Tow hook upgrade to turned premium SS
Supporting Vendor
We now have in stock chrome molly premium turned down front and more being made for the C7 ZO6 Corvette!! We have now the forged red D ring and SS shaft that fits front and rear receivers on the C7 ZO6. We are making receivers for the Z51 at this time and will post when done.
the single red standard tow hook is $79.99
The NEW chrome molly turned down front shaft and the rear are chrome molly also. the red D ring is forged steel and has a heim joint.
We now have the premium chrome molly with turned down shaft for the front to not touch the grill so much, and a short 3.5 inch for the rear, they are $169.99 a set. in stock now at www.zl1addons.com
We got the standard going for you guys as fast as we could and the SS are sold out.
They will be available at www.zl1addons.com tonight 4/16/15
Supporting Vendor
If you loose one on the track and that will never happen I will give you a new one no charge. (Now some one may take it)
Yes the rear one is all the way in tight, the front i picked up two 20 mm nuts and found the sweet spot where I wanted it to be and the nuts are tight against each other , then I screwed the hook in tight. It took me 3 times to get it where I wanted. Very easy, mine stay in and don't move.
Do you have the stock C7 base grill? I do and the threaded portion of another venders hook does not fit through the grill opening. I see where these are turned down in size near the hook but the threads still have to go through the opening. I don't think the grill opening between the grates will line up with the hook even if it did fit. Looks like I will have to cut out a few slats in the grill for it to fit. Curious what you did?
Supporting Vendor
Do not cut the grill, no need to cut the grill. They will fit. Also the nuts are not needed, if the D ring stays down it will not turn.
Supporting Vendor
Also the production shafts will have a lock pin to tighten when you install. We have the pin installed on all we ship now. I do not use the pin on my car and have driven many miles with it not turning.
Received 2,379 Likes
looks like a booger hanging from a nose (except it's red). function over form because race car! :-)
