C7 performance brake pads including low dust
Old 05-18-2018, 10:26 AM
  #1041
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Friday order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%. If you do not know what you need call me at 216-780-8825 or email sales@ampdautosport.com
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 05-21-2018, 11:57 AM
  #1042
Supporting Vendor
Carbotech brake pads 100% made in the USA!
Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
F: ZO6/GS Iron rotor CT1405
R: ZO6/GS Iron rotor Ct1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-22-2018, 03:52 PM
  #1043
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-22-2018, 07:19 PM
  #1044
BlackMoon
BlackMoon's Avatar
I installed XP10 and XP12 on my C7Z, did the initial bedding processes and had the rotors turned before installing. Planning on tracking the car this weekend but not sure I'm comfortable with them. The noise isn't an issue but when braking the rotors feel warped and pulses really bad.
I flushed the system with Motul 600 as well.
Is this typical during the bedding process or should I be looking for a cause? I had the street version on before these and loved them even on the track the one time I went with them on.
Any suggestions? Thanks
Old 05-22-2018, 08:19 PM
  #1045
Supporting Vendor
[QUOTE=BlackMoon;1597254689]I installed XP10 and XP12 on my C7Z, did the initial bedding processes and had the rotors turned before installing. Planning on tracking the car this weekend but not sure I'm comfortable with them. The noise isn't an issue but when braking the rotors feel warped and pulses really bad.
Any suggestions? Thanks[/QUOTE
Please call me at 2167808825 sounds like bedding was not correct. I'm available all night.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-22-2018, 08:45 PM
  #1046
BlackMoon
BlackMoon's Avatar
Now that right there is EXCELLENT customer service.
Thank you for taking my call and helping.
Adam@Amp'dAutosport.com (05-22-2018)
Old 05-22-2018, 10:04 PM
  #1047
Supporting Vendor
As I said flip left to right on the calipers and go with this
Proper bedding instructions for AX-Series & XP-Series Compounds :
1. All new brake pads require a bedding process, start this process by pumping your brakes a few times to assure proper installation. Once on track perform several moderate (medium) near stops (to a very slow rolling speed) to thoroughly warm up the pads and rotors. This should take 1-2 laps. This allows a thin layer of the pad material to be transferred into the micro-grooves of the rotor.
2. After the pads/rotors are warm, perform a series of hard near stops (to a slow rolling speed) until some brake fade is felt. This process should take about 2-4 laps (depending on the track). Once this occurs, then stay off the brakes (as much as possible) and bring your car into the pits/paddock to completely cool. Do not lock the tires during this operation.
3.Allow brake pads and/or rotors cool down to ambient temperatures; no less than 30 minutes. The total bedding procedure should not take more than 5-6 laps or about 10-15 minutes.
NOTE: The proper way to bed your brake pads and brake discs (rotors) is to bed them on the racetrack, NOT on the street (excluding the Bobcat 1521 compound).
Old 05-22-2018, 10:33 PM
  #1048
BlackMoon
BlackMoon's Avatar
Yes but you offered your time at 8pm and that's great customer service. Thanks again.
Road Atlanta this weekend should do it. I may skip the warm up lap and wait to just go out with my group.
Adam@Amp'dAutosport.com (05-23-2018)
Old 05-23-2018, 03:40 PM
  #1049
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-25-2018, 10:42 AM
  #1050
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-29-2018, 12:30 PM
  #1051
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-30-2018, 04:00 PM
  #1052
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 05-31-2018, 12:13 PM
  #1053
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 06-01-2018, 12:15 PM
  #1054
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 06-03-2018, 09:49 AM
  #1055
Supporting Vendor
Order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%. If you do not know what you need call me at 216-780-8825 or email sales@ampdautosport.com
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 06-05-2018, 10:20 AM
  #1056
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 06-06-2018, 03:54 PM
  #1057
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
To C7 performance brake pads including low dust
Old 06-08-2018, 10:22 AM
  #1058
Supporting Vendor
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 06-11-2018, 12:38 PM
  #1059
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Old 06-12-2018, 10:34 AM
  #1060
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Quick Reply: C7 performance brake pads including low dust
