Handling
Old May 27, 2014 | 07:21 PM
Modshack's Avatar
Modshack
Originally Posted by JSibert
I have talked to my Corvette alignment specialist and he was not aware of a rear caster specification for the C7. He also took a ride with me and described the sensation as bump steer which is what I have surmised it could possibly be. So where do I find the rear caster alignment specification and also how to set the rear caster. I have run out of ideas. The connections on the suspension have been checked and all seem to be in order. I would like to get him to set the rear caster and see if that solves the problem.
There is not a caster spec for the rear. That is a front end alignment number only which has to do with the steering's self centering effect.
Are you lowered? That usually encourages exaggerated bump steer effect..
Old May 27, 2014 | 07:55 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Wrong !!!!! There is a caster spec. for the rear.
Old May 27, 2014 | 10:20 PM
Modshack's Avatar
Modshack
Show us then!
Old May 27, 2014 | 11:17 PM
Old Yellow's Avatar
Old Yellow
Show us then!
I'm not going to search all over for it, but believe me there was a list of tools required for dealers to purchase in order to qualify to sell C7s. On the list was a rear alignment caster tool, and the spec for rear caster was zero.
I think it may have been in one of the monthly GM TechLink issues.
ED
Old May 27, 2014 | 11:33 PM
xp800's Avatar
xp800
Here's a link to the rear caster tool:
http://sandyblogs.com/techlink/?p=2328
Link to race alignment settings...shows rear caster at zero, but not the street spec.
http://www.corvetteblogger.com/docs/...ationGuide.pdf
Old May 28, 2014 | 02:51 AM
BarneyZ's Avatar
BarneyZ
Old May 28, 2014 | 04:33 PM
JSibert's Avatar
JSibert
Yes, the C7 does have a rear Caster specification. Below is a link to the alignment specifications for street. It appears the caster is the same regardless of track or street.
https://i.imgur.com/1YDlc9O.jpg
Old May 28, 2014 | 04:37 PM
JSibert's Avatar
JSibert
Yes, I am lowered. Curious why my other lowered Corvettes did not exhibit bump steer and why this Corvette only has a right rear bump steer. I am also curious why GM put the capability to set caster in the rear of the C7 and not other year Corvettes.
Old May 28, 2014 | 07:14 PM
Modshack's Avatar
Modshack
Really? Zero? In other words, NO caster...
Old May 28, 2014 | 09:11 PM
Old Yellow's Avatar
Old Yellow
Yes: really.
Why would that surprise you when there is no need for self centering on the rear wheels of a front steer vehicle. They just want to be sure that the pivot axis is vertical to minimize bump steer.
To the OP. Their is no reason to assume that your problem is caused by bump steer, whether by virtue of incorrect castor, or toe. A number of faults can cause side movement of the rear of your car other than alignment, but the cause can only be determined by a competent mechanic.
Old May 28, 2014 | 09:50 PM
JSibert's Avatar
JSibert
Originally Posted by Old Yellow
Yes: really.
And why should I not have the rear caster checked to see if that may be the problem. As I said earlier I am running out of ideas.
Old May 28, 2014 | 09:56 PM
Old Yellow's Avatar
Old Yellow
Sorry for the misunderstanding. By all means all four wheels alignment should be checked, but don't make that your main point of reference. If you ask for alignment to be checked that's all they'll do. Give them all of your symptoms, and let them do the diagnosing.
Ed
Old May 28, 2014 | 10:00 PM
  #33
xp800's Avatar
xp800
Just out of curiosity, have you swapped sides on the rear tires? A bit of a shot in the dark, but ...
Old May 29, 2014 | 08:21 AM
  #34
JSibert's Avatar
JSibert
Ed
I have given my Corvette mechanic all the symptoms, he has driven the car and has ridden in the car with me. He has checked the alignment and all the suspension for anything loose. The alignment is spot on and the only thing he needs to do is obtain the necessary tool to perform the rear caster as another check. If you know of anything else that needs to be checked could you please advise because he is running out of things to check and the dealer has no clue as to the cause. This is not a little problem. If I were to take this car on a performance run through some twisties I would be a little hesitant. The car is not stable. Frustration is the word of the day.
  #35
JSibert's Avatar
JSibert
Aren't the tires directional????
Old May 29, 2014 | 08:43 AM
  #36
gthal's Avatar
gthal
Something HAS to be wrong. I find this car is extremely planted when the tires are warm. My only hesitancy pushing the car hard is that I haven't yet reached the car's limits so I don't have a feel for where that is... I'll know this weekend after I get back from the track.
No they are not. I suppose it is possible there is a problem with one of the tires that isn't visible to the naked eye... unlikely though.
I wonder if you could drive another C7 to see if it feels differently than your car. That might help you better describe the difference in handling characteristics which might give some additional clues.
Old May 29, 2014 | 09:49 AM
  #37
*C7*'s Avatar
*C7*
No, they are not. ( Sorry, did not see gthal mentioned it ).
To Handling
Old May 29, 2014 | 10:44 AM
  #38
xp800's Avatar
xp800
Since pretty much all the obvious has been checked, that's why I suggested trying a tire swap.
Another outside idea: eDiff problem? If it was not functioning properly and directing significantly more torque to one side, could this cause the rear end hops when going over bumps and the tires unload?
Could you have one bad rear shock, allowing uncontrolled wheel hop on one side?
Old May 29, 2014 | 02:25 PM
  #39
JoesC5's Avatar
JoesC5
Originally Posted by B Stead
The problem is the short sidewall tires and the heavy runflat tires. Basically, that setup is not going to work without magnetic shocks.
However, I recently watched a 458 accelerate over some city bumps and humps and it did not look good with the magnetic suspension going soft.
Anyway, the fix is wider tires and non-runflat tires:
265/35-18 tire on a 18 x 9.5 52mm wheel
305/30-19 tire on a 19 x 11 74mm wheel
or
265/35-19 tire on a 19 x 9.5 52mm wheel
305/30-20 tire on a 20 x 11 74mm wheel
And that first tire pair is about 1/2" less diameter than stock while the second tire pair is about 1/2" more diameter than stock. Both tire sets have the same sidewall heights at 3.65" front and 3.6" rear. There's a wider selection of tires in the 18/19 set.
Another setup is:
255/40-18 tire
295/35-19 tire
That's a front sidewall height of 4.0" and a rear sidewall height of 4.06".
And the BBS RS-GT wheels are spec widths for them at 18 x 9 and 19 x 10.5.
The Z51 tire sidewall heights are:
3.38" front and 3.37" rear
MyC6 Z06 has short sidewalls(3.8" front. 3.84" rear), wider wheels/tires(than the C7) and has heavy runflat tires(first was the OE Goodyear's and now Bridgestone's) and it does not have the mag ride. I have very item you listed as a problem.
All those C6 ZR1's, Z06/Z07's and 427 Convertibles have 19/20 inch wheels with 3.37" sidewalls on the front and 3.30" sidewalls on the rear and they don't have the problem with a mishandling car from short sidewalls.
My C6 Z06 runs true, no tramlining or darting, and a bump in the road does not cause the car to become unsettled.
I can cruise at 80 MPH on longitudinally grooved concrete pavement with no side to side movement of my car.
I think you need to find something else to place the blame on as the items you listed are not the problem.
Old May 29, 2014 | 02:53 PM
  #40
JoesC5's Avatar
JoesC5
First have him set the specified alignment spec(camber front caster, toe, thrust angle) to the center of GM's very broad spec with zero front toe(or a very minimum of toe in...no toe out). Set the rear toe at zero. A good alignment tech can do it. Don't worry about rear caster.
If that doesn't correct the problem, then switch out the stock wheels/tires from a known good C7 Z51, to see if you have a bad tire. change one tire at a time, to isolate the bad tire(if you have a bad tire). Don't start changing tire sizes trying to correct your problem.
If that doesn't correct the problem, take it higher in GM and start reviewing the lemon laws in your state. Every time you take the car in for this problem, make sure the dealer makes out the paperwork showing you had the car in for service, and save your copy. most states have either 3 or 4 times for the dealer to correct a problem, or a total of 30 days out of service.
PS- It's not your job to run out of ideas. That's the dealer's/GM's job. Hold their feet to the fire, until you are happy with the car. See if you can get the alignment printout and post it for the forum to see. Maybe someone will spot something unusual.
