What's a cost effective track wheel and tire setup for my Z51?
Old 11-06-2015, 12:51 PM
  #141
SocalCyberZ51
SocalCyberZ51's Avatar
Got a set of TSW 18" with Yokohama AD08R. They clear my brembo calipers, but have replaced stock brake pads with Carbotech. Am told it's the balance tabs of the stock pads that don't allow clearance.
The wheels do stick out of the fenders a little in the back and rub the outside edge of the tire when suspension is fully compressed, but these tires do stick! 😍👍
Old 11-06-2015, 12:58 PM
  #142
blue_bomber697
blue_bomber697's Avatar
Received 1,296 Likes on 479 Posts
2018 C7 of Year Finalist
What size wheels and tires?
Old 11-06-2015, 01:11 PM
  #143
Race Tech Forged
Race Tech Forged's Avatar
Default Track Spec Series
We do offer a very competitive Track setup. Where out 19x12 is only 22lbs.
All of or wheels are custom built in the USA!
Any color and size is available.
If anyone is interested please feel free to send us a PM
Race Tech Forged Track Spec-5 MonoBloc <br/>19x12
Old 11-06-2015, 05:52 PM
  #144
SocalCyberZ51
Sorry, I meant 18" front and 19" rear.
Yokohama advan neova ad08r
265/35r18 93w
305/30r19 102w
Got the wheels on eBay. Pm me if u want details, but they r easy to find.
Old 11-13-2015, 10:50 PM
  #145
andy13
Cruising
andy13's Avatar
I can add first-hand information about the Cray Brickyard 20 x 11 rear fitment on the C7 Z51. Not good enough. While they fit and look fine on the road, they extend out too wide and I'm getting a bit of rubbing on the sidewall from the fender lip. I talked to Cray about it today and Ralph told me that Cray does NOT RECOMMEND their wheels be used on the track as they are not strong enough. He also defended the offset as being perfect for street use, but not for high speed. I found the answer puzzling, as they consider their wheels "high-performance".
Old 11-15-2015, 10:22 AM
  #146
mustclime
mustclime's Avatar
Yes you do...but as the thread says "cost effective"....
Old 05-30-2016, 10:36 PM
  #147
Bill B 1
Bill B 1's Avatar
Originally Posted by descartesfool
I have a set of four C5 Z06 rear wheels, 18x10.5", with four Nitto NT01's in 315/30/15. They fit fine front and rear without spacers, and have not seen any rubbing on my Z51, and they clear brakes and brake ducts and fenders. At full droop and full lock, the front wheel touches the rear of the front upper A-arm, which is not likely to happen in any situation I can think of. Putting tape marker on A-arm just to be sure it does not happen on track. Same setup as MTI Racing used, so I copied them.
Any more input on this setup and where did you get the wheels?
Old 05-31-2016, 02:09 AM
  #148
X25
Sr.Random input generator
Support Corvetteforum!
X25's Avatar
Received 1,465 Likes on 1,022 Posts
The new Cray Spider wheels seem to be a great choice for track use. They are spin-forged, and at 18x9.5 and 19x11 sizes. These sizes should let you mount a quite-wide array of tires. I am not certain if these wheels can clear C7 Z06 (iron) brakes, though. I asked one of the vendors, but he was not sure. He said he would check it out on their C7 Z06, and get back to me; we'll see.
I ended up ordering StopTech kit for myself, so I ordered CCW TS12 custom wheels, which the manufacturer states should clear StopTech 15" BBK. They said it even clears CCB brakes(!).
Bill B 1 (05-31-2016)
Old 06-02-2016, 01:46 PM
  #149
descartesfool
descartesfool's Avatar
Wheels came from Bob at House of Wheels. Setup worked fantastic on both my C7 Z51 and my buddy's iron brake equipped C7 Z06. Tons of grip, and cost effective. My setup is for sale now, 1 day old tires effectively. Shoot me a PM if you're interested.
