key fob programming issue
Old Oct 1, 2022 | 08:03 PM
9sec's Avatar
9sec
Default key fob programming issue
2017 z06 2 key fobs. 1 original to the car 2nd fob is a new oem gm fob with the key blank cut to the car which I confirmed opens the rear hatch.
when I try to program the new key the way I read the instructions is as follows
1. insert key into lock and turn 5 times in 5 seconds
2. insert fob buttons up into slot in the column and dash should read new fob detected
my issue is when I perform step 1 I get a dash reading that says "action required remote learn pending please wait
then at the bottom of the dash above the touring icon it says "dismiss"
within a 10-20 seconds the dash simply goes blank and nothing happens. if I go get the working fob the car will not start until I hold the start button for 20-30 seconds to clear the dash then it starts.
ideas as to what im doing wrong? i9m keeping the working fob away from the car as instructed in the programming thread. do I need it in the cupholder? im sure its me not the car thats doing something wrong and im loathe to pay the dealership 75$ plus tax to program a key .
Old Oct 2, 2022 | 12:45 PM
RonC7's Avatar
RonC7
Use the procedure in the Sticky Threads or in your owner's manual. You will need to use the LONG procedure (Programming without Two Recognized Transmitters) if you want your fobs to be #1 and #2 (doesn't matter for 1LT/Z trim without seat memory).
Use the procedure in Sticky Threads to prove that the system works before you try the reprogram.
Is your new fob the same part number as the old fob? 2014/5 fobs are different from 2016/9 fobs and are not interchangeable.
Timing for the key rotations is tricky - try slightly slower or faster...
The owner's manual says to start with fobs in the cup holder. I have added #3 to my previous 2014 and current 2019 using the procedure in the manual.
GL
Ron
Old Oct 2, 2022 | 01:07 PM
9sec's Avatar
9sec
@RonC7 I tried the procedure to see that the system is working with the recognized fob and I get the same message. do I need to erase this message before starting? I see the dismiss icon but dont know how thats done other than holding the start button 20-30 seconds. retry and same thing shows up.
Old Oct 2, 2022 | 01:14 PM
RonC7's Avatar
RonC7
Press the center button (SEL) in the DIC steering wheel buttons under your right thumb to dismiss a message.
SEL : Press to open a menu or
select a menu item. Press and hold
to reset values on certain screens.
Ron
Old Oct 2, 2022 | 01:43 PM
9sec's Avatar
9sec
Ron
ok ill try that. I was concerned about the long procedure since I only have a single workin g fob. if I screw it up I wont be able to start the car. guess its time to see!
something else you mentioned about the food having different yrs to work. physically they look the same the decal on the fob has the same #5951 as the original fob but I int see any part # without opening the fob up which im reluctant to do.
looking at the instructions am I correct in that I have to make all the fobs unusable first then relearn them? thats the scary part !
Old Oct 2, 2022 | 02:06 PM
RonC7's Avatar
RonC7
If you don't want the new fob to trigger memory recall - use the short procedure. You can always use the memory button...
So if you want the practice and to prove the new fob - do the short procedure and if successful then do the long one.
Ron
Old Oct 2, 2022 | 03:35 PM
9sec's Avatar
9sec
@RonC7 you sir are owed a free drink on me!! the long procedure reprogramming both fobs are what was needed . takes about 30 minutes but works perfectly. now I have 2 working fobs! thanks again
Old Oct 2, 2022 | 03:55 PM
RonC7's Avatar
RonC7
I'm just glad you got it done.
I know how frustrating key fobs can be.
Ron
Old Oct 2, 2022 | 06:16 PM
9sec's Avatar
9sec
Ron
it was more fear then frustration. with only 1 working fob and having to basically disable it I was terrified I would screw up the procedure and then have no way to start the car. im computer deficient and illiterate! can barely work my iPhone 8 lol
thanks again.
Old Oct 3, 2022 | 04:56 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
thanks again.
I've seen it suggested on the Forum that the long procedure be done in a Chevy dealership parking lot, for just that reason.
Old Oct 3, 2022 | 05:40 PM
9sec's Avatar
9sec
I try to stay as far away from dealerships as I can. it really wasn't hard at all and the instructions are clear and precise. the forum thread I was using didn't tell me I had to wait 10 minutes between and when the screen went blank I assumed it was going to sleep. the directions posted here were much easier too use
Old Oct 3, 2022 | 07:48 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Thanks, that's what they were typed to do. Use the KISS method to get it done correctly.
Elmer
Old Oct 5, 2022 | 12:24 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
This is certainly not what we like to hear, 9sec. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2017 z06. To do so, please send an email to socialmedia@gm.com with ATTN: 9sec/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
Old Oct 5, 2022 | 01:44 PM
9sec's Avatar
9sec
www.gm.com
with all the help I get on this forum I have little use for dealerships
Old Apr 27, 2025 | 05:02 AM
bOule's Avatar
bOule
7th Gear
hello, I have the same problem here in France with my C7 of 2017, the message is always the same as yours at the beginning. Could you explain to me what you did to change this message and finish this long procedure? thank you!
Old Apr 27, 2025 | 07:14 AM
bOule's Avatar
bOule
7th Gear
I did it!
in fact had to wait 10 minutes for the right message is displayed! and the rest is quite simple!
my 2 remote controls work!!!
HIIIIHAAAA !!!!!
Old Apr 27, 2025 | 09:07 AM
9sec's Avatar
9sec
Originally Posted by bOule
I did it!
HIIIIHAAAA !!!!!
im glad you were able to figure it out. im not much of a computer tech guy it intimidates me a lot. this forum Ihas always been a wealth of help. dont be afraid to ask so many knowledgeable members on here
Old Aug 22, 2025 | 10:16 AM
70vetteinpieces's Avatar
70vetteinpieces
I reprogrammed an old and bought new fob since one is lost Still haven't figured out where the cat hides her treasures - another forum discussion
biggest concern following the instructions - turn the key 5 times and the DIC shows ready and goes completely blank a few seconds later.
Concerned - seeing no activity or any lights. 10 minutes later DIC lights up and press start/stop button appears press that shows ready and again goes blank for another 10 minutes
repeat 3rd time and after the hit start/stop message appears hit stop/start the message insert remote #1 and then followed the remaining instructions..
I was expecting a 10 minute countdown visible or seeing a light flicker to show something was happening - nothing just a blank screen - that was scary........
2019 Stingray
Old Aug 23, 2025 | 12:23 PM
bearone2's Avatar
bearone2
Ron
deleted
To key fob programming issue
