NPP Reverse-Engineered - Full Open/Close, Non-Factory-NPP Retrofit
Tech4882 (05-15-2018)
#203
I would like to get these, does anyone have them for sale all ready to go? z06 automatic.
Mikec7z (07-17-2018)
#211
Actuator wiring
Actuator pin order?
Hi Fyreant and Red 1,
i got the controller from smola and he has been very helpful, but I wanted to get all the information on this thread for future retrofitters
can you provide a possible pin diagram for the actuator connection?
i read that pin 4 is the power, and 1&2 are the ground,
i’ve attached a modified image with the pin order (assumption) and wanted to confirm with you guys.
Thank you,
joel
#212
I'm Batman..
Pro Mechanic
Actuator pin order?
Thank you,
joel
#213
Thanks for the reply. Waiting for my car to comeback from diff replacement before I tackle this. Another 2016 with the issue. Good thing it’s under warranty 😝
The npp is much quiter than the muffler delete. I started missing the sound as soon as I drove it. Damn California law 😡
#214
Exhaust over 95db is an automatic $1k fine then visit the state referee then who knows 😡
It was a fix it ticket before this year.
Red convertible sticks out quite a bit and at 103db is pretty loud 😝
here’s a link for more descriptions
https://jalopnik.com/why-people-are-...1831620651/amp
FYREANT (02-08-2019)
#217
Thank you very much. I would have fried the actuator with my assumption.
One more question, do I supply the PWM signal to pin #2 or #4?
if I use pin #2, do I need to provide a constant 12v to #4 or leave it open for the retrofit?
thanks again to all your feedback 😎
#218
I bought a "new cut off" exhaust system from ebay that looks like it was cut off when the car was brand new. Unfortunately I did not know how this system worked and I thought it was just standard motor type system so I tried every combination of 12v + and - that I could to get them to actuate. I bet that I've destroyed them now. They are on my H3 Hummer LS-3 conversion. Right now I'm just holding the flapper valves in position with some chicken wire since I can't figure out the circuit.
#220
This is perfect 👍🏻
Thank you you very much. Hopefully I get my car from the dealer today Or Monday 😇
diff came early 😎
diff came early 😎
