C7 performance brake pads including low dust
#241
Supporting Vendor
St. Jude Donor '11,'13
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
#242
Supporting Vendor
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
PH:216-780-8825.
#243
Supporting Vendor
Carbotech brakes give you:
• Assured stopping power
• Increased overall performance and handling
•Excellent modulation and release characteristics
•Better control entering the corners
•Longer brake pad and rotor life—up to four times longer than the competition!
•Longer rotor life
•Non-corrosive dust
•Longer rotor life
•Non-corrosive dust
#245
Supporting Vendor
XP8 will work best for your option front and rear. There are so, many other factors I need to know more. Are you willing to swap pads for street and track?
Carbotech™ XP8™
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP8™
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#247
Supporting Vendor
Friday the 13th Phones are open 216-780-8825. We our here all day and is always 24/7 at http://ampdautosport.com/
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#250
Supporting Vendor
Open Saturday gives us a call if you have questions and of course orders 216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#251
Supporting Vendor
Give us a call 216-780-8825 and we can recommend the compounds that will be perfect for your front and rear pads. Assuring that they perform together with optimum effectiveness
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#252
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Amp’D Autosport.com
PH:216-780-8825.
#254
1521 pads
Installed the 1521 pads on Z51 yesterday. Perfect fit. Test drive (agressive) was very positive. Smooth and quiet operation. Very little dust after 50 miles. Much better than OEM. Thanks again Adam, Slim.
#256
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Amp’D Autosport.com
PH:216-780-8825.
#258
Supporting Vendor
PH:216-780-8825.
PH:216-780-8825.
#259
Madison Wisconsin
Pads work great..... thanks
Well, it is spring in Wisconsin and I have had the pleasure of getting the C7 out with the new low dust pads. And I just wanted to say thanks. They work great and I love not having to clean the wheels every darn time I drive it with the Z51 pads. I sure hope GM can do this switch so the rest of the world can stop cleaning wheels so much.
Nick
Nick
#260
Supporting Vendor
Nick
Nick
