Tow hook upgrade to turned premium SS
Supporting Vendor
Its a role pin and will lock the shaft when you bottom it out. For the run we have now, we have a coating on the turned part of shaft for the members that want to leave the hooks on.
Do you have the stock C7 base grill? I do and the threaded portion of another venders hook does not fit through the grill opening. I see where these are turned down in size near the hook but the threads still have to go through the opening. I don't think the grill opening between the grates will line up with the hook even if it did fit. Looks like I will have to cut out a few slats in the grill for it to fit. Curious what you did?
Supporting Vendor
Our tow hooks do fit in the Z51 grill, but you have to line up right and it will touch the grill.
Supporting Vendor
Do not paint, we have shrink tube to go over the turned down part if you want to leave on. PM me and I will send you the mod.
Supporting Vendor
Supporting Vendor
