C7 performance brake pads including low dust
#901
Supporting Vendor
St. Jude Donor '11,'13
Save 5% on your order use promo code z28 at check out or call us direct at 216-780-8825. If you have questions leave them here or feel free to call me at 216-780-8825, email or send private message.
http://ampdautosport.com/brake-pads/corvette/
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#902
Supporting Vendor
TO THE TOP....
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#903
Supporting Vendor
We have plenty of Carbotech pads in stock all compounds. Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#904
Supporting Vendor
Give us a call TODAY 216-780-8825 or order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#905
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#906
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#907
Supporting Vendor
I appreciate all the orders... Still have plenty pads in stock all compounds. Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#908
Supporting Vendor
Can't beat our customer service! Open Saturdays until 6pm call us at 216-780-8825 with question or orders and as always 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$
I just ordered a set for my 2017 Grand Sport. It only has 670 miles on it but the brake dust is intolerable. Last year I purchased a set of the 1521 compound CarboTech brake pads for my C5 that has C6 Z06 rims and brakes that had the same dust problem plus they squeaked. It has been over a year and no squeak, no dust, stops on a dime. Not only is it a great product, but let me tell you about Adam. I had my Corvette dealer mechanic install them for me and they still squeaked. I sent Adam an email to get his thoughts. He called me at home on a weekend and told me he talked to the installer. I took my c5 back to the mechanic and Adam walked him through the proper steps of prepping the rotors and bedding the pads. Problem solved! Now that's what I call customer service!
#909
Supporting Vendor
From low dust to full out race pads we have all Carbotech compounds ready to go. Let me know what your driving style entails and I will recommend the best set up for your driving application. I can be reached by Email, PM, Leave message here or call direct anytime at 216-780-8825. All pads available on line @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$ if you know what you need.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#911
Zo6 pads? What do you recommend for front and rear pads 2016 z06
I don’t track my car. Only street driving. Do you recommend the 1521..
Back to work Monday Check out review of the 1521 below.
I thought I would post a very quick review of the Carbotech 1521 pads I recently put on the car now that I have had enough time to get a really good feel for them.
I wasn't planning on swapping out the OEM pads any time soon. However, I decided to go with a Carbotech XP10/XP8 combination for the track this summer and wanted to make my life as simple as easy as possible when swapping pads. Having done some research, I was advised by Carbotech that if I used the XP10/XP8 for the track, I would need to spend time cleaning the rotors before putting the OEM pads back on as their compounds are not "compatible." I believe this will be, to some extent, an issue with many track pad to OEM pad transitions. With the Carbotech 1521 street pad, it is a simple as swapping them for the track pads and back again... easy as pie.
Once my car was jacked up, swapping the pads was fast and easy (other than the front pads which had tape on them which made it a challenge to get them off).
My observations...
1. Very little brake dust. Much less than the Z51 OEM pads.
2. Very good initial bite and braking force. Initial bite is better than OEM pads IMO and the overall braking force is subjectively the same.
3. The pads are dead silent. I had a couple of squeals the very first evening but since then nothing. I suspect that may have been residual OEM pad material on the rotor or dirt. I did not apply any brake quiet paste. They are quieter, in my experience, than OEM.
For those who aren't tracking their car, these pads are as good or better than stock in braking with WAY less dusting and virtually silent in my experience. I don't think you could buy a better street pad... well, I haven't experienced one yet.
For those who are tracking their car, these pads allow you to swap in/out the Carbotech track pads with ease.
Thanks to Adam@Amp'dAutosport.com for the time he took to answer my questions, fast shipping, great follow up and overall great experience. I can't wait for the first day out at the track to test out the XP10/XP8... I'll post a review then too
My observations...
#912
Supporting Vendor
Yes, I highly recommend the 1521. Give me a call at 216-780-8825 to order or direct here http://ampdautosport.com/brake-pads/corvette/
F: CT1405
R: CT1718
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F: CT1405
R: CT1718
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#913
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#914
Supporting Vendor
Too The Top.. Give us a call today 216-780-8825. If you have no questions and know what you need, order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#915
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#916
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#917
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#918
Supporting Vendor
HAPPY FRIDAY TO THE TOP....
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#919
Supporting Vendor
To the top.... Use promo code z28 @ check out and save $$ http://ampdautosport.com/brake-pads/corvette/ or just call us direct at 216-780-8825 and you can save $$.. We can also send pay pal..
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#920
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
