So direct injection does cause carbon buildup...
So in Volkswagens, it does. Is direct injection different on our general motor Corvettes than Volkswagens direct injection?
Its got to do with how the PCV system is designed and how much oil vapor is created which will vary from engine to engine. Supposedly GM went to great lengths on the C7 with the baffles in the valve covers to reduce the amount of oil ingested. I would reroute the PCV and/or use a catch can based on all the oil ingestion issues I've seen posted here.
That article refers to a 2006 VW. I can't help but think the technology has improved a little bit in the last 9 years.
But if you're really worried, make sure you use Top Tier gasoline:
http://www.toptiergas.com/
St. Jude Donor '14-'15
The DI cars (especially EU manufacturers) of the last two generations have paved the way for better technology across the industry. The early examples (this 2006 VW being a great example) were fraught with problems, while the latest-gen EU and US models don't really have enough data to make a conclusion.
For now, we'll just have to hope.
If you do some research on this Forum and youtube and you'll find the type of gas you use will make little or no difference if you have a Direct Injection engine. You will eventually build up Coking on the intake valves over time and eventually loose some power. Adding a Catch Can helps.
I'm Batman..
Pro Mechanic
This is the biggest pitfall with DI. I would like to see this question asked to Tadge to see what the Corvette team has to say about it. Discuss it more here as well:
https://www.corvetteforum.com/forums...on-valves.html
Ant
Ant
Received 2,379 Likes
the term direct in direct injection refers to the fuel being injected "directly" into the cylinder/combustion chamber, which is also below (past in terms of airflow) the heads.
This short video explains the Direct Injection issues pretty well:
I think DI engine technology will eventually evolve to solve the problem. While some manufacturers choose to ignore the problem, as the video states, other manufacturers are starting to address the problem.
St. Jude Donor '13-'14-'15
PLUS Use of injector cleaner with DI becomes less effective on cleaning valve stems and the seat area---But it still can be done by the deep cleaning process with SEAFOAM---
So, here is one picture from my son's 2010 Audi Q5 V6. Every valve looked exactly like this one. No doubt there is an issue with direct injection and it would be wise to use some type of cleaner like Seafoam every 15-20K.
BTW...he uses top tier premium and I add a can of Techron to his tank every 8-10K...but obviously that makes little difference.
So is it just use SeaFoam or something similar every year?
I've done it to my other cars, had a few high mileage LS1's that were swaps into other cars so I ran a can through.
Except for the neighbors hating me it seemed to work pretty well.
UPR catch can from day 1-----------
There's also the 'get-it-so-hot-it-burns-off' method that BMW guys use... Not great for the motor, but done once a year, I can't see it doing much harm. Involves running at a sustained 4000rpm for 20 minutes if I remember correctly.
Seafoam has been hit-or-miss on the N18, N20, etc. Can't comment on the LT1/LT4.
well I personally have been driving 4 different GM vehicle for the last 7 years......I had 2 of them at the same time.....ALL of them had a D.I. engine in it.....3 of them only required Regular Gas....and I never bothered to ensure that I put "Top Tier" gas in them, the Vette.....its requires Premium and I will put Top Tier in it.....BUT not one of these vehicles have EVER been into a shop for any reason other than for a Oil/Filter Change. The first two had right 100K miles on them when they were traded in...... I have no fear of D.I. engines at all.....if fact I prefer to have one.
I have no doubt DI engines can and do last a long time without adding a Catch Can, although there's a lot of evidence that DI engines do ingest PCV fumes and Catch Can's can help.
The C7 in the video below shows how much oil deposits and valve coking accumulate after only 5500 miles. At the 7 minute 40 second point in the video a link will pop up which will show what the inside of the intake and intake valves look like on this low mileage C7.
Did I miss something in that video? They disconnected the hose from the dry sump oil tank to the intake, but I didn't seem them reconnect anything there nor plug the connections that the hose used to attach to.
