Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 Tech/Performance
Reload this Page >
How-To: Install Short Shifter / Replace Stock Shifter
Old 03-25-2015, 06:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Old 07-31-2017, 09:52 AM
  #221
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
I found the chrome ring was almost impossible to remove just by hand, but with just a little more force than I could apply with fingers it easily rotated. Note, there is a flat on two sides of the ring that make it easier to grip..
You just need a pair of these.
TEXHAWK0 is offline
Old 09-10-2017, 09:50 PM
  #222
Avanti
CF Senior Member
Avanti's Avatar
Sheesh, but THIS seems a lot more complicated than my memories of doing my C5 back in the day. I think I'll just settle for a **** made from a black Belgium cue ball dropped well down over the stick. I still have the jig I made for doing these... somewhere, hehehe.
Avanti is offline
Old 11-19-2017, 10:32 PM
  #223
gSwift
CF Senior Member
Support Corvetteforum!
gSwift's Avatar
Almost done with my MGW install on my 17 Z06 and took it down the road for a test drive. Feels really good.
One question though. Is it normal to hear a little more "gear chatter" when shifting? It could be I'm hearing more moving parts in there due to us not reusing that one thick rubber piece and also to my console not being put back together yet
gSwift is offline
Old 11-20-2017, 08:16 AM
  #224
badhabit_wb
CF Senior Member
Probably because everything hasn't been put back together
badhabit_wb is online now
Old 02-20-2018, 12:18 AM
  #225
Pineapple
CF Senior Member
Pineapple's Avatar
Thank you SO much Theta for making this guide! I used this guide and referred to MGW's videos to do my install. It went perfectly thanks to your guide!
Pineapple is offline
Old 03-01-2018, 09:57 AM
  #226
ZedMaximus
Junior Member
Great instructions Theta. Very informative and helpful. I too compared your instructions with the MGW install video's which lead to a successful flat-stick install. Love the positive feel of the MGW. The 'Snick' accompanied by each shift is strangely satisfying.
ZedMaximus is offline
Old 03-04-2018, 01:30 PM
  #227
GSdave
CF Member
GSdave's Avatar
Default install on a 2017 grand sport
I just finished my install. took about 3 hours but took my time and struggled with the rubber boot. All back togther and it looks to be working with a test in the garage through the gears. Will take it out once it warms up a bit..
GSdave is offline
Old 05-13-2018, 08:34 PM
  #228
Bob U
CF Senior Member
Bob U's Avatar
What interior removal tool kit did most use from Amazon?
Bob U is offline
Old 05-13-2018, 09:16 PM
  #229
GSdave
CF Member
GSdave's Avatar
I used this one. Worked fine
KINGLAKE Auto Door Clip Panel Trim Removal Tool Kits for Car Dash Radio Audio Installer Pry Tool 4Pcs https://www.amazon.com/dp/B00HNMLQAG/ref=cm_sw_r_cp_apip_hOIg15QQfCNQ7
GSdave is offline
Old 05-13-2018, 09:27 PM
  #230
Bob U
CF Senior Member
Bob U's Avatar
KINGLAKE Auto Door Clip Panel Trim Removal Tool Kits for Car Dash Radio Audio Installer Pry Tool 4Pcs https://www.amazon.com/dp/B00HNMLQAG..._hOIg15QQfCNQ7
Bob U is offline
Old 05-18-2018, 02:03 AM
  #231
chrismcdaniel
Junior Member
Will the CEL eventually go away or do I need to find a way to reset it?
chrismcdaniel is offline
Old 06-17-2018, 03:26 PM
  #232
DaveTheWav3
Junior Member
DaveTheWav3's Avatar
Default Trick to getting the rubber plate under the MGW boot
So I spent over an hour trying to get this on correctly after viewing the MGW install video, which apparently was on a C6. The way I finally got it to fit completely under the MGW boot was to hold the plate a little bit above the console, toward the top of the bolts, THEN push down the rubber boot under the MGW boot while holding the plate up. I couldn't get it to go without holding the plate up on the driver's side. But holding the plate up, only about 1", allowed me to flex the rubber down then under the MGW boot. Then it was 1 minute to finish the rest of the boot.
DaveTheWav3 is offline
Old 06-17-2018, 04:33 PM
  #233
badhabit_wb
CF Senior Member
Looks good.
Old 06-17-2018, 05:45 PM
  #234
DaveTheWav3
Junior Member
This is what I mean. I took it off and did it again. It's easy now. Don't put the panel all the way down, while its above the console, flex the rubber below the MGW boot on the left side. Once that side is in, the rest is easy. Get it under the boot, THEN push the panel down and bolt it in .
Old 06-17-2018, 07:05 PM
  #235
DaveTheWav3
Junior Member
I panicked for a minute when I was left with 4 bolts after I had reassembled the interior. I was like, WHAT DID I FORGET?!?!
But then I realized they went on the old shift box. HAHA
Quick Reply: How-To: Install Short Shifter / Replace Stock Shifter
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
