov 18, 2021 | 11:03 AM
Maxpowers's Avatar
Maxpowers
I dont. You should check for codes as a first step.
Old Nov 18, 2021 | 10:57 PM
jimmbbo's Avatar
jimmbbo
A8 or M7 trans? Stopped in neutral or moving? Vibration only or sound as well?
Old Nov 19, 2021 | 07:17 AM
jazvet's Avatar
jazvet
😒A8 when moving no codes
Old Nov 19, 2021 | 08:14 AM
TensionED's Avatar
TensionED
Yep I and many here had shuddering in the 1300 to 1600 range. This certainly sounds like a trans triple flush issue though I thought it was corrected in 2019. Maybe if yours was made early in the model year that could be the problem. I just had mine 2017 flushed and GM paid for it. It fixed the issue immediately. Best of luck and I hope that is the issue since that is a quick and easy fix.
To Engine l stumble
