FS: Now available from SCP: C7 Corvette Front Brake Cooling Duct System
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Braking on your new Corvette is the best it has ever been. You can stop on a dime under heavy braking. But there is always the dreadful brake fade from riding the brakes harder than normal. GM has designed a bolt on Front Brake Cooling Duct Kit to help with the problem.
The brake ducts direct a constant flow of fresh air to the back of the front brake rotor area of your vehicle, which helps reduce heat build-up compared to conventional air flow. The brake duct kit is beneficial for decreasing ‘brake fade’, increasing brake component life, and creating secondary cooling of brake fluid. The kit includes deflectors and bolts. This Chevrolet accessory can help to personalize, customize, or optimize the capability of your vehicle for your lifestyle and use.
- Increases the brake performance of your vehicle
- Directs a constant flow of fresh air to the back of the front brake rotor area
- Reduces heat build-up compared to conventional air flow
- Decreases brake fade
- Creates secondary cooling of brake fluid
- Potentially increases brake component life
- Kit includes deflectors and bolts
Order here: C7 Corvette Front Brake Cooling Duct System