Old 06-03-2016, 03:09 AM
  #150
Race Tech Forged
Compared to most forged wheel companies if we compare apples to apples we're cost effective
Old 06-03-2016, 03:11 AM
  #151
Race Tech Forged
18x9.5 (275) Front 19x11 Rear (325)
Old 06-03-2016, 07:12 AM
  #152
AKKutz
AKKutz's Avatar
What's the old saying...."if you have to ask, then you can't afford it?"
Old 06-03-2016, 12:16 PM
  #153
BaylorCorvette
BaylorCorvette's Avatar
That's what I've started running as of late. Running 275x35x18 NT01s on the front and 305x30x19 NT01s on the back. No issues so far (-2.0 camber front/back), haven't lowered the stock bolts though. I know at least one person on this set up that is lowered on stock bolts and has slight rub in the back.
Old 08-23-2016, 05:04 PM
  #154
Jedi-Jurist
Jedi-Jurist's Avatar
St. Jude Donor '15
Originally Posted by leadville1
I am running the TSW Interlagos 18/19 with Ferrari Challenge Take off's
The Pirelli's are amazing 275 front's 295 rears
I was considering those wheels, and for some reason, TSW doesn't think they fit the Stingray (offsets seem slightly off) - have you had any issues?
Old 08-30-2016, 04:13 AM
  #155
X25
X25's Avatar
Following on descartesfool stating 1000 times that 315/30/18 works up front and rear (thank you!!), I just ordered 315/30/18, 325/30/19 Nittos to be shod on my CCW 18x10.5 ET52, 19x11.5 ET83 wheels.
  • My goal is to go as wide as possible while limiting or eliminating oversteer. In my case, unlike pure square setup of using C5Z rear wheels on all 4 corners, I will have 315s on 10.5" wide wheels, while the rears are already a bit bigger at 325, and they will be mounted on a much wider 11.5" wide wheel, further stretching the contact patch.
  • Since wheel width usually dictates the actual contact patch width, I am hopeful this will result in about 20+mm or so actual difference F/R, even though the tire spec would only indicate 10mm or so.
  • On the top of this, my T1 rear sway bar is same stiffness as FE4 (Z51 w/MRC), but my fronts are 17% stiffer than FE4 front sways, which should further stabilize the setup.
If this setup doesn't rub, but still needs further balancing, I will buy the LG sways and use the stiffer setting up front to shift balance towards understeer a bit more.
Old 09-01-2016, 07:00 AM
  #156
AUTO_X_AL
AUTO_X_AL's Avatar
Take this from someone that learned the hard way, you'll want the T1 front bar if you have the T1 rear bar on non-MR Z51 springs. I even put the stage 3 aero on the back to bring the thing closer to neutral.
If you just need a front bar, order a Z07 Front bar off of a GS. That's pretty much the T1 setup.
Old 09-01-2016, 01:33 PM
  #157
X25
X25's Avatar
Thanks, I guess my text was a bit confusing, I already have both front/rear T1 sways, and stage 3 aero : )
By the way, I was told sway bars are all same among Z51 MRC, Z06, Z07?
To What's a cost effective track wheel and tire setup for my Z51?
Old 09-01-2016, 07:08 PM
  #158
Chets LS3
Chets LS3's Avatar
Correct. It's different bushings between the stages.
Old 11-21-2016, 10:24 PM
  #159
Internetguru
Internetguru's Avatar
I have been contemplating running Sumitomo HTR Z III's to make running my C7 on the track more affordable. I realize I will be giving up performance and grip... But I need to find a way to lower my per track day costs. And this one change would drop my track day costs by $150/day.
Old 11-24-2016, 12:15 AM
  #160
lynndm
lynndm's Avatar
The last set of TSW wheels I bought arrived with chrome flaking off in the shipping box. TSW would do nothing, finally had to get refund from MasterCard.
Doug
Quick Reply: What's a cost effective track wheel and tire setup for my Z51?
