[Mod] Switched AUX power jacks - making them always hot
As you already know, the two front AUX (cigarette lighter) jacks are ignition switched.
I needed -at least- one of the front jacks to always be hot.
On my 2015 the relay that switches the frontward AUX jacks is located on the rear fuse panel:
Relay 4 is the responsible relay:
I'm sure there are many ways to be successful with this; here is the one I went with:
* Pull relay R4 straight out
* take a mini-fuse:
*with a pair of thin bladed wire cutters, cut away the plastic - extract the two blade terminals. Surprisingly, these terminals are the exact same width and thickness of the relay terminals:
*take a piece of wire which is a little larger/thicker than the blades themselves and solder it on the tops of each of these blade terminals:
(the assembly is sitting upside down in this pic, terminals pointing upwards)
carefully plug one terminal in the 11 o'clock position (now empty) relay 4 socket, and the other in the 5 o'clock positioned relay socket:
Though, this makes both frontwards AUX jacks hot all the time; but in my specific it's moot.
Another method would be to modify the pulled relay... and plug it back in.
* take a mini-fuse:
The following 7 users liked this post by Mike Mercury:
CDH76 (12-09-2015),
Flame Red (12-09-2015),
gunnerjuju (11-24-2016),
meyerweb (12-08-2015),
probono (08-06-2018),
and 2 others liked this post.
By "aux" jacks, you mean the "lighter" sockets, correct?
This is a great mod that I haven't seen before. I rewired the lighter socket (and added a couple of extra ones) on my Miata, but that was a more complicated project. I'll be doing this very, very soon.
The following 2 users liked this post by Flame Red:
beaversstonehaven (10-26-2018),
SyberSaint (12-13-2017)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
Looks like it will work but wouldn't that make the 2 sockets fuseless? If yes, I could see soldering leads to a fuse and then making this connection with the fuse in the circuit.
Wouldn't that be better than a straight hot wire or is there a fuse somewhere else in the circuit?
ELmer
ELmer
Vette Jockey (10-17-2022)
I don't believe that the relays have a fuse inside of them.
I would replace the insulated wire with buss wire. If you pick the correct diameter or gauge it would act as a fuse.
Or you could solder the pulled leads on to a fuse and lay it sideways where the relay was.
Moderator
added link to the master list of how-to guides for c7 corvette stingray sticky thread.
