Elite E2 Catch Can Results 2015 Z51 A8
Installed the Elite E2 single outlet @800 miles in my 2015 Z51 A8. Changed factory fill oil @500 miles with Penzoil Ultra. Verified no oil in the intake tube @500 miles and again @1800 miles (installed aFe CAI). Did not inspect inside intake manifold at either time. Installation was a breeze.
So the results... After 1000 miles, there is about 1 tablespoon of oil. Pretty clean too. Picture makes it look dirtier than it really was. Bottom line is that I'm glad I have it, but others seem to have caught a lot more than me.
BACKGROUND:
Opted not to get oil separator for dry sump cap since I personally believe it only helps for dry sump oil foaming on the factory fill oil. For severe overfill, not much is going to help keep from pushing liquid into the intake through the burp line. I also only got the single outlet for my Z51 since I believe there's more than enough vacuum at WOT given the PCV vacuum tube that crosses the mouth of the intake manifold. The location of it appears to be at the highest velocity point of the intake flow, and the air crossing the PCV tube opening at high velocity causes vacuum. I can't think of a reason for GM to have put that "obstruction" where it is from a "free flow" perspective. I believe it's the vacuum at WOT. (see pic below pointing to the tube I'm talking about).
For reference, my '14 Z51 M7 @2200 miles had at LEAST 1/2 cup of liquid oil in the intake from the burp line. This was with the factory fill oil. It was at most 1/4 quart overfilled from factory on delivery (I did the PDI with dealer, and no oil was added). This was also before the updated 500 mile dry sump service interval announcement. I drove the first 500 break-in miles as recommended in the manual, then to 2200 with only occasional spirited driving. Loved downshifting though...this may also make things worse.
My current 2015 Z51 A8 was broken-in the same way, but oil changed at 500 miles. ZERO liquid oil in intake tube. Not even any oily film in the tube. Now at 1800 miles, installed the aFe CAI, and again zero oil or film. But also had the catch can... Wonder if the A8 and no frequent downshifting/engine braking also made it better?
Video of removing the can cup for inspection. No bolt loosening required!
http://vid581.photobucket.com/albums...pssc0hanv1.mp4
BACKGROUND:
Update: after 2000 miles since last drain, I had about 1.5oz. So just a tad more than what I drained after 1000 miles.
Very easy to drain without loosening mount so long as you don't over tighten the bowl. You can feel the o-ring engage and I stop as soon as the bowl stops on the shoulder. There's about 3-4mm clearance between the bottom of the bowl and the lower steering shaft U-joint when bowl is loose. Then walk it out between the two rubber hoses. Drain, wipe, repeat.
Very satisfied!
Very satisfied!
I have the same Elite can mine is mounted like yours, on mine I moved the ground wire to one of the other bolts on that same bracket, I felt it would ground better than on the aluminum of the catch can.
I don't know if you agree but I would think it is easier to run that one bolt out to gain access to turn off the catch can bowl for cleaning.
In the way I have mine mounted, I do not loosen the bolt to unscrew the cup. My bracket is swiveled forward a bit rather than being at a right angle to the frame, and I don't tighten the cup past just stopping. Maybe this helps? It's also quite feasible that there is a small amount of build variation that gives me a couple mm more room to drop the cup. If I was better at YouTube, I'd try to upload a video...
Edit: added a picture of the top view and a video.
As for ground, the bolt itself I think is the conductor that carries into the threaded hole. The face of the tapped hole on the frame was fully painted on mine, so I opted to just leave it on top of the bracket. It seemed to me 'no worse' with the Elite bracket in the stack. Could be wrong there too, but so far no electrical gremlins...uh oh...jinxed myself.
I'm not sure I can make the conclusion that it's better/worse than the RX. For my needs on an essentially "stock" application, I am more than pleased. I did look at RX before purchasing mine, but I felt that the extra expense, heavy duty appearance, and cost were a bit too much for my needs. Maybe the RX performs better, but mine seems to be working well for me.
Here's my latest "catch" from 3,000 highway miles using a Standard Elite for a base C7. 10,500 miles now and this is consist with the two previous oil changes.
I should add I'm only filling with 6.25 quarts of oil which is half way on the stick. This would eliminate the argument that the engine is overfilled and pushing out excess oil.
It will be interesting to see what happens in the cooler/cold weather into November.
Quick questions:
1- Oil over filling issue, is it limited to Z51 cars or Base cars as well??
2- When i removed the "Outlet" tube from the catch can, it leaked some oil? Is this Normal? I expected the catch can to catch all the Oil, which mean the tube should be empty from oil as oil is being collected in the catch can, so basically this means the little oil is actually going into the intake manifold, is this Normal?
3- When do you guys clean the catch can, before or after oil changes?
Received 1,762 Likes
Mine looks the same as well on a base 2016 Manual C7, too much oil got collected i the catch can.
Quick questions:
WITH THESE CARS BEING DIRECT INJ ALL OF THEM EVEN MORE SO IF THEY ARE OVER FILLED.
YES IT WILL ARE SOME WILL STILL GET INTO THE INTAKE & THAT.
AT OIL CHG ARE REALLY NEED TO LOOK SOONER IF YOU DRIVE THE CAR LIKE YOU HAVE STOLEN IT.
I KEEP MY Z51 OVER 1/4 QT LOW. Robert
Quick questions:
