How-To: Lift/Jack Vehicle Per GM Specifications
St. Jude Donor '14-'15
The following How-To covers the explanation of how to Lift/Jack Vehicle Per GM Specifications and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Please note that these instructions are current for the C7, even though the C6 is shown as an example.
Blackcherry20 (06-10-2023)
TB186 (01-24-2024)
robert miller (10-07-2016)
Can you go between the two green circles in front with a bottle jack to put jack stands on the circular areas?
Art17 (09-27-2017)
But to answer your question, that area is able to temporarily hold the load. If you look at the shading, the main points are preferred, while the rest of the support is a secondary (though acceptable) lift zone.
Received 8,928 Likes
Bill
The following 4 users liked this post by Bill Dearborn:
braveheart3158 (04-14-2018),
jtscherle (09-30-2023),
need-for-speed (07-18-2019),
OhioDave (01-15-2018)
I am happy to see they confirm you can lift in front of the shipping slot because that works better with my standard arm length 2 post lift. Its also more stable to spread the arms more and lift on frame contact points further apart.
I lift using pucks in the shipping slots and haven't found the car to be unstable when lifted by my two post MaxJax. I have the side skirts on my car and I have to use the pucks or the lift bars would come into contact with the skirts. If I moved the front arm further forward on the frame I would still need to stick a hockey puck between the lift pad and the frame to get the lift bar to clear the skirt.
Bill
Bill
Yeah, I am just saying for people that have a lift with longer arms like mine has, you have the option to lift other places on the frame. I wasn't sure about this at first and had to search a bit to find this thread that clarifies things pretty well.
Jacking from under front of car.
While I have done this in the past, I generally only recommend using opposing floor jacks to lift - hell of a risk to crawl under there with only a bottle jack.
BTW, I have a C6, 2006 Z51.
Navigator
I see the preferred rear jackstand points per green circles on color diagram in 2nd post of this thread, and per my owner manual, are on each side of the rear crossmember forward of the rear axle. But looking under my 2017 C7 M7, only the center 9" or so appears level; outside of that it slopes up towards the sides of the car at a shallow angle. The color diagram appears to show the jackstand points placed right under this shallow angle. It sure looks like a risky point to place them, as I would think the stands could slip sideways on this angled surface.
Yet I see above the service manual pic shows the crossmember behind rear axle can be used instead of the crossmember in front of rear axle for of jackstands-- that looks much safer to me.
thanks, Jim
thanks, Jim
Do you have the front and rear mixed up? The diagram in the 2nd post has the front of the car on the right side. On the rear of the car you put the stands behind the axle.
Navigator
Boy do I feel dumb!! You are correct, I thought I was looking at the rear in the color diagram, not the front. I saw the bold "leaf spring" warning on the diagram and assumed it was the rear since my last Corvette (a '67) didn't have leaf spring in the front. Thanks for setting me straight!
Will this jack fit under my 2017 C7 Z06??
https://t.harborfreight.com/15-Ton-A...ump-60569.html
Thanks!!
Thanks!!
It'll go down minimum height of 2 5/8" is what the sticker says on mine.
I can't believe nobody has an answer for this question that I posted months ago?!?! I just jacked my 06 Z-51 from the side jack points and slid jack stands underneath to the suggested support points anyways.
lndrckt (01-29-2019)
^^Maybe because this is the C7 section? With my C7 Z06, I use a two post lift and to get the arms under the car I have to drive the car on ramps/blocks that raise it about 3" off the floor. Maybe you need to do the same to get the jack under the front.
I have that jack, but haven't tried it because I do as noted above. I am pretty sure it will fit, but can check when I am out at the shop later today. If you don't hear back send me a PM.
Thanks!!
Thanks!!
06Rawpower (08-08-2017)
